Question about Dual Pro2- WM795V Channel VHF Wireless Microphone Microphone
Pro. 2 WM-795V Wireless Problems
When I sing loudly into the microphones, the speakers make a loud, static noise. Any idea why it does that? Is there any way to fix that?
  • sq6348 Jan 22, 2009
    I disconnected right and left front speakers, the noise front the rest three is less. Any idea?
    I disconnected the front right and left speakers, and the noise from the rest of the three speakers is less. Any idea?
  • 79 Answers
The mic volume is to loud. Turn it down a little.
Posted on Jan 22, 2009
Loud speaker static when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to get it to stop. Any ideas?
I GUESS that the speakers are driven by an after market amplifier. An amplifier needs to be connected to a power source that is only on when the radio is on, through a relay.
So I GUESS that:
  1. The wiring is incorrect. Or
  2. If is has a relay, the relay is stuck.
Feb 01, 2015 | Cars & Trucks
Static crackling sounds
Replace the speakers or let it be repaired by some one.their may be rust near the speaker coils.just giv it a try.
Nov 20, 2013 | Yamaha Music
As soon as the toshiba a200 boots up there is a loud static noise in the speakers.It does not stop making the noise. The problem started 2 months ago when adding an audio file into powerpoint
you should check the configuration of the microphone and see if the volume is very high which leads to feedback with the speakers and produces the squeak
May 24, 2010 | Toshiba Satellite A200-0ET00X Notebook
My rear wireless speaker from one side is making a loud noise.
the problem is the transmitter. it is generating undesired signal. in all wireless communications if the transmitting end creates oscillations other than which is desired - they are termed noises. ur receiver unit happens to pick up one of those noises and is able to amplify it. a qualified tech will be able to identify the frequency range and filter that out on the transmitter stage. if the warranty covers it- replace!
Mar 12, 2010 | Panasonic Audio Players & Recorders
Logitech speakers occasionally making loud thudding noise!?
i have the same problem.... its very annoying, i cant get it to go away!
Apr 19, 2009 | Logitech SoundMan Pro Computer Speakers
My webcam works fine but the microphone crackles all the time
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Feb 01, 2009 | Logitech Webcam
Inspiron 1505 speakers
The static noise may be a defect. If your laptop is still under warrent, contact dell for a warrenty replacement. I had the same problem with my inspirion. Sigmatel
Jan 24, 2009 | Dell Inspiron 6400 Notebook
Very Loud Noise When I am playing Back my Video
could be feed back make sure microphone is as far away from speakers as possible
Jul 17, 2008 | Logitech Webcam
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Loud static
Verify that your microphone is configured correctly loadTOCNode(2, 'resolution'); 1. In Windows Live Messenger, if you cannot see the menu, click Show Menu. 2. On the Tools menu, click Audio and Video Setup. 3. Click Next two times. On the Microphone page, verify that the correct microphone is selected on the Select the microphone you would like to use drop-down list. Speak in a typical tone of voice, and then verify that the voice meter moves up and down correctly. 4. Click Next, and then click Finish.uparrow.gifBack to the top
Verify that your contact's speakers are working correctly loadTOCNode(2, 'resolution'); To do this, have your contact follow these steps: 1. In Windows Live Messenger, if you cannot see the menu, click Show Menu. 2. On the Tools menu, click Audio and Video Setup. 3. Click Next. On the Speakers page, verify that the correct sound system is selected on the Select the speakers or headset you would like to use drop-down list. 4. Click Play Sound, and then verify that you hear the sounds correctly. 5. Click Stop Sound. 6. Click Next two times, and then click Finish.
Jan 02, 2008 | Microsoft LifeCam VX-3000 Web Camera
359 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Michial Gueffroy
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
