Samsung sw50vs sensor pressure switch - Washing Machines
  • Washing Mach... Master
  • 17,129 Answers
Check this link for tips: pressure switch
Posted on Jan 11, 2013
I have a samsung front load washer. I get an error code nf. What is that?
indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure. if its filling with water and just keeps going it can be a leak in the door sensor module as this is a sensor to the the pasher the water pressure and how full it it is. it can also display 4E that is the same code. check that there is water pressure at the inlet to the washer this is the pipe on the back to the water mains supply. it could also mean the switch that lets the water into the washer is not working. but first check that there is water getting it to the washer.
Jun 30, 2017 | Samsung Washing Machines
2009 cummins isx cm871 fualt code mid 128 sid 372 fmi 1
[PDF]Fault codes .pdf - heavydutypowertrain.Com
www.heavydutypowertrain.com/md200codes.pdf
Description. Sample Fault Code Chart. Sample Display. 128. PID/SID FMI. MID. 110. 003 ... MID 128 - CAT. CAT. PID/. SID. FMI Fault. Code. Fault. Description. 1. 11. 72..... Injector Metering Rail #1. Cummins (Continued). PID/. SID. FMI Fault. Code ...372. Fuel Pump Control Module. 12. 374. Fuel Pump Control Module. 13.
2009 Volvo ISX Cummings Codes ' TruckersReport.com Trucking Forum ...
www.thetruckersreport.com > ... > Volvo Forum
Sep 13, 2013 - Well my truck finally stopped today and has these 6 codes. Anyone have any idea what they are? MID 128 SID 380 FMI 11 MID 128 PID 131 ...
[PDF]Diagnostic Fault Codes For Cummins Engines - Allied ...
www.alliedsystems.com/pdf/Wagner/Forms/80/80-1044.pdf
Dec 18, 2015 | Cummins Signature ISX QSX15 Series Service...
My Samsung Washer has a code of 1E which means maybe the water level. My problem is that it want turn off. Even when I push the stop button. The door is locked and it keeps beeping and flashing
1e is usually a pressure sensor error. To open the door you will need to switch off the appliance at the wall then after about 2 minutes the door should unlock. You could try the appliance again as it may just be a glitch but you will probably need the pressure sensor.
Good luck.
Dec 17, 2015 | Samsung Washing Machines
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
  • Apr 06, 2015 | Samsung Washing Machines
    I get an error code PE on Samsung washer WA5451washer
    PE error code is a pressure sensor code, and more than likely the sensor will need to be replaced. Try unplugging the unit for about 5 minutes and see if it will clear it out. If not, will need to replace pressure switch and hose (switch looks like a little UFO under the console, pretty easy job.
    Nov 11, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
    IE error code
    1 E error code
    WATER PRESSURE SWITCH ERROR
    Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
    Normal Level = Abnormal W/L Frequency
    Low Level = 30.00 Khz High Level = 15.00 Khz
    If the same signal is detected for more than 5 seconds, it is a pressure sensor error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
    Nov 03, 2012 | Samsung SW62ASP Top Load Washer
    I have a code p0453 is a ford fiesta 2012 what's the probleme
    P0453 FORD - EVAP Pressure Sensor/Switch High
    Possible causes- Evaporative Emission System (EVAP) Pressure Sensor/Switch harness is open or shorted
    - Evaporative Emission System (EVAP) Pressure Sensor/Switch circuit poor electrical connection
    - Faulty Evaporative Emission System (EVAP) Pressure Sensor/Switch
    - Damaged fuel tank pressure sensor
    This likely is an emission system warranty problem.
    Oct 15, 2012 | Cars & Trucks
    THE "SWITCH" GOES BAD EVERY
    Please look at the list below, keeping in mind that this is not an exhaustive list of the switches that your vehicle is equipped with. After staring at the list for a while, tell me what is wrong with your question.
    >> A/C High Pressure Switch
    >> A/C Low Pressure Switch
    >> A/C Refrigerant Pressure Sensor / Switch
    >> Ambient Temperature Sensor / Switch HVAC
    >> Blower Motor Switch
    >> Brake Fluid Level Sensor/Switch
    >> Brake Fluid Pressure Sensor/Switch
    >> Brake Light Switch
    >> Brake Switch (Cruise Control)
    >> Cabin Temperature Sensor / Switch
    >> Combination Switch
    >> Coolant Temperature Sensor/Switch (For Computer)
    >> Cruise Control Switch
    >> Door Jam Switch
    >> Door Sensor/Switch (For Alarm)
    >> Door Switch
    >> Driver Information Center (DIC) Switch
    >> Engine - Coolant Temperature Sensor/Switch
    >> Fog/Driving Lamp Switch
    >> Fuel Door Switch
    >> Garage Door Opener Switch
    >> Glove Box Lamp Switch
    >> Hazard Warning Switch
    >> Headlamp Dimmer Switch
    >> Headlamp Switch
    >> Heated Glass Element Switch
    >> High Pressure Sensor / Switch
    >> Hood Switch / Sensor
    >> Horn Switch
    >> Ignition Switch
    >> Ignition Switch, Buzzer
    >> Low Pressure Sensor / Switch
    >> Neutral Safety Switch
    >> Parking Brake Release Switch
    >> Parking Brake Warning Switch
    >> Power Door Lock Switch
    >> Power Mirror Switch
    >> Power Seat Switch
    >> Power Window Switch
    >> Pressure Cycling Switch
    >> Rear Defogger Switch
    >> Remote Switch
    >> Seat Belt Buckle Switch
    >> Seat Heater Switch
    >> Seat Memory Switch
    >> Shift Interlock Switch
    >> Sunroof / Moonroof Switch
    >> Telescoping Wheel Switch
    >> Tilt Wheel Switch
    >> Traction Control Switch
    >> Transmission Mode Switch
    >> Transmission Temperature Sensor/Switch, A/T
    >> Trunk / Liftgate Switch
    >> Trunk/Liftgate Sensor/Switch (For Alarm)
    >> Turn Signal Switch
    >> Underhood Lamp Switch
    >> Valet Switch
    >> Washer Fluid Level Switch
    >> Windshield Washer Switch
    Aug 17, 2011 | 2001 Cadillac DeVille
    How can I fix the error code 1E in my washmaching samsung SW70A1P
    Error 1E is no pulse to weighing sensor to open and closed valve.
    Step to solve:
    1. Open top cover (behind door cover)
    2. Check connecting cable of pressure switch, pull out and clean up connector (usually dirty with rust)
    3. Open back cover, pull out pressure switch.
    4. Clean up hose of pressure switch, blow the hose slowly.
    5. install again pressure switch to the position.
    6. Install cable to connector, check the current & resistant by tester.
    7. Push "on" selector and fill drying position, wait until digital no blink. Running test.
    8. If machine is running well closed the cover.
    If still error condition (1E Error still come out), change part of "Pressure Switch" by the new one.
    Regards,
    Priyo
    Nov 16, 2010 | Washing Machines
    Samsung Washing machine fault
    I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
    Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
    Greetings - Thomas
    Jan 16, 2008 | Samsung WF203ANW Front Load Washer
    Washing Machines Logo
    12 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
