Question about iLO 3200 32 in. LCD Television
MTS keeps switching...HELP!!!!
My Ilo tv keeps switching between Mono and Stereo and SAP without me doing anything! It is SOOO irritating, can anyone tell me how to make it stop? Thank you so much! Jessica
  • 1 more comment
  • jvietri Dec 28, 2007
    Same thing.. HELP!!!!!
  • Jessica Kinney Apr 23, 2008
    I was previously using my ILO tv through my Charter Cable box. Since I've moved my TV into my bedroom, without a cable box, it no longer switches between the mono and sap. (knock on wood)
    The tv no longer switches between mono and sap, but the sound quality is bad. It sounds static-y all the time and now "pops" instead. Next time I will spend the few extra dollars to get a quality tv from a company who offers a warranty. Good luck to you.
Same here.....just bought the tv too..Let me know if you here anything.
Posted on Jul 12, 2007
Any Luck???
Posted on Apr 21, 2008
SOURCE:
Under the channel it says SAP and no sound comes out on some channels,on other channels its says stero and works fine how can i fix the problem
I found this information in the manual, and perhaps it will help:
1 Switch the audio.
• Every time you press [AUDIO], the audio will
be switched as below.
MAIN : Outputs main-audio
SAP : Outputs second audio channel
MONO : Outputs mono-
Also the manual says this about SAP:
SAP
(Secondary Audio Program)
Second-audio channel delivered
separately from main-audio channel.
This audio channel is used as
an alternate in bilingual broadcasting.
Here is a link for the manual, in case you want to go over the settings. I'm thinking this is a setting problem in the menu, but it can be a physical problem with a cable line.
http://dukeelectronic.com/Manual/IWT3206.pdf
Of course it could also be a trickier problem, but check your settings, check the cable line with another TV if possible, and then contact ILO Support for help, in the event nothing fixes it.
Good luck, and hope this helps.
Dec 01, 2010 | iLO IWT3206 TV
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
I've been having this audio issue with my LG 19LG30 for awhile now. Only recently discovering what exactly was going on. My audio would go in and out on some channels. There would be sound then muted for a...
to eliminate the problem just select the mono sound disable the stereo signal.so that your tv sound will be stable.this happens because not all tv stations are broadcasting on stereo signal thats why your tv keep on switching to mono and stereo base on what signal it receives.plus the signal being feed by the cable provider sometimes they are not stable enough to give the stereo signal so better select only the mono sound...tnx hope i helped you..
please rate my help!
Jun 05, 2010 | LG 19LG30 19 in. LCD HDTV
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
How can I turn off SAP?
if you are using a digital TV is is possible that the frequency is slightly out or you have poor reception.
do a new channel serch first (automatic if you can
and see what happens
sap may reset also if you do this function.
May 05, 2009 | iLO Televison & Video
Mono stereo sap on screen
you need to reset the preferences on you sound icon in the menu panel
Mar 26, 2009 | iLO 3200 32 in. LCD Television
ILO sound quality
Had a similar issue and turns out I had accidentally switched my language pref to SAP rather than English. As soon as I changed it back, everything was fine...
Aug 10, 2008 | iLO 3200 32 in. LCD Television
MONO - SAP
In the audio menu, you should be able to select stereo or turn off sAP -- you may have to unplug the set for about 20 seconds and restore power to reset it, or return it if the problem doesn't go away. If you end up replacing the set, try for a JVC, Panasonic or Toshiba if you can switch. I think they will last longer for you.
Jan 09, 2007 | Akai LCT2701TD Television
iLO 3200 32 in. LCD Television Logo
208 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
