Question about Dell OptiPlex 360 Desktop Computer
How do i reset dell optiplex hard drive password
I can reset the bios, set up, admin etc. except the hard drive password does not get disable when i remove the jumper
    New Friend:
Hard disk #MAV2x803834-595B
Posted on Feb 06, 2013
  • adugnaworku2
    adugnaworku2 Feb 06, 2013
    how to remove hard disk pass word?
    New Friend:
  • 32 Answers
Just go to boot menu by pressing f10 while on start up of your computer.
and go to hdd psssword and change password from here.
Posted on Sep 04, 2015
  • Dell Master
  • 32,281 Answers
These WEB sites may help remove the hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/
A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Posted on Jan 11, 2013
SOURCE: dell optiplex 170L hard drive recognition
Ms Driver gets flaky sometimes. Get New driver from Dell Downloads.
Contact Dell Support for more INFO
Posted on Oct 08, 2008
leecom72
  • 4806 Answers
SOURCE: Optiplex G620 has "munged" BIOS Admin password
Hi there.
Try clearing the cmos fdbf23f.jpg. move the plastic jumper the alternative position, power the pc up (Nothing will happen if you have it correct, then put it back in its original position and try to boot the machine again, password should be removed.
Good luck and thanks for using Fixya!!
Posted on Feb 13, 2009
Fixe_You
  • 1800 Answers
SOURCE: Dell Optiplex GX260 desktop-how to reset factory settings in BIOS
sir try to remove the pill battery its in the inside of ur box that return it that might give an error said that u shud configure again ur time and date but that is easy but taht will increase teh speed and gives a reset to full factory defaults
Posted on Aug 13, 2008
  • 3940 Answers
SOURCE: dell optiplex gx620
There is a Jumper on the motherboard to reset the system Password.
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/advfeat0.htm#wp1117484
Posted on Feb 24, 2009
ginko
  • 19396 Answers
SOURCE: Bios default password
The BIOS default password is just blank, and it is not asked.
When you set a bios password, you are asked to enter a value, therefore if bios is asking the password, the password had been changed.
To reset the bios password if you do not know the password you need to access to motherboard and temporarily remove battery for few seconds.
Removing battery will reset bios and delete the password.
Unplug power cord before accessing the motherboard, and try not touching the motherboard with your finger.
Put battery back in place before restarting computer.
See also the following websites:
technibble.com/..
satyathakur.com/blog/
Posted on Mar 04, 2009
How to disable Hard drive password
Did you clear your BIOS to rid yourself of the bios password first? Just making sure you are really looking for the hdd password (which you set while setting the BIOS password I assume) There are some tools out there to help you remove/rest the hdd password but lets be sure that's what you need to do first. Be warned, the tools don't always work and unless you remember the password you might be looking at complete data loss and a new hard drive.
Aug 11, 2014 | Dell OptiPlex 390 DT Desktop Computer...
How to remove a BIOS password from a desk top
This is both trickier and easier than you might think.
  1. Shut down PC, disconnect power, and open case.
  2. Look for two pins sticking up off the motherboard that say: "RESET CMOS" or "CMOS PASS" or "BIOS PASS" or "BIOS RESET" or some combination.
  3. There should be a plastic "jumper" that is attached to ONE of the pins on the CMOS jumper (step two).
  4. Carefully remove the "jumper" by pulling straight up on it.
  5. Replace the jumper so that both pins are inserted into it.
  6. Connect Power and Power On your PC
  7. (it may beep loudly and shut off or it may startup like normal, allowing you to get into your BIOS)
  8. Shut down PC, remove power
  9. return the "jumper" (step two) so that only one pin is connected like you found it.
  10. Power on your PC and you should be good to go.
NOTE: If you don't have a jumper on your motherboard, you will need to find one. Often, a CD-ROM drive or old IDE hard drive will have a jumper on it. If you find a jumper on an old device that is not connected and not running, you can use it so long as you remember to return it to it's original position. Failing to return a "borrowed" jumper from an external device could make it unusable in the future.
Also, never use a jumper from elsewhere on your motherboard. These jumpers can be critical to the operation of your PC and "borrowing" one could render your PC useless and may not ever help you to reset the BIOS password.
NOTE: When you reset the BIOS password in this manner, all of your custom BIOS settings will be reset. Any hardware that you had to configure manually through your BIOS may not work. Overclocking and other features may be disabled by default. This should not be done without proper consideration.
