Question about RCA VR629HF VHS VCR
VCR POWER ON PROBLEM
Need some advice on a vcr (power supply ?) problem, sure hope you can steer me right on it.
It’s an RCA model VR633HF, four head, nearly 8 years old. For over a month now, when I
try to turn it on (with a recording tape in the carriage) with either remote or the on/off switch, it begins
to bring the carriage up to the drum, then abruptly stops, upon which the LED display starts flashing,
with a ‘tick-tick-tick…’ sound occurring, synchronized with the LED flashes. It does this for some
3 – 5 minutes (no controls will stop it), then stops and shuts the unit off. Usually, if I turn it on again,
it starts, and every thing is normal, but sometimes I go through this THREE times to get the unit
on. When it does come on, the LED flickers a little, and the clock time must be reset. Strangely, with
a pre-programmed recording, it powers on fine, and the program is recorded, however, it still screws
up the clock after. I have tried pulling the plug (reset the cpu) several times, to no avail.
I asked a local service tech here about this problem, and he told me it was a defective power
supply ( the SMPS type), but didn’t tell me what in the circuit to look at. I don’t have the schematic/
service manual for the unit, I do have a DMM. Later I was told that the power supplies in these units
are enclosed and plug in to the main board, and from reading online, that the problem could be with
leaky/shorted diodes or filter capacitors in the rectification part of the circuit.
What specific components are defective here, and could you give me an idea what the circuit looks like,
so as to locate the parts, etc. ?
Thanx loads for your time, patience and help in this,
Chris Curran
    Problem Solver:
  • 15 Answers
On vcr power supplies usually first component to go is a capacitor, check if its blown, or test it if you have a meter capable, next check diodes and resistors, also check the resistors and diodes on all the boards( they may have blown if a cap has blown) If there was smoke or a smell its usually a resistor to look for. When you replace them replace them with a higher votage cap.. Example 15v 1000uF cap with a 25v -35v 1000uF cap( this is just to avoid the problem from happening again.
Posted on Feb 01, 2009
SOURCE:
We have a RCA VCR Model VR622HF Manf. 9-18-98 that suddenly won't turn on manually OR with remote. I am an experienced Electronic Tech with 43 years @ ATT. I measured the resistance at the AC Plug and read...
If front display lit up when vcr plugged in that means power supply is working and issue is in system control section, and if front display remains dark while vcr plugged in wall socket then power supply is defective.
As you know its an old model vcr so I do not think spare parts would be available any more, I found good option for you to fix this vcr.
Click eBay.com link to get same vcr in working order for $40 that can be used to obtain either power supply or any other board/ parts to repair your vcr.
Hope these info will help you.
Thanks.
Dec 14, 2010 | RCA VR622HF VHS VCR
I do not have power but I verified int incoming to the board and the fuse is good. Where is the power supply circuitry
the power supply starts at the plug and, extends along the edge of the vcr to the front; it has a heavy line and, the word: "hot" printed on the circuit board; separating it from the "cold" DC side of the VCR circuit board.
Jan 16, 2010 | RCA VR701HF VHS VCR
My combo DVD/VCR DRC8335 will only display HELLO and not respond to the remote or buttons on the face. I have tried the troubleshooting portion of the manual and need help.
I have an rca drc8335 vcr/dvd player that is locked. I have the code to unlock it, but don't know where to post the code. Can you help me?
Dec 12, 2009 | RCA DRC8300N DVD Recorder/VCR
Will not come on
RCA DRC8320N DVD Recorder/VCR
Symptoms:
Seems to have no power, no lights on front lit, if listened to closely one may hear a "click click click" sound.
Solution: Replace C232 on power supply board.
Additional technical info:
In this design, the switching power supply feedback is from the 5 volt standby rail only, which is odd. The problem is caused when C232, the first filter capacitor in this rail and the sampling point for the feedback circuit, opens. The clicking sound is transformer rattle as the power supply restarts repeatedly.
Aug 03, 2009 | Televison & Video
RCA VCR makes high pitched whining noise when it's on...
The power supply is starting to fail. There are a number of capacitors in the power supply that need to be replaced. A local repair shop should be able to fix this easily. Figure on $10 max for parts.
Dan
May 05, 2009 | RCA VR508 VCR
Drc8320n vcr dvd combo says hello and pls wait over and over again.
Replacing a simple capacitor on the power supply just brought my unit back from what I thought would be the junk pile....
Read this.
Yes you can do this yourself....
http://forums.afterdawn.com/thread_view.cfm/707232
Jan 26, 2009 | RCA DRC8300N DVD Recorder/VCR
NO POWER ,MAKING A TICKING SOUND IN POWER SUPPLY
This is a sure sign the power supply needs replaced and is damaged!
Replace power supply and all should be fine again!
PLEASE rate my response to your question!
Thank
You!
Jan 07, 2009 | Zenith VRB420 VHS VCR
RCA DVD/VCR model DRC8320
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
VCR says safe
Hello. Have you tried unplugging the power from the VCR for more than 24hrs? This may resolve the "safe-mode" feature going back to "default" and permit regular use after this amount of time elapses. That is kind of unusual for the stepping upon the remote to cause this?
Jan 22, 2008 | RCA VR637HF VHS VCR
Televison & Video Logo
143 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
