Question about Sega Incredible Hulk
Problem with fmod_memory_initialize@20 - Sega Incredible Hulk
What Files Will Be Displayed in the Flash Memory in Addition to the Default Startup System Software Package and Configuration File?
After a device is powered on, it initializes the configuration by reading the configuration file from the flash memory. When you run the dir flash: command in the user view, the following information is displayed:
<HUAWEI> dir flash:
Directory of flash:/
Idx Attr Size(Byte) Date Time FileName
0 -rw- 812 Jan 01 2008 00:00:56 private-data.txt
1 -rw- 948 Jan 01 2008 07:16:55 vrpcfg.zip
2 -rw- 90,602 Jan 03 2008 03:58:15 v200r008sph001.pat
3 -rw- 6,418,980 Jan 19 2008 20:19:42 s2700-v100r005.cc
4 -rw- 12,240 Jan 03 2008 04:52:43 $_patchstate_reboot
14,632 KB total (8,228 KB free)
In the command output:
· The private-data.txt file saves service initialization data. Initialization data of some tasks is irrelevant to the configuration and is not recorded in the configuration file. The private-data.txt file records initialization data of these tasks, for example, the number of times the device restarts.
· The $_patchstate_reboot file records the patch status. This file is created after the device runs a patch and cannot be deleted. The file records the status of all patches, for example, the active state and running state.
· The v200r008sph001.pat is a patch file. The file name extension of patch files is .pat.
Sometimes, the flash memory saves a notilogindex.txt file. If a destination host is configured for Inform traps, the number recorded in this file is used as the initial serial number and filled in the Request ID field in Simple Network Management Protocol (SNMP) packets. The system starts a timer when the SNMP task starts and updates the file every 12 hours.
May 10, 2016 | Computers & Internet
Fmod failed to initiliase
You may not have enough memory to finish the game or start. Harddrive space may be the factor also. the game on the cover should tell you how much memory and hardrive it will take. And processor speed you need to play your game.
Apr 30, 2014 | Sony F.e.a.r. 3 Playstation 3, 2011
Fear 3 problem with fmod memory initialize@24
DOWNLOAD fmodex.dll cupy it in C:\Program Files\WB Games\F.E.A.R. 3 and cupy skidrow in the same folder. 834d2ca4-7a77-4db1-83cd-71ac12598d0e.png 6135f1b1-2cf1-45b1-8400-60959250f0e8.png
Jun 04, 2013 | Computers & Internet
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
I can't install some applications/games and my computer always says fmod.dll error.
Due to the fact that your operating system is for some reason missing a critical .dll, rather than going through the lengthy process of restoring it, your best solution is to backup all the files on your computer you'd wish to keep, and do a complete reinstall of your operating system, if the problem continues to occur, you may have malicious software on your system.
Jul 01, 2011 | Computers & Internet
When I turn it on, it is looking for satelites constantly and never locks on to one. I have done the reset numerous times. I have not used this for over a year. The batteries were removed and it was stored...
Since the batteries were removed, the unit loses its memory in 20 minutes so that the GPS now has no idea where it is on the planet or even the time and date.
SO, it likely needs to be initialized.
Here is the owner's manual, initialize procedure is on page 4.
Hopefully this'll get you back on track.
Good Luck!
Apr 30, 2010 | Magellan GPS 310 GPS Receiver
Message memory problem of lll6 model
have the firmware reflash....on the phone so take it to a mobile service center and have it reflashed.
Nov 12, 2007 | Motorola Mobility L6 Cellular Phone
Sega Incredible Hulk Logo
61 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
