How do I make it work
SOURCE: can't get Blueray player to release DVD
You may now have corrupted firmware. did the dvd contain the firmware update?
Are you sure there wasn't already a cd in the tray? (Ie two cd's are now inside?
The easiest way to remove the cd if turning off fails is to remove the screws around the casing. Lift off the lid and the cd should come out easily, however if the update was corrupt or the wrong firmware you may now have a dead player.
Try removing the Cd as described first with the power off and plug removed.
Then see if the unit powers up and the drawer opens.
If so you may be able to revert it to its original firmware from the vendors site.
Regards
Marc
SOURCE: Magnavox NB500MG9 BluRay Player
A Blu-ray player can play DVD or CD and still not play Blu-ray. It may play Blu-ray but not CD or DVD, or burned discs. This is all caused by the 'optical' a part that reads the disc in the machine. Your player will need service as a Blu-ray optic cannot just be 'dropped' into a player.
Testimonial: "good answer I upd soft,cleaning the lens izopropil but I can not read only regular dvd the service guy was asking for the same price like the new one"
SOURCE: I have samsung BD-D7500/SX 3D
this model by this time has no free region code available but you can modified the hardware by installing chip open this link www.gattiweb.com for multi region blue ray player modifications. hope this may help thanks for consulting fixya.
SOURCE: A dvd is stuck in
Hi.I do not know if you can do it but no other way..Lets try it..
Please got a screwdriver and open the DVD case from the sides and back. It is simple, just some black screws. Then look in the unit and see and gently remove the disks by plastic holder open and sliding the disks out.
Then put the cover back on and put the screws back in. Should Work fine now.
I hope this helps you. Good luck.
Please let me know if you need more help.
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
SOURCE: I want to unlock my
Hi.
There is no region hack for this player, not even for the DVD only (see LG BD660 region code - VideoHelp.com , along with previous Fixya threads and similar)
The only way to make it region free is by desoldering and replacing the chip. That would be expensive and will invalidate warranty.
Sorry to bear bad news but I hope that this will save you some times.
Regards.
Ginko