Hope this helps,
Jase
Feb 26, 2014 | Computers & Internet
Password admin bios
Reset the CMOS by unplugging your Optiplex from the power cable & removing the CMOS battery.
The CMOS battery is just a larger "watch battery" about the size of a nickel. Remove it for a few seconds, put it back in & power it back up. This will reset the BIOS password & restore all the BISO settings to default however.
Oct 16, 2013 | Dell OptiPlex GX520 PC Desktop
Help to restore the computer to normal (Bios Password)
RTM - Read The Manual
I found the info below in your manual online. You will need to reset the jumper on the motherboard to remove the password.
Admin Password (Not Set default)
Displays the current status of your system setup
programs password security feature and allows you to
verify and assign a new admin password. The Admin
Password may be disabled by a jumper on the system
board.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals and search them for Passwords.
Clearing Forgotten Passwords (the manual shows a picture of this)
1 Remove the computer cover.
2 Locate the 2-pin password jumper (PSWD) on the system board. By
default, Pin1 and Pin2 should be connected. You will need to remove the
jumper and boot the system, as follows.
3 Remove the jumper.
4 Replace the computer cover.
5 Connect your computer and monitor to electrical outlets, and turn them on.
6 After the Microsoft Windows desktop appears on your computer, shut down your computer.
7 Turn off the monitor and disconnect it from the electrical outlet.
8 Disconnect the computer power cable from the electrical outlet, and press the power button to ground the system board.
9 Open the computer cover.
10 Locate the 2-pin password jumper (PSWD) on the system board and
attach the jumper to reenable the password feature.
11 Replace the computer cover.
NOTICE To connect a network cable, first plug the cable into the network wall jack and then plug it into the computer.
12 Connect your computer and devices to electrical outlets, and turn them on.
NOTE This procedure enables the password feature. When you enter system setup (see "Entering System Setup" on page 79), both system and administrator password options appear as Not Set meaning that the password feature is enabled but no password is assigned.
13 Assign a new system and or administrator password. Replace the computer cover.
NOTICE To connect a network cable, first plug the cable into the network device and then plug it into the computer.
14 Connect your computer and devices to electrical outlets, and turn them on.
Apr 23, 2012 | Dell OptiPlex 330 Desktop Desktop Computer...
I purchased an old Toshiba Tecra M3 from a well known on line auction site. When I cam to use it I discovered that the computer goes really well but the hard drive is locked, this is not a BIOS password...
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
Hope this helps
Feb 19, 2011 | Seagate MOMENTUS 5400.3 (ST9160821AS) SATA...
I lost all password for dell desktop optiplex computer bios password hard drive password cmos password
Lots of sites say to move the PSWD jumper (on the motherboard) from pins 1&2 to pins 3&4, or something like that. However on my Optiplex 360 I found that the PSWD jumper had only 2 pins. By trial and error I found that removing the jumper from these two pins while the system was off allowed me to boot the system with BIOS password disabled. I was then able to change BIOS settings (and install Linux - yeah!!).
Dec 03, 2010 | Dell OptiPlex 360 Desktop Computer
Problem with BIOS password on a Dell OptiPlex GX240 ??? user forgot the system password
In order to clear the BIOS password, you can remove the coin-cell (CMOS Battery) from the motherboard for a few minutes. The BIOS settings will be reset to defaults and you will have to reset password etc.
Hope it helps!
CreativeTECH
Nov 19, 2010 | Dell OptiPlex GX240 PC Desktop
How can you reset the cmos password
Dell Optiplex 780, user forgot BIOS master password (which is necessary to change the boot order to run BartPE from CD and do an image backup).
There is a jumper on the mainboard called PSWD1, which is set (shorted). Remove power cable from PC (CMOS battery can stay in place), open the lid. Remove jumper from PSWD1. Reconnect power, start the PC, hit F2 to enter BIOS. All passwords should be reset.
Leave BIOS, power off the PC, remove power cable. Reattach jumper to PSWD1, close lid, reattach power cable. Start PC. Enjoy.
Nov 11, 2010 | Dell OptiPlex 780 MT PC Desktop
Computer was disabled when Bios password was incorrectly entered two times in row, I was trying to remove disk passwor in order to add a larger hard drive It will not boot to a bootable disk or any other...
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
May 27, 2010 | Gateway MX6437 Notebook
Dell OptiPlex 360 Desktop Computer   Logo
1,555 people viewed this question
Alun Cox
