Question about Electrolux Washing Machines
Electrolux ewx14450w washer/dryer heating element gone can i still wash with m/c
Waiting for replacement heating elelment for dryer .can i still use the machine just for washing
  • 1462 Answers
SOURCE: Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
Posted on Apr 19, 2007
  • 209 Answers
SOURCE: Heating element Zanussi washing machine
remove the back, the element is at the bottom of the drum tis maybe a split cabinet, where the lid comes off the it splits down the middle like cracking an egg, loads of screws, hard to describe, also 2 at bottom at the side in the middle, behind 2 plastic lugs, when removed the back half of the cabinet comes away, not an easy job until you have seen it done if you really are stuck try and send me an e mail address and i will send you a drawing, then you will see its easy, i am an engineer of 20 years and done loads, its easy job to do once you know how to split the cabinet
Posted on Oct 07, 2007
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
FitzOriginal
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
JAN_yuanjia
  • 470 Answers
SOURCE: Electrolux EW 1005f washing machine trouble.
try to go for the technician of washing machine, cuz you have the chance to replace it by replacing another board by there old unit that available and compatible to your washing machine
Posted on Mar 31, 2009
WE are having problems with our EWX14450W Washer Dryer. It either runs but does not dry or stops with an E10 error. This apparently to do with the water tap But I cannot see any problem with it.
If not drying properly you may have a clogged vent issue. Or the heater element is open. Use continuity meter to check.
Replace if open.
Sep 03, 2017 | Washing Machines
My washing machine model no ewf 1421,is writing e60,why
Insufficient heating measured by the main board during washing cycle and also during drying cycle at washer-dryer.
Could be faulty: heting element, pressure switch, NTC sensor, printed circuit board (PCB),
wiring between PCB - heating element,
wiring between PCB - NTC sensor,
wiring of pressure switch.
Dado
Nov 20, 2014 | Electrolux Washing Machines
My washing machine just turns white light on display but nothing to display and white background light also comes when i turn it 2 times on n off
Good Morning Friend,
I understand you are having trouble with the display on your Electrolux washer, model# EWX14450W. In researching your model number, I have determined that it was manufactured in the UK. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction for having your display repaired. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux Washing Machines
HOW DO I CHANGE HEATING ELEMENT ON MY ELECTROLUX DRYER?
You might try this step by step process. It is not for Electrolux, but the process should be similar. Changing the Heating Element
Apr 08, 2013 | Electrolux EIED55HMB Electric Front Load...
Electrolux Dryer Heating Element 131553900 is this the right one for model #fex831cs0 or can you restring the original if so what is that part Number
Hi L Martin - For this particular model FEX831CS0, the heating element part number is 131475320. The part may be purchase directly from the manufacturer or through a part distributor in your area.
Mar 18, 2013 | Frigidaire FEX831CS Top Load Stacked...
My whirlpool gas dryer is no longer heating. Could it be a fuse? Or more likely an elelment?
gas dryer does not have an element
it could be the one of the thermal fuses that has gone bad as well as the ignitor. if the ignitor is not pulling enough current it will not open the gas valve in order to light the gas.
Jul 05, 2010 | Whirlpool LGR7646E Dryer
How do you expose the heat element
Take of back of unit, unplug first. Heat element is near heat duct side with wires attached to it. Unscrew and slide it out. You could also put a tester to each wire to see if you have a complete connection. If ok check thermal switches, one could have gone bad.
Aug 17, 2009 | Maytag MDE308DAYW Electric Dryer
Indesit washer dryer, washer is fine, but dryer does not heat up
If you don't hear the fan running then the fan motor has gone bad. If the fan motor is bad then most likely your element has burned out. If you hear the fan motor than probably your element has gone bad..
Jul 29, 2009 | Splendide 2100 Vented Washer-Dryer
Washing Machines Logo
78 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
