NOTE: When installing drive belt on the pulleys, make sure that belt is properly routed and all V-grooves make proper contact with pulley grooves. 1. Install the accessory drive belt (2) around all the pulleys except for the generator pulley (3). 2. Using a wrench, rotate accessory drive belt tensioner (8) counterclockwise until accessory drive belt (2) can be installed on the generator pulley (3). Release spring tension onto accessory drive belt (2).
you can down load the drive from internet and install to check whether the driver is installed or not right click my computer click properties then hardware then device manager if any sign in th drive means that driver is not installed properly you will have reinstall the correct driver as per the OS version
Please check the connection and the speaker. After that go to device manager check the sound driver is installed or not.If the sound driver is not installed please download the drive from the website and install properly. Please enther the model number of the PC in the www.google.com. you will get the website for down lod the driver.
may be the sound drivers u have not installed properly....go to control panel check for device manger...n see if u have installed ur drivers properly..
It is the sound card drivers problem. Either they are not installed or wrong drivers are installed. if the sound card drivers were not installed, you can find them on the motherboard CD which u got at the time of purchase of your Computer. Insert the CD into the drive and install the proper Sound Card Drivers for your relevant Operating System.
it is most probably you have sometimes accidently muted the speaker to check it first go to control panel and select sound and audio devices and see if it is muted or go to the device manager (right click on my computer and select device manager from the hardware tab) and see if the driver is properly installed if not properly installed download the sound driver from the homepage of your pc's company. and from the device manager right click on the sound drive and then update the driver and give the path for the drive as the location whre you have saved the downloaded file
hi check that your sound driver is properly install, when you install the sound driver its giving error if yes, then you have to send your motherboard to service center for repairing or buy sound card from computer stores fix it and sound driver
The message that the installation failed means the drivers did NOT install properly. Uninstall the driver FIRST before trying the installation again. Failure to remove all the sound drivers will insure a failed installation.
what Model and Make and what type of sound Drivers are you looking for or Errors
