Moter is not working - Washing Machines
  • Washing Mach... Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jan 11, 2013
Moter turns over but wont start. and windos stops working after moter start.
02 ford/?
wont start, then starts. im confused.
check all fuses. first.
Dec 18, 2013 | 2002 Ford Explorer - XLT - Speed Grille
Auto 4 wheel drive will not engage. Just a clicking sound in right front panel
it sounds like u are getting power [the clicking is the relay]ur next step would be to go under the truck and find the moter on the transfer case .have someone engage the 4x4 and listen for the moter working.if not uplug the harness and see if u have power there when ingage or disen gage the 4x4 .if u do then it is most likely the moter or the spline on the moter witch then u have to remove,to check
Jan 22, 2011 | 1994 Ford Bronco
My 4wd stopped working ...any ideas....when i hit the button for either auto 4wheel or 4wheel hi the lights on the buttons just blink and it never goes into 4wd just eventually the light goes back to 2...
check the fuse for transfer case shift moter if thats ok
check the connections at the moter then have someone push the button while use a test light or
meter to check for power if you have power at the
moter and it makes no sound odds are bad moter
Jan 11, 2010 | 1999 Chevrolet Blazer
Will fill up with water but will not spin and just makes a buzzing noise?
there are two possible problems one the lid switch might be broken there is a small tab front right corner of lid that goes down into a hole to operate the switch which i beleive is still good because you can hear the moter hum there is a drive coupling between the moter and transmission if you lean the machine back you will find black rubber debries in the middle toward the front of machine before taking apart unplug from power the pump has two clips that hold it on top of moter there are two screws in two clips that hold the moter to a metal plate next to transmission the wiring harness plugs in to side of moter the drive coupling can be worked off gently with a wide screw driver from moter and transmission each plastic piece has three
pins that line up and fit into a hard black
rubber center the trick is lining it back up and clipping the metal supports back on moter i normally clip the top one back on first gravity assist with correct placement of moter to reinstal bottom clip reattach wiring harness two screws in moter clips reinstall pump will probably have to turn moter shaft to align with pump reinstall pump clips
Dec 07, 2009 | Roper RAS6233KQ Top Load Washer
Washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Jul 29, 2009 | Washing Machines
The engine wouldn't turn over.
check the battary make shore theres plenty of life in it , if that doesent work make shore the starter moter is not jamming, if the stater moter is jamming try to krank it over mannualy that will free the starter moter , and then it should turn over . if it does then your starter motor is the problem
Jun 22, 2009 | 2004 Dodge Durango
Canon NP6050
The E510 is a sorter feed moter problem moter (M1) You can see if the sorter moter turnes if it does not,replace it
If you want a quick cure to get you copying disconnect the sorter remove the communications lead you have to remove the sorter completely and the copier will work.
Thank You
Mar 11, 2008 | Canon NP 6050 Copier
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
