Question about Vornado Air Purifiers
Replace transducer on vornado ultrasonic humidifier
How to replace transducer on vornado ultrasonic humidifier Transducer shot. Severe corrosion bubbled up metalic surface, leaving only 50 percent of surface area to produce mist. Having a hard time finding replacement. Also, is access to the transducer gained by removal of the grommet on the top side, or is access gained by removal of the metal backing plate on the inside?? Thanks for your help!
  • 148 Answers
SOURCE: Living Air XL (no smell)
Posted on Sep 25, 2008
  • 89 Answers
SOURCE: How do I clean the metal screen? Do I need to replace any filters at any point?
if the metal screen is removable, run under warm water and gently brush with damp rag
if no removable, unplug unit, wipe clean with damp rag
Posted on May 29, 2009
  • 670 Answers
SOURCE: what does a green blinking light mean on my eco
When the green LED starts to blink, means that there is a bulb failure in the RCI module. It typically glows greenish blue when it working. Check the connector to see if it is seated properly, and also check the power connector for problems. I had a problem with the power connect not making a good contact and it caused the power to be intermittent. I was able to clean the connector with a can of electrical contact cleaner from Radio Shack to fix this problem. If you can't get the bulb to light, you will need a new RCI module.
As for the purification plate, the one that shaped like a tongue depressor, it does not matter which way it go back in to the unit. You should be able to get parts from your dealer or you can call the company at 800 989 2299. Hope this helps.
Posted on Jun 10, 2010
  • 41 Answers
SOURCE: The power was not copming on becaise the little
Hi the tomato m,
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Posted on Feb 18, 2011
  • 722 Answers
SOURCE: After removing and cleaning the
Make sure there isn't a clip at the bottom (back) that may be preventing it from sliding all the way. This clip may be used for holding it in place while it's in, but loose enough for you to remove it when needed. The metal stips should not be what is holding it back, however, look closely on that side on the unit, and see that there is equivalent space. It could be that the grooves and metal just aren't lining up as needed, and because it is such a close fit, you are not able to see that while inserting it back in.
Please let me know if you need further assistance.
Guru, Premium Expert, Phone Support @
Posted on Jun 16, 2011
How do i change battery on vornado remote
it may be held on with a tiny screw.. it needs removed before you can open it up
Aug 01, 2014 | Frontgate Vornado Tower Circulator Fan -...
Says insert plate, new plate vety thing is together correct
Clean the contacts which hold the two pieces of curved metal they are corroded once you clean them, apply some anti corrosive paste or spray to these areas that should prevent it from happening for some time.. they corrode between the curved metal contacts and the screws.
Jul 16, 2012 | Ecoquest Fresh Air Air Purifier
I have SYNAIRG4 readout said 'perform cleaning'....I out filters washed and replied, put in new ceramic plate...restarted read out...'perform cleaning'.....what now? I...
The metal contactors and the wire spade connectors get pretty corroded and can cause continuity problems . I have had to replace those spade connectors and clean the metal contactors with emry sand cloth. Another trick is to soak the plate in ammonia to reduce the corrosion present on the grids
Sep 28, 2010 | Ecoquest Fresh Air Air Purifier
No Medium Fan Speed
sounds like ur medium speed has gone out
Feb 20, 2010 | Air Purifiers
Is rainmate good for sinus problems
If you are having issues associated with dry sinus, and it is cold where you are located (with heating unit running), then yes, a humidifier will increase the relative humidity of the air and possibly decrease the issues you have with dry sinus, regardless of manufacturer.
You need to look for a humidifier that provides for a decent humidification rate, in terms of gallons per hour. The higher, the better. And, with that, you want a decent water tank storage amount, or you will be refilling all the time (the smaller the tank, the more often you have to refill.).
Also look for a humidity control, but don't pay a lot for it. The more humid the air, the harder it is for more water to evaporate into it. You would really like around 50%-60% RH in your home.
Dec 13, 2009 | Rainbow Rainmate Air Purifier
I have an ecoquest fresh air purifier and the end of a red wire was corroded so I replaced the end with a new one, but the unit doesnt seem to be producing any ozone smell or sanitizing. It seems as if...
That corrosion is oxidation for the lug connecting the grid plate.Metal contact fingers make contact on the plates metal grids.The same corrosion exists on those metal contact fingers and the plate itself. Clean the fingers,ensure good connections as the other wire connector spade for the other contact finger is probably compromised. You might de-oxidize the plate by soaking in pure white ammonia.At any rate,I agree about the quality of the machines and you might be faced with a small parts order from eco-quest.Do include the plate, a bulb and the bulb starter. I run 5 of these in a commercial setting and they are fairly enjoyable to work on.
Jul 25, 2009 | Ecoquest Fresh Air Living Air Purifier
Plate error
the metal contactors and the wire spade connectors get pretty corroded and can cause continuity problems .i have had to replace those spade connectors and clean the metal contactors with emry sand cloth.another trick is to soak the plate in ammonia to reduce the corrosion present on the grids
Apr 08, 2009 | Ecoquest Fresh Air Air Purifier
"Replace plate" messge appears. I replaced it but the message remains!
Regarding "Replace Card" warning, 90% of the time it's the female metal connector on the red wire going to the spring metal connection screws... The connector can have a buildup of corrosion ( green) build inside of the crimped connection. In that case, the crimped connector will need to be replaced. The black wire may also suffer from corrosion, but to a lessor extent. The replacement crimps need to be stainless steel crimps. The copper crimps corrode easily. Another thing to look out for are loose connections. The final solution would be to replace the card, or see your friendly dealer.
Nov 08, 2007 | Ecoquest Fresh Air Air Purifier
Air Purifiers Logo
161 people viewed this question
Top Vornado Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Vornado Air Purifier Expert? Answer questions, earn points and help others
