Question about Toshiba Satellite P35-S611 Notebook
No sounds coming out from the speakers.
I have a satellite p35-s611 series and when i play music there's no sound coming out from the speakers.
  • helpme818 Feb 07, 2009
    Had the same problem took it into circuity city was fix under service aggrement sometime ago. I do not use this laptop maybe one or twice a month if that, now I have the same problem no sound, did all of the checks and everything is set correctly.
  • Joel Navarro May 11, 2010
    Is it just when you play music? What program are you using to play music?
Toshiba satellite p35-2611 2 inch(1
the worse thing it could be is the lcd going out in a very bad way. Yes likely to get wrose over time, No not the video card because it happends on every screen, boot,preboot,and windows so guess what? If you have the lcd replaced you will be looking at a good laptop once again. Price aroung $75-100 bucks where? Ebay of all sources. Thanks I hope this was Very Helpful to you if so lay ing your ratings.
Dec 13, 2009 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
Psp sound is not working
did you forget to plug in the speakers or did you blow them up
May 29, 2009 | Toshiba Satellite P35-S611 Notebook
Slow Hard drive
That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
May 08, 2009 | Toshiba Satellite P35-S611 Notebook
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
No sound
check the software that deals with sound like Reltek .If still not working, check sound card
Jan 22, 2009 | Toshiba Satellite P35-S611 Notebook
Missing P35-S611 Restore CDROM
Sorry but that would be illegal :(
Contact microsoft for a replacement.
Jan 05, 2008 | Toshiba Satellite P35-S611 Notebook
Sound problem
Sounds silly but, try muting your built in microphone, because i'l bet, the mic is picking up the sound from yours speakers and causing the echo. That's wot i've found on a few occassions. Other than that, check sound and video drivers by click Start>Run, then type in 'dxdiag' (without quotes) this will run a diagnostic on audio and video. Please rate this solution
Nov 09, 2006 | Toshiba Satellite P30 P35 Series Notebook
Toshiba Satellite P35-S611 Notebook Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
