Did samsung sw50v3 have drain pump - Washing Machines
2 Suggested Answers
  • 12962 Answers
SOURCE: My samsung washing machine model SW50V3 showing dE error after its full of water, its not spinning at and even not draining as well, plz help thank you.
Did you go to Samsung site and inquire re the significance of the DE error?The machine is telling you where the problem is. Use the info and check it out.
Posted on Sep 17, 2017
Samsung dishwasher not pumping water out. "delicate" light blinking and it doesnt appear the pump even tries to come on. the machine just stops after wash cycle then I get the error light.
The Delicate light flashing on Samsung dishwashers indicates a drain error. Possibly a pump/motor assy.
Samsung Dishwasher Not Draining
Doesn't sound like a clogged ECS because it's not draining at all.
Jun 12, 2017 | Samsung Dishwashers
I need to find the reset button. It will not drain. This has happened before but I can't remember where the reset button is.
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
Jun 24, 2015 | Samsung Washing Machines
I have a Samsung 8kg top loader and had to change the drain pump. The new pump just runs constantly while the power is on.
The old drain pump has taken the control board out with it & it's now stuck in the drain pump cycle. You will need to replace the main pcb to fix this one.
Jun 15, 2015 | Samsung Washing Machines
Samsung dishwasher starts and after while stops with three lights cycles on (heavy , normal and quick)
I think that light combination means "Drain error". Most comonnly caused by something hard getting down into the drain pump, blocking or partially blocking the drain pump impeller or the check valve inside the drain hose right next to the drain pump.
Feb 24, 2015 | Samsung Dishwashers
5e or se code on samsung dishwasher
The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose check out okay.
Sep 07, 2014 | Samsung Dishwashers
User manual for samsung sw50v3
Please check this link for support : user manuals
Jan 11, 2013 | LG WM3885HCCA Washer
Not spinning or draining Samsung front load wf206ans/xac
Won't spin if it hasn't drained. Most probably a blocked/jammed pump impellor. Manually drain it from the lower drain pump (by side tube if that model has one, or slowly into a shallow pan. Remove cap completely & check for things jamming pump.
Dec 12, 2009 | Samsung WF206ANS Front Load Washer
My washer (samsung WF203AMW)does not drain. what should I do?
there may be something stuck in the drain pump.you need to remove the hoses from the drain pump and look in there and see what is stopping the pump.
Sep 25, 2009 | Samsung WF203ANW Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
