Question about GE JVM1440 Microwave Oven
Microwave Turns on automatically
Three to four times per day, my microwave oven comes on by itself. It is running in a programmed way; for example it says it is defrosting or cooking vegetables, etc. From the display screen you can see it is running these fixed programmed cycles (cooking vegetables; defrosting, etc.) This microwave was manufactured in Feb. 2006 but was only recently used. Any suggestions on how to delete the preprogrammed cooking cycles from the memory of this microwave will be appreciated. AJ
  • outback Dec 09, 2007
    Emerson mw8987B Turns itself on by itself , I came home from work to find my microwave running , I have no idea how long it had ran , but when I opened it , It was very hot, I have unpluged it from the wall. This is the second time this has happened, I thought I was going out of my mind, Fix it before you burn someones house down. Paul Willsher
  • Anonymous Dec 15, 2007
    I'm having the exact same issue. I unplug overnight, but sure enough, the next day it will do the same thing. I'm pissed because I've only owned it less than 1.5 years.
    Problem Solver:
  • 17 Answers
Probably a defective keypad. Check with manufacturer; some brands have issued recalls for this problem as it is a fire hazard.
In the meantime, unplug oven or leave door ajar when not in use to prevent it starting on its own.
Posted on Feb 14, 2008
    Problem Solver:
  • 18 Answers
I would remove the plug from the mains for at least one hour. This should remove any memory
Posted on Jul 10, 2007
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
Aug 29, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
After I entred the desired minutes, when I press START it does not work. And if I press the ADD MINUTES, it is not working. Please can you tell me any solution. Can this problem be due to not cleaning the...
HELLO.
The steps to the solution are as follows.
Off the microwave oven and it.
Then plug the microwave oven and power on the microwave.
Allow the microwave oven to load itself.
Then reset the timing program.
Test the microwave for normal operation.
NOTE:if the problem persist,cleaning the microwave is the next solution.Below is the solution to cleaning the microwave oven.
  • Remove oven racks and soak them in soapy water.
  • Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • Let the oven do its work; it will heat for several hours, charring off baked-on foods.
Thanks.
Sep 20, 2011 | Kenmore 63652 Microwave Oven
Taylor model c300 service manual
Hello. How old is your Taylor Model C300? If you have had this microwave oven four or more years. If it none functioning then recycle it for the metal and other materials. Now the price of copper is $3.25 per/lb, brass 1.85 per/lb, nickel has gone up. stainless steel. Almost everything in your microwave is recyclable. If you don't fell like take it apart and salvaging the material in it.
Call the Boy Scouts, Girl Scouts, recycling centers, etc.
If you need service manual search the Internet and used wild cards, such as***-----. example: ***Service Manual Taylor Microwave #C300*** or ***Service-Manual-Taylor-Microwave-C300*** Now, if you use to many -- between words this will make the search engine tighten it search to a point it can find anything. So, try it out, if nothing comes up take out a few dashes out
It almost cost prohibitive to repair microwave oven, TV, DVD, VCR, Cassette players, etc. I don't work on them anymore. By the time I get the parts and I have waited months for parts and my time plus parts it to expensive. GB...stewbison
Aug 20, 2011 | Microwave Ovens
Sharp 2010 turns itself on, fan runs but does not microwave
The repair or replace decision depends to some extent upon age and repair history.
Oct 04, 2017 | Sharp R-1210 Microwave Oven
Manual for breville microwave bre799gmsse
this feature allows you to program your oven to begin cooking automatically at a designated time of day. Simply touch Custom Help pad. Touch the number 3. Enter the start time. Touch Clock pad. Enter cooking program. Touch Start/Touch On pad.
Jul 26, 2009 | Microwave Ovens
Microwave turns on by itself
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So please leave it unplugged or leave the door open.
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or visit here.
Jul 04, 2009 | Beyond WBYMW1 Microwave Oven
Microwave turns itself off after a couple of seconds
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light turns on Automatically
If you don't have the onwer's manual, it's online here:
http://www.fixya.com/support/p50922-amana_amv5164_1000_watts_microwave_oven/manual-1726/page-5
See page 7 for Control Setup button functions.
Aug 19, 2007 | Amana AMV5164 Microwave Oven
GE JVM1440 Microwave Oven Logo
287 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
