Question about Kodak EasyShare C180 Digital Camera
Mi cameras lens has refused to go back
Will i was shutting it down the batteries died and it stopped on the way
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello Andrew, With the batteries removed try gently pushing the lens back in with the palm of your hand, GENTLY being the word. If you are able to push it back in then install batteries and turn it on.
Best Regards, Russell
Posted on Jan 24, 2013
  • 641 Answers
SOURCE: Lens won't open and retract.
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Posted on Sep 03, 2007
SOURCE: lens won't go back in
some times if the batteries get wet it will short the system and it won't turn back on... if you dropped it something may have shifted inside blocking the messaging systems inside the camera. i would take it to a local camera shop.
Posted on Oct 22, 2008
  • 411 Answers
SOURCE: Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Posted on Mar 06, 2010
lock123
  • 6831 Answers
SOURCE: I was taking pictures and
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 16, 2010
lock123
  • 6831 Answers
SOURCE: As soon as I turn
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
Camera froze
Take out the batterys turn off goodluck
Aug 30, 2012 | Nikon Coolpix L810 16.1-Megapixel Digital...
When i try to turn my camera on it sounds like its going to turn on but it stops and gives me the message on the screen Lens error 111. then it shuts off. I've been messing with it and i can get it to...
Often times a lens error comes up when the lens extension/focus mechanism has been jammed. It may almost fully function, but then the gears run into a small spot where those tiny gears are jammed, broken, have debris on them, etc. When the motor hits unexpected resistance, the camera kicks back the lens error code and shuts down before it does further damage to itself. Make sure there isn't anything wedged between where the pieces of the lens slide past each other. Past that, the best solution I can offer is to look on ebay... most cameras either die because the lens mechanism breaks, or because the LCD screen breaks. If you can find a donor camera with a bad screen, you can combine the best of both at a pretty reasonable price. These cameras are quite complicated to transplant, but fortunately most lens mechanisms and sensors are a full unit of themselves, and so are the lcd screens. Before investing in the donor camera, take yours apart and see how difficult it appears to be to work on it. Then make your decision. Good luck!
Aug 13, 2011 | Cameras
Lens is protruding out of camera. lens error displayed on digital screen. its telling me to restart my camera. how do I do this?
Actually it's asking you to shut it off and turn it back on again. What I would do is shut it off, remove the battery for a few minutes, put the battery back in and turn it on. If it still refuses to operate then it could need the battery contacts cleaned and or the battery charged again.
Jan 07, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
MY DIGITAL CAMERA WILL NOT STAY ON AND THE LENS IS OUT AND WILL NOT GO BACK IN. WHATS WRONG WITH IT
Could be the battery has died on you at an awkward moment, though normally a camera will retract the lens before shutting down. Apologies if you've already checked this but you haven't given much detail.
First step might be to charge the battery. If that doesn't help then before getting a new one you might like to test the battery with a voltmeter. If the battery seems OK then the problem is with the camera and will need professional attention.
Sep 23, 2009 | Sanyo VPC-E760 Digital Camera
Camera is frozen up
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. Note in your case, the second listed fix might actually jog it back into operation:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 01, 2009 | Canon PowerShot A95 Digital Camera
Adding WD-40
gears hang up alot or the lens was banged while out make the lens stay out.. a tiny motor that drives these gears might be bad,
might be a low battery, sometimes other errors make the camera just shut down with lens sticking out, I used baby oil once to free a sticking lense mech but only like 1/8 of a drop.
your problem doesnt sound good and i think you added more.
Dec 28, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Camera will not power up correctly
Again the same old compact camera zoom lens problems - sand in lens, stuck AF motor, chewed up plastic gears...you only have to look at them wrong and they will die... (A very cynical camera repairer that has tried to repair these damn things soo often!!) Even cameras with internal lenses like the old Nikon 950/990/4500 still have troubles with stuck motors and broken lens parts. I despair - these things are just made to last the guarantee out (if that long) and die horribly afterwards!!
Nov 08, 2007 | Canon PowerShot A620 Digital Camera
'Lens Error' message, No activation of lens
i have had the same problem too, have you got ALL the equipment still in a box, because if so (if you have had the camera less than a year) u can report to the vivitar contact thing because that's what i had to do write back
Apr 12, 2007 | Vivitar ViviCam 4345 Digital Camera
Camera turns on and then turns off.
It seems the camera has a lens problem. Probably one of the lens gear is broken or defective. When you try to shoot the lens moves to focus and jams in the middle of the focus so shutter will not release becasue it is not focused yet. There are couple of gears in the gear chain of the lens and it is plastic. the volume of pictures you took might have caused one of the gear to wear down. The solution is to rebuild or replace lens assy. and the cost may be around $100 in US.
Mar 20, 2007 | Fuji FinePix A330 Digital Camera
Lens wont shut completely
hello, as you said lens cover does not shut it means camera is in working mode so naturally it drains the batteries. Actually the problem is in the lens assy. so go to samsung shop. good luck...
Jul 27, 2006 | Samsung Digimax S500 Digital Camera
Kodak EasyShare C180 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
