Question about Sony DCR-PC55E Mini DV Digital Camcorder
Sony dcr-hc35e it will not play back any of my recorded footage, to the lcd or to any output. i have tried reseting it. the motor seems to be working, it will forward, rewind and when i press play you can hear the motor working but it will not show any footage. what should i do?
    Problem Solver:
  • 9 Answers
First try a cleaning tape and this will not solve the problem have a service dealer check the unit.ru the cleaning tape once and try to playback a good old recording, if it does not work try to run the tape twice before testing . do not run the tape too many times as you may damage the video heads.one cleaning session should not be longer than 10-15 seconds. most of the new cams are stopping the cleaning tape playback after 10-15 secs.
Posted on Jul 25, 2007
SOURCE:
When I turn on my handycam sony DCR-HC 35,the touch-screen don't work!? What can I do about it?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Jan 05, 2011 | Sony DCR-HC35E Mini DV Digital Camcorder
Half the screen is blue
the lcd panel is faulty. replace it at a service centre
Oct 13, 2009 | Sony DCR-VX2000 Mini DV Digital Camcorder
Everthing seems to work, except the camera will not record.
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD.
If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor.
Qualified camera tech will replace ccd imager chip.
Thanks.
Oct 01, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
No picture or sound on playback
Hi, All sorted. I purchased a head cleaner and played it for 10 seconds. The camera now works as good a s new. Hope this will help others with a similar problem. John
Jun 04, 2009 | Sony Handycam DCR-TRV110 Camcorder
Sound but no pictures
It seems problem of defective ccd imager IC, please confirm is this DCR-HC18E model Sony camcorder to guide you further.
Nov 30, 2008 | Sony DCR-HC18E Mini DV Digital Camcorder
Sony handycam dcr-dvd105
dear tonimo
if you was finish your recording, select menu and choose finalize
it can make your dvd can play in dvd prtable
oke
cropp
Dec 26, 2007 | Sony Handycam DCR-DVD105 DVD Camcorder
Trv138
I had the same problem with the DCR-TRV250 where it just stopped playing back tapes. It appeared to be recording correctly but upon playing it back, all I got was the blue screen. I tested the USB, SVideo, and DV outputs and got the same blue screen.
After weeks of deliberating, I finally decided to try cleaning the heads and that cured it! I removed the screws that allowed me to remove the transport assembly cover, which made it easier to reach the heads with a Qtip. I cleaned them using rubbing alcohol and everything seems fine now.
Dec 06, 2007 | Sony Video Cameras
My touch screen buttons stopped working, and now I cant play back or even put footage on the computer. I try to click the touc screen buttons but it doesn't work. The recording and everything works fine,...
the flexwire is the problem of your camera and if all wiring be cut the next problem is the lcd monitor would not turn on...go to a service center for replacing or repairing the flexwire...
Sep 01, 2007 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony video camera recorder DCR-HC35E
your lcd is a touch screen so if it is cracked ? you will not be able to control the camera ' s functions , from there - go to sony website for latest software updates ( and nearest service center , if lcd is damaged ) ;
Aug 14, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
Sony DCR-PC55E Mini DV Digital Camcorder Logo
190 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
