Question about Linksys Computers & Internet
I forgot the ip password - Linksys Computers & Internet
  • 7,627 Answers
If you are refering to the Security Key (password). You can reset the Linksys by pushing and holding the reset button for 30 seconds or so, release, that will reset to default settings. Rconfigure the SSID and Security Key. You may want to write it down for future use.
Posted on Jan 11, 2013
Password forgot
Hard wire into your router, enter ip address and then user name and password or factory default.
Change password security to none, save settings, cycle power on router. This will clear secutiy on router and now repeat the above steps and enable secutity and assign password.
Sep 24, 2014 | Seagate Computers & Internet
How do i reset my password for the voice messges on the cisco ip phone 7962
password is a server level not phone, you have to contact your system admin.
Sep 11, 2014 | Cisco 7962G IP Phone
I forgot the security key
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jun 25, 2011 | Linksys WRT120N Router
Forgot user name and password
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
I forgot my password
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you forgott WEP password in wireless security note down the WEP code it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 08, 2010 | Linksys WRT120N Router
Forgot my password
Sep 06, 2010 | Linksys Wireless-G Broadband Router
Forgot password and user name??
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you want to secure wireless then enable WEP in wireless security enter password there it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 05, 2010 | Linksys Wireless-G Broadband Router
How to obtain my password and add another laptop to wrt54G
To access the router's web-based setup page using Mac, click here. Step 1:
Step 2:
Step 3:
Aug 23, 2010 | Linksys Wireless-G WRT54G Router
How to find router fully ip address?
if your PC still working and connecting to the internet thru this router, then open command prmpt, enter "ipconfig" and read the ip address of the default gateway. at most simple home networks, that is your router.
Jun 06, 2009 | EnGenius EOC-3220+ (EOC3220PLUS)
Computers & Internet Logo
23 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
