Question about Tomtom GO 300 GPS Receiver
TomTom 500 won't power EITHER!!!!
I have the same problem, it shows a green light when charging but doesn't start. I pressed reset and it still doesn't work. Any Suggestions????
  • Lottidax Apr 23, 2008
    I have pressed reset and recharged the TOMTOM but it still doesn't work. The first time this happened to me , the reset button did put it right.
Guys make sure you know where the reset button is . Ie for tomtom 500 it is at the back and you have to unclip from the adapter.
Posted on Jul 08, 2007
SOURCE:
How do I start my tomtom 2405. It has been sitting for 1 year. Charged overnight. The start button is green
Have you tried to RESET it ? .... either, hold down the power ON/OFF button for a long while ... (e.g. 30 seconds or more) ... until the device starts up (then let go)..... or use a pin (paper clip) to push into the RESET hole at the bottom of the device.
May 11, 2014 | Tomtom GO 2405 TM GPS Receiver
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
My TomTom One V3 won't switch on. The green light shows it as charging but it won't power up. Tried reset as discussed with TomTom
If reset not worked, then must open up, take out battery and then reset, then you must hook up USB and upgrade software, also maybe need to get new battery too, often battery seems OK, but not,.
Apr 10, 2010 | Tomtom ONE 3rd Edition GPS
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
My tomtom go 910 will not switch on it has the green light on at the top left when plugged into a charger but nothing turns on when pressing button for 2 seconds any ideas??
In general I find these sort of problems can be fixed by the below
If the Tomtom loses battery power it might cease to function with a blank screen but will show a green light when you charge it. The trick is charge it on the mains charger for at least two hours. Then reset the device with a paper clip. If you get no reponse hold down the on button for at least 20 secs and the device will show the Tomtom logo and play a drum roll and startup normally.
Sep 03, 2008 | Tomtom GO 910
Seeking the repair of my tomtom Go 910
One suggestion is to plug the Tom Tom using the temporary power cord to you home circuit (not the power source from the car). That worked for me. Sometime the Tom Tom shuts down when left in the hot car requiring a reset. Then the best way is to plug in at home and restart. Try it, otherwise I can't help.
Jim
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
My tomtom doesnt turns on. It shows the green led when pressing the power button, but doesnt show anything. It doesnt charge and doesnt show any led while on charge. I tried the reset for 10 sec (and 15...
Remove the micro sd card from your TomTom. Look at the bottom of your unit, where the copper contacts are (where the unit mounts to the windshield mount). You will notice a "cut-out" in the plastic case, just above the contacts. The reset button is there. Use a paper clip and depress this button for 15 seconds. Now press the power button, and it should turn on. Now replace the sd card.
Jun 27, 2008 | Tomtom GO 510 GPS Receiver
Tomtom not switching on
I had this problem. had it plugged in charging and then pressed the the reset and the power button at the same time for about 30-50 seconds and then after that pressed the power button and so far so good
Apr 02, 2008 | Tomtom GO 700 GPS Receiver
Doesn' t turn on
reset the device by pushing the reset button near the plug on the bottom of the unit , then it will come on i presume you upgraded by the internet you need to use a paper clip to reset the unit
Sep 25, 2007 | Tomtom GO 700 GPS Receiver
Tom tom go 500 wont power up
Press the power button for 15 seconds and your tomtom will turn on with the drum sounds yor tomtom will now reset but nothing will be deleted off it and it will now hope fully work.
Bye
Apr 27, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
204 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
