Question about Maytag Dryers
May tag intellisense dryer fault F07 what does it means?
Fault number F07
  • 1314 Answers
SOURCE: I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
Posted on May 21, 2008
ngfam1
  • 639 Answers
SOURCE: fault code E9E
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Sounds like an electronic problem!
Better have factory service do it!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Krazytech
  • 725 Answers
SOURCE: maytag dryer
88 is not a error code on the tech sheet..all error code should have an F-XX I think your control must be showing a bad circurt in the control... you need to replace control... hope it helps
Posted on Oct 26, 2008
blueextc3221
  • 15935 Answers
SOURCE: getting a fault code F70 on our 3000 series dryer?
F70 = Overheating sensed causing dryer stop until temperature reaches(drops) below set level - determined by manufacturer
Can be caused by different contributing factors;
1. poor airflow
2. blocked air flow screen inside tumbler
3. clogged lint screen
4. slow tumbler (low revolutions)
NOTE;
Ironically, the fourth factor has been lurking behind the popular discussions on this problem that has exhibited itself on both the whirlpool and kenmore products with the main triage to have included inspection of the electrical connections made by the installer.
These electrical connections not followed properly with accordance to '4prong' NEMA 14-30R (30amp, 2-phase circuit outlet) with separate ground and neutral posts, as exhibited in the standard dryer installation manual, will cause your tumbler to run slow. Hence, the 4th factor which caused the 'F70' code stops the dryer from operating.
Now, you have corrected the wiring as necessary and eagerly place some stuff's in there and all seems well. But as soon as you place something large and wet (HEAVY/BUNDLE), you get the error code again, Geeeezzzzz, you thought you had it!
Okay, this is what you need to do;
1. make sure your air flow is adequate by really cleaning the duct (I stuck my hand through the wall duct and scraped off old hard lint that can collect humidity & even cut my finger). Also make sure your vent hose does not have any unnecessary elbows or squiggles in it ( I had an elbow/pan type and it is not good as the heat seems to reflect too much ). KEEP IT AS SHORT AS POSSIBLE - I KNOW IT'S HARD, BUT IT IS NECESSARY.
2. Refrain from using too many softener sheets as they can & will restrict the air flow screen inside the tumbler.
3. Make sure your lint screen is clean - wash it periodically as lint particles collect moisture and this in turn raised humidity.
4. Once you have verified your electrical connections as stated earlier in this posting, run a normal cycle with towels or something of the like so as to reset the sensors in the dryer.
What my wife keeps doing is to put a back in after it's Heavy Buncle cycle (because it's not fluffy) and the dryer start up with high heat and then senses over heat and then SHE GET'S THE FAMOUS F70. In cases like this, use the damp dry selection and that works great - or better yet just use the timed dry selection with low heat.
We just have to understand that someone sat down and figured out what and how they wanted to program the computer that determines how this particular machine is going to react.
THE MAIN THING TO REMEMBER IS THAT 'F70' SEEMS TO BE THERE TO PROTECT AGAINST OVERHEATING WHICH IN TURN CAN TURN TO A FIRE HAZARD!
Posted on Mar 03, 2010
SOURCE: maytag 3000 series dryer fault code f22. what does
F22 is an exhaust blockage. Machine shuts off to prevent overheating and causing a fire. Check the exhaust in the back for blockage. Also clean lint screen before each load to decrease the chance of exhaust blockage
Posted on Dec 19, 2010
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Hot point ariston aqualtis condenser dryer fault code f07
F07
Heater relay stuck
Check wiring
Check electronic control PCB
Jun 21, 2014 | Hoover Dryers
Free whirlpool repair manual
Hello, Without a model number, I can be of limited help. But the F07 fault on a whirlpool dishwasher is indicating a problem with the water intake flow meter. Check the connections at the meter, if good replace the flow meter.
Unplug the appliance.
Take it out of it's installed location
Remove the left side panel .
In the large plastic tank on the left side of the machine is the flow meter. It will have a 2 wire plug on it.
Pull the plug off and push it on again a couple times.
Make sure the connection is dry and tight.
Try the dishwasher.
If you receive the F07 fault again, replace the flow meter.
Apr 21, 2014 | Dishwashers
Fault code f07
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Dec 31, 2013 | Dryers
Error code f 07 mid cycle?!?
You do not state your machine or model. The error code F07 that I have states that the Central Control Unit has detected a short in the Motor Control Unit.
Check the wire harness between the Drive Motor and the MCU and between the MCU and the CCU.
Check the MCU.
Check the Drive Motor.
Check the entire wire harness.
Replace any defective parts.
Apr 26, 2011 | Washing Machines
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
Hotpoint wf310 set wash,it starts then after about 20 seconds the on/of light and the lights to the far left flash
you will have to check the error code number which you get as per the blinks.
f16 N/A
ignore the on off light
as per the fault mentioned you will have to check the fault in your unit and then replace that following part in your unit.
you can get required parts from
www.repairclinic.com and also from www.partselect.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 27, 2009 | Dishwashers
APC BR1500LCD Fault F01
This is a printout of the fault codes
System Fault indicator is on and all other
front panel indicators are flashing.
Internal UPS fault. One of nine Internal UPS Fault Messages is displayed:
F01 - On-Battery Overload F06 - Relay Welding
F02 - On-Battery Output Short F07 - Temperature
F03 - On-Battery XCap Overload F08 - Fan Fault
F04 - Clamp Short F09 - Internal Fault
F05 - Charger Fault
Nov 23, 2009 | APC BR1500LCD UPS System
Dryers Logo
51 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
