.My Keyboard is locked-I cant unlock it.
I am using an HP. 2525 Notebook tablet P.C.. No Keys work at allHow do I unlock the keyboard
  • melwint Mar 11, 2009
    ma hp tablet notebook has the same problem
    i turned on and i cant use the key board to type anything
    Plase help fixing this problem
  • Anonymous Mar 30, 2014
    Unlock the keyboard and mousepadp
Steps to unlock HP laptop keyboard.
1. Turn off the computer
2. Remove the battery.
3. While the battery is out, hold the power button for about 30 secs
4. Put back the battery
5. Turn back on the computer and it should be good to go.
Posted on Jun 03, 2009
My grandson forgot his finger drawing to open the note book.. The e mail we used keeps saying pass word is wrong or e mail...How can I get back in the note book please help.
How do I unlock my notebook? - HP Support Forum - 722697
h30434.www3.hp.com > Laptop & Notebook > Software
Jun 17, 2011 - 4 posts
I lock my computer so my sisters cant go on it. Well one of them had to use it so I gave her the password to turn on the computer and when she ...
how do i unlock my hp laptops keyboard - HP Support Forum
h30434.www3.hp.com > Laptop & Notebook > OS/Recovery
Jan 2, 2012 - 10 posts
Solved: how do i unlock my mothers hp laptop keyboard. ive looked all over the net and the answers i get is to push fn button and an f# button ...
Unlock a password protected PC - HP Support Forum ...
May 23, 2012 - 10 posts
Hello, I am buying an HP laptop at a liquidation auction, but it is password protected. Is there a way to break into it? Thank you - 1524423.
How To Unlock My Computer Or Laptop Password In 3 Easy ...
? 3:47
https://www.youtube.com/watch?v=4zTqum0oIHU
Jan 07, 2016 | Tablets & eReaders
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    The shift keys and ctrl keys on my nc6230 laptop have stopped working. Any solutions?
    Clear temp files and reboot
    If you're using Skype turn off keyboard shortcuts
    Make sure sticky keys are turned off
    Keyboard cable/keyboard may need to be replaced
    Nov 23, 2010 | HP Compaq nc6230 Notebook
    The keyboard is locked
    Dear Sir,
    plz folow this step to unlock keyboard
    1. Step 1 Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
    2. Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
    3. Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
    4. Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
      For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
    5. Step 5 Reconnect the power adapter or AC cord. Start your computer.
    6. Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
    Thanks For Your Time,
    Apr 13, 2010 | Dell adamo PC Notebook
    My computer comes on but my keyboard does not work did i push a button or something
    maybe.. unlock all the keys like number lock in the board.
    if not
    change your keyboards
    if not
    you keyboard driver was corrupted reinstall or repair your operating system
    Jan 21, 2010 | HP Pavilion dv9000z Notebook
    The keyboard is locked, is there an unlock code?
    Try this
    To lock keyboard with filterkeys activate sticky keys by pressing the shift key 5 times. Go to settings and click the radio button 'use filter keys' this locks the keyboard and gives nifty little sounds all except the taskbar button if keyboard has one. easily unlock by double clicking little clock emblem in the bottom right hand corner of screen and deselecting use filter keys. Make sure you hit 'apply'
    Dec 04, 2009 | HP Compaq Presario CQ60Z Notebook
    Can not get keyboard off
    There are some screws under the computer that fixes the keyboard, they often have a keyboard icon near the hole, remove them and make sure you unlock the latches that are holding the keyboard near the Fxx, Caps Lock, Enter keys.
    Oct 27, 2009 | HP Compaq 6730b Notebook PC KR973UAABA...
    Acer Notebook Keyboard is locked
    Just hold down Fn then press F7 or F8 keys to unlock keyboard.
    Good luck.
    Aug 14, 2009 | Acer Aspire 4315 Notebook
    Laptop keys locked how do i unlock them
    try going to control panel>administrative tools, find the keyboard, double click it, and click "enable"
    Apr 02, 2009 | HP Pavilion zd8000 Notebook
    I have a HP Pavilion TX 2000, PC Tablet & the keyboard locked ((
    just see the option is given on your laptop keboard for locking and unlocking .
    Mar 14, 2009 | HP Pavilion zd8000 Notebook
    Computers & Internet Logo
    2,269 people viewed this question
    David Payne
    David Payne
