Question about Linksys Wireless-G WRT54G Router
My router isnt sending signal to my printer
Printer will work only if cable is connected. When disconnecting cable and trying to print error screen appears that says printer offline.
  • 78 Answers
If u can describe about ur network. n is there wireless device like laptop or pc is connected to the router n working .let me know that much
Posted on Jan 22, 2013
  • Anonymous Nov 27, 2013
    Dont worry of any thing just call linksys technical number that is 1855-219-3333
  • 7,627 Answers
The router doesn't send signals to a printer. The Linksys transmits a radio signal recieved by the wireless adapters on other devices, if your printer has wireless compatibility it must be setup on the printer, in the wireless settings. I don't think it's a Linksys issue. It a computer software issue. If you post the Computer Make, Model, and your OS, the Printer Make, mode,l I will try to help you. Is this the first time using the Printer?
Posted on Jan 11, 2013
florenn
  • 174 Answers
SOURCE: cant get to internet thru linksys etherfast cable/dsl router
i you restart you devices, modem and router...
first turn off the modem and then the router and last will be the computer
second if you will turn the devices on...
first turn on the modem,wait until the dsl light becomes solid
second turn on the router,wait for a minute and
third turn on the computer.
check the wireless settings for your router and save changes
next, try to check wireless connection by disabling the local area connection (LAC)
Posted on Nov 09, 2008
  • 31 Answers
SOURCE: 321 error
try this power of both pc and router , unplug router power on pc then power on router see if it then picks up the isp, if not just simply unpup router and plug it back in while pc is running hope this helps!!!! good luck
Posted on Mar 23, 2009
  • 108 Answers
SOURCE: When I try to connect my router to my laptop, the
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Posted on Jun 07, 2009
govinda123
  • 2260 Answers
SOURCE: Every time I connect router I lose internet
If your computer is able to go online through the
modem, that means the modem is working fine.
This router WRT160N hs firmware issues.
Try to upgrade the firmware of the router.
Is there any computer connected to the router with
the cable.
If not then you will need to connect the computer
to the router.
Download the firmware of the router from the
manufacturer's website.
enter the model number. select proper version
number and download the firmware of the router.
Once you download the firmware, you will need to
open the router set up and upgrade the firmware of
the router.
After upgrading the firmware, it is recommended
that you reset and reconfigure the router.
Click Here for more information about router and
networking
Posted on Feb 27, 2010
router-user
  • 550 Answers
SOURCE: my router isn't sending a wireless signal.
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Jul 21, 2010
How to troubleshoot HP Printer not found during network driver setup issue in Windows Operating system?
Download the full feature software from the HP website or on the software disc and setup your printer for wired or wireless network connection.
There might be one of the following errors if the installer does not detect your printer after setting the connection type.
1.Printer not found
2.Devices not found
3.Unable to find the printer
During the Hp printer network setup, there may be some troubleshooting issues,
Step 1: Reset or restart your computer, HP Officejet printer and the router
1.Disconnect the power cord outlet from the router.
5465_install_1a-ur23imwvkexuk45mistkg3hp-5-0.gif 2.Close all the tabs running on your computer and shut down your computer.
3.Then turn off the HP Officejet 4650 printer.
4.After few minutes reconnect the power cord outlet to the printer and wait till the connected status light blinks to normal.
5.Then turn on the printer and computer.
6.Again install the HP driver and software.
Step 2: Check the status between the printer and the network connection.
Before the setup confirm that your printer is ready.
1.Wireless Network: On the printer, open the wireless network connection settings menu and check whether the wireless signal is turned on.
2.Wired Network: Check that cable is connected to the printer Ethernet port.
Note: The green light should be in steady status and the orange link should blink when the cable is connected and make sure that your HP printer is not connected to a guest or host network.
1.Set the band to 2.4GHz if it is dual band router else the printer cannot connect to the network.
2.Check the network name and status of the connection in the notification bar.
3.If it is a different network then reconnect your network to complete the setup.
4.Move the computer and HP Officejet 4650 printer closer to the router if the signal is weak.
5.Slide the Airplane mode to off if it is on.
6.And again try installing the software and driver.
Step 3: Run the HP Print and Scan Doctor:
1.HP provides a free tool called HP Print and Scan Doctor to resolve the scanning and printing issues.
2.Download the HP print and scan doctor software to resolve all the troubleshooting issues.
3.After the installation on the Welcome screen click start.
4.A new menu box appears on the screen with the printer list. If your printer is not listed then turn on the printer again and connect it.
hpscanprinter-ur23imwvkexuk45mistkg3hp-5-2.png 5.Click the option my product is not listed and then select retry.
6.After that, your printers display and select it.
Step 4: Temporarily disable firewall software.
If the firewall software is installed on the computer that will help you to block the threats that found on your computer.
Use the print and scan doctor to identify and temporarily disable firewall software on your computer.
1.Click network on the print and scan doctor window.
2.A drop down box appears in that select the option troubleshooting firewalls.
