Question about Toshiba MK2565GSX Hard drive 250 GB internal 25 SATA300 5400 rpm buffer 8 MB SATA II
Oshiba MK2565GSX Hard drive device driver - Toshiba MK2565GSX Hard drive 250 GB internal 25 SATA300 5400 rpm buffer 8 MB SATA II
  • Toshiba Master
  • 7,627 Answers
For what computer?
Posted on Jan 11, 2013
Toshiba MK326GSX hard drives issues
Start computer while holding or tapping the "F2" button.Screen will come up to set the BIOS password.Read all carefully,clear the passwords that were placed,and then you won't need a password.It's blank.Don't fool with any other settings,you'll screw something up and NEVER get in.Just change the screen untill you come to the password settings by using the directional arrows on lower right of your keyboard.Regards,Rigger.
Apr 14, 2014 | Toshiba MK2565GSX Hard Drive MK2565GSX
Security password
If the hard drive has a password and you don't know it there is nothing you can do.
Jan 25, 2014 | Acer Aspire One Netbook
My Toshiba satellite with a mk2555gsx won't boot up no messages, tried recovery discs to no avail.
SMART FAILURE PREDICTED on HARD DISK 2: TOSHIBA MK2565GSX-(S1)
Warning: Immediately back-up your data and replace your hard disk drive.
Press F1 to continue.
What is that problem?? and how to troubleshoot this my computer, the model is neo M1110 noteboke.
Sep 10, 2013 | Toshiba MK2555GSX 250GB SATA/300 5400RPM...
My laptop stopped working so I removed Toshiba MK2565GSX hdd and I have a usb to sata/ide adapter connected to the hdd but it wont power on and the motor isn't spinning. I have important videos on their...
ur toshiba hdd is ur laptop's primary hard disk, so it is not booting from external hard disk, so open bios in ur laptop and set booting with usb as primary booting device, it works, if u have more doubts post me again
Aug 06, 2013 | Toshiba MK2565GSX Hard Drive MK2565GSX
My Toshiba Satellite C645D-SP4007M was working fine. All of a sudden it does not recognize the HDD. I get a message saying no bootable device. I tried with the recovery disks that came with the laptop, but...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
hope this helps you
Sep 17, 2011 | Toshiba MK2565GSX Hard drive 250 GB...
I have problem I need password for TOSHIBA MK2565GSX..THX
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 21, 2011 | Toshiba MK2565GSX Hard drive 250 GB...
I need the driver for iomega hard drive usb 2
The device does not have propitiatory drivers. The device uses Windows or Mac generic drivers to run the device.
Dec 09, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
How do you get the simpletech external hard drive to store information, and how do you know when it is stored?
Plugging in a USB device before installing the driver disk is the most common USB mistake people make.
An external hard drive, driver properly installed, looks just like a normal hard drive in 'My Computer'. Use it like a hard drive.
If you cannot see it in My Computer when it is plugged in (Go ahead, unplug it and reconnect while My Computer is open) then the driver is loaded wrong. A wrong driver needs to be removed with 'Device Manager', the USB drive DISCONNECTED, the driver reinstalled and the device plugged in at the end or when it is asked for by the installer, not windows (unless it does not have an install disk)
Poof, you can see the disk as a hard drive in My Computer.
See 'Device Manager' on the Internet for help with this.
Mar 20, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a oshiba laptop. The touch pad does not work. What do you suggest to fix it ?
please see in ur device manager there is touchpad device it shows or not if not then please install drivers for touchpad from supplied dvd with toshiba laptop
May 05, 2008 | Computers & Internet
PC Does not recognize HDD
there is a complict device driver in the device manager. .. configure device manager and remove an auknown device driver especially the usb device and restart the computer
Mar 08, 2008 | Beyond Micro Mobile 80 GB USB 2.0 Hard...
Toshiba MK2565GSX Hard drive 250 GB internal 25 SATA300 5400 rpm buffer 8 MB SATA II Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
