Question about H2o TR220002 Steam Cleaner
H20 steam mop blowing fuses
Plug it in and blows fuses. noticed one pin on plug is longer
How do you get to the fuse in the dc28?
The 3-pin mains plug will have a plastic fuse holder which can be levered open with a small screwdriver. Look on the pin side of the plug. There will also be small writing on the plug to tell you which size of fuse is fitted to the plug. Replace with the same size of fuse. It is important to note that the fuse in the mains plug is only likely to blow if there is an electrical issue inside the machine, so replacing the fuse may just result in the fuse blowing again. If this happens then the vacuum needs proper checking and repair. DO NOT try using a bigger fuse, as you may cause more damage to the vacuum, or cable overheating or risk of electric shock.
Jan 09, 2017 | Dyson DC28
I have the original H20 Mop. The light comes on, I feel the motor humming but no steam.
Hello, this is Ava with Think Crucial.
The are a number of reasons why your H20 mop doesn't steam. Ensure that the water tank has correct level of water. Check if the Steam Nozzle has a blockage and clean if it's necessary. Also, check for limescale deposit and removed it. You may refer to your unit's manual for procedures to remove limescale.
You can purchase a wide variety of high quality replacement microfiber mop pads for your H20 mop from ThinkCrucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=h20+mop
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 16, 2016 | H20 Vacuums
My H20 x5 steam mop keeps tripping the electric I have changed the fuse but this still keeps happening please advise?
Please stop using the mop before you have the thing catch on fire, or even your house/apartment.
What may have happened is the steam/water may have gotten in to the motor some how and is shorting it out.
Jul 11, 2016 | H20 x 5 Mop
H20 Steam Mop Blows Fuse can it be fixed?
Potential problem is steam entering the electrics causing a short. Try and put appliance in an airing cupboard overnight and see if this helps. Good luck, Graham
Sep 06, 2013 | H2o TR220002 Steam Cleaner
When i plug in my oreck steam it mop, it keeps blowing the fuse
Make sure no other appliance is running at the same time. Some other appliance on the same house line is causing the fuse to overload. Example: If we have the space heater on in the bedroom and my wife tries to use her hair dryer then the fuse blows as they are both on the same circuit.
Aug 26, 2013 | Oreck Vacuums
No steam from h20 mop
examine this page for troubleshooting:
http://www.ehow.com/how_5422482_troubleshoot-hoover-steam-vac.html
God bless you
May 09, 2012 | Vacuums
Shredder does not power on
Good day!!!!
please try to check the plug if it is OK..
Then look for the fuse if busted...
If the fuse is busted look at the fuse if only disconnect the wire inside so that you can determine the cause of blowing of fuse..if the fuse is dark or have color black inside your machine have a short circuit..if not got fluctuate high current in split second (that is normal)..just replaced the fuse with the same type and ratings..
If the fuse always blows after power ON your machine need further repair it have short circuit..
Thanks for using fixya...
Aug 10, 2011 | Vacuums
Will the mop be safe to operate if you by-pass the fuse?
Fuse is meant for the safety of the equipment & the user as well. It prevents the occurrence of fire in case of malfunction by blowing. So never bypass the fuse.
-sonsunny
Jul 09, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I am trying to change an old fashioned fuse, (house lights), luckily had a spare one. Have put the 15amp fuse wire through the whole thing, and trying to describe if I've got it right is alitle awkward,...
hi.
your descriptions are understandable and sound about right.
as long as the wire is securely fixed to both pins, you should be ok.
if there are any problems, especially if the fuse blows again fairly soon, then i strongly recommend calling a qualified electrician to check the system.
Apr 04, 2011 | Vacuums
H2o TR220002 Steam Cleaner Logo
174 people viewed this question
Top H2o Vacuums Experts
rugby prop
Lawrence Oravetz
Tom Chichester
Are you a H2o Vacuum Expert? Answer questions, earn points and help others