3.Click the firewall software to disable it.
4.And install the HP driver and software.
If the HP driver is successfully installed then consult the firewall software support to change the settings as security level, trusted zones. After changing the settings re-enable the firewall software.
If the HP driver is not installed then there is no issue in firewall software and re-enable it.
Step 5: Uninstall and reinstall the HP drivers and software.
1.Disconnect the cable if your HP Officejet 4650 printer is connected to the USB cable.
2.Click programs and features in the search windows.
3.A list of installed programs will be displayed click your printer name and uninstall it.
4.Then follow the on-screen instruction to complete the process and restart your computer and reinstall the software from the official site.
If you still have doubts regarding this setup you can call us @1-800-836-3987 or visit us 123 hp setup oj 4650
Jul 06, 2017 | HP Office Equipment & Supplies
How to fix 49.2fa7 error
Try again with out connecting network cable or usb cable . If the message does not come on, you have a bad job trying to print each time the printers signals the network it is ready. You need to delete the bad job. Sometimes you can keep the network cable disconnected until it comes to ready and then plug it in and keep hitting the cancel button in attempt to cancel the job, but most times you need to delete the job at the computer or server which is sending it.
Dec 24, 2015 | HP COLOUR LASERJET CP4525DN Printer
Why won't my Epson 280 printer work?
Try new / different cables. If wireless, make sure to follow all of the connection instructions to your router.
Aug 19, 2014 | Epson Office Equipment & Supplies
Hp color lj cp4025 error 49.2fa7 code how to clear
see
HP color LaserJet cp4525dn error 49 2fa7
suggestion.
Disconnect the network cable or usb cable and try again. If the message does not come on, you have a bad job trying to print each time the printers signals the network it is ready. You need to delete the bad job. Sometimes you can keep the network cable disconnected until it comes to ready and then plug it in and keep hitting the cancel button in attempt to cancel the job, but most times you need to delete the job at the computer or server which is sending it.
Jun 23, 2014 | Office Equipment & Supplies
Hi there, i got a usb air card for my laptop and i want to send out a signal to my belkin wireless router (with a cable) so that it can send out a wireless signal and be able to put my wireless printer on...
Sure, I can help. First off I need to know more information. Are you planning on connecting the printer, through USB, to your laptop then sharing the printer from there to other computers? If so, it is a matter of adding that printer, going into the printer properties, sharing tab, and sharing the printer. Or are you trying to share your printer wirelessly? If so you may need to buy a wireless print server. It acts as a base to share that printer and then allow you to wirelessly find it and connect. If the above doesn't help please tell me the make and model of your printer, laptop, and wireless router.
Best, -Mind
Aug 03, 2011 | Belkin (F5D7230-4) Router (587009)
Got error of "PC cannot send datga to printer. Please check power
my printer, I got error of "PC cannot send data to printer. Please check power and printer cable connections and retry printing". Please help me.
Apr 02, 2009 | Sharp AL-1642CS Copier
Connecting wi-fi on Epson SX600FW
I hada the same problem. I used the settings on the actual printer rather than through the software to input the information it needed and It works fine now. I was able to set it up on my husbands laptop without any problems, I just added his laptop through installing the software on his laptops as it had picked up the signal and was showing in the Network and sharing centre on Windows Vista premium. Hope this helps. I think you need to take the wire out now and now load it as wireless. You need to use the wire first to connect then take it out to connect to the wirelss network. My router is a Sky router.
Tiptap
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
"The process mdns stopped unexpectedly..."
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Are these printers connected with a LAN cable directly to the router, or are they wirelessly connecting to the router?
HP C8180 has built in wireless adapter and Ethernet according the Website at HP.
If this is connecting to the network wirelessly, check to see that it is connected to the Network, is your router using secure passwords for a connection to the network,
Your printer will need these passwords just as your computers would
If you connect the printer with a Lan Cable, it will be more reliable, and shouldn’t need a password to be on the network. And makes life a little easier...
Your internet provider has nothing to do with your Printer not printing; this is an Internal Network Problem. The settings or your network has changed.
The Printer should have a static IP address
Here is a link to a tip I put together about this subject,
http://www.fixya.com/support/r1173875-network_connected_printer_not_printing
If you need any further assistance, feel free to contact me...
Oct 26, 2008 | HP Photosmart C6180 All-In-One InkJet...
How do i hook up a westell router to a moterola comcast modem?
Okay, well something is obviously wrong.
This is how it should be connected. Internet to modem, then with an Ethernet cable, connect the modem to the router (jack1) then with another Ethernet cable, connect the router (jack2) to the computer.
If you are still having problems, then contact your company to see if they could walk you through it, or if they needed to set things up.
Also, where are you connecting your laptop from? Is it very far from the router? Perhaps your router's signal strength isn't great enough? (This would mean getting a new, more powerful router.)
Jun 13, 2008 | Westell Wirespeed VersaLink...
Linksys Wireless-G WRT54G Router Logo
67 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
