Question about Lexmark E232 Laser Printer
Paper jams no matter what stock I use; Lexmark e232
The paper is continually jamming no matter what stock I use.
I once came across a ''self cleaning'' (or similar) process but can no longer find it.
Someone suggested cleaning the rollers, but I can't find rollers for this printer.
Help
  • Lexmark Master
  • 684 Answers
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer....
Good Luck
Posted on Jan 22, 2009
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Hi, My Lexmark E232 printer is on but will not print. The light second from the bottom is orange. Help!!
That second from the bottom orange light indicates a paper jam. Press Continue to resume printing once all the jammed pages are cleared from the paper path. Press Continue twice quickly to see the secondary error code. See "Secondary error codes" on page 69 of the user manual for more information.
Here's a link to the manual: http://www.lexmark.com/publications/pdfs/e230/eng/ug.pdf
Mar 21, 2011 | Lexmark E232 Laser Printer
Slipping paper feed rollers is probably causing the jamming. Remove the paper tray and tip the machine back so that you can access the feed rollers from underneath. A good technique to isolate this problem is to remove the rubber feed tires, turn them inside-out and refit them. If it now works OK you need to get new feed rollers.
Jun 01, 2009 | Lexmark E232 Laser Printer
Paper jam light is continually on and I can't reset.
Did you check for jam in the back (open rear door maybe jam is there)?
Mar 26, 2009 | Lexmark E232 Laser Printer
Paper continually jams
What is the error code from page 69 and 70 of the E-232 manual?
Here is the webpage to download anything that you may be missing. The manual has a very complete section on complete clearing of jams.
http://search.lexmark.com/printer/US/en/22S0200
Dec 22, 2008 | Lexmark E232 Laser Printer
Frequent jam in Lexmark E232
This can happen a lot if you're using very light weight paper.  Also, if the paper is not flat it can jam up too.  Best thing you can do is get yourself some higher quality paper and keep it in a air tight tub after you open it.
Nov 22, 2008 | Lexmark E232 Laser Printer
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Aug 22, 2008 | Lexmark E232 Laser Printer
Lexmark E232
oh my GOD ,PLESE OPEN ITS ELECTRONIC BOARD AND REINSTALL IT PROPERLY
Sep 19, 2007 | Lexmark E232 Laser Printer
Printer jam
There is an easy fix for Lexmark E232 paper jams at the beginning of the paper path. This fix only works when the problem is that the paper starts to feed, but does not quite make it out of the paper tray.
The problem is the pickup paper rollers. If you remove the paper tray and press down on the paper indicator (the red lever to the left of the paper tray) you can see the twin rollers attached to a spring loaded armature.
Chances are these rollers are worn and are very smooth to the touch. This slick smooth surface does not have enough friction to push the paper up to the next roller.
To fix this, remove both rollers, they slide off easily. Then simply turn both rollers inside out and replace them on the armature. Notice how much "stickier" they feel now? Chances are your paper jam problems are over, until the rollers wear out again.
At that point you will have to replace them.
Mar 30, 2007 | Lexmark E232 Laser Printer
Lexmark E232 Laser Printer Logo
162 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
