I have dell laptop with windows 7, I shut down properly.,but when i star up in the booting time it restart again and shows error in shut down problem.. please tell me what is the sollution.?
  • 2,385 Answers
Windows gone corrupt or virus infected, needs re-installtion
Posted on Jan 11, 2013
SOURCE: acer laptop aspire 4710z config my notebook have problem
hello ramavtar..
i have a acer aspire 4710z. This laptop can not open the display but the system unit is working normally. i can not see the display but i can join the external monitor i will see it process. Pls let me know how can i repair it.Pls reply to this email thanks. pyeisone1988@gmail.com
Posted on May 17, 2008
cpenzes
  • 1102 Answers
SOURCE: dell m1330 will not boot
Try and get into safemode by continuosly pressing f8 on restar then selecting safemode
let me know if you can do that
Posted on Jan 13, 2009
  • 82 Answers
SOURCE: My Hp 520 Laptop doesent show standby option activated
Either it is not enabled in your BIOS or you dont have the chipset drivers installed .
Reboot , hit F1 , go into settings for APM and verify it is enabled.
In it is enabled in BIOS and not selectable in windows , renistall the chipset drivers. Go to this link , select your OS , download and install.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3375954&lang=en&cc=us&prodTypeId=321957&prodSeriesId=3375952&taskId=135
Should be enabled. If not check device manager for any ! symbols.
Posted on Mar 04, 2009
PlatoAu
  • 67 Answers
SOURCE: Dell 1501 Inspiron w/Vista won't boot up -- virus?
Hi Erika,
have you tried pressing F8 when it starts booting (keep pressing it before dell bios screen fully loads)
you should get a black screen with options,
scroll up to with arrow keys>> "last known good configeration"
let me know if that works?
also have you installed any programs or hardware befor this happened?
Posted on Apr 13, 2009
Ricky_Critic
  • 119 Answers
SOURCE: my acer aspire 5520 keeps shutting down on boot
Insert your restore CD if errors are found and not fixed by the checkdisk function listed above. Turn your computer off and then back on. You'll beasked to hit any button to boot from your CD; press any key. You will then beasked if you want to install a fresh version of your OS or "Repair" acurrent copy. Choose the "Repair" option.
Posted on Dec 24, 2009
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Dec 06, 2012 | MSI A6000-226US Core 2 Duo T6600 2.2GHz...
Can't restart windows 7 on my dell d610, did a format on the hd, re-loaded the windows 7 disc, everything runs great until I shut it down then it won't restart
Recently a put windows 7 on my latitude d610 only problems I had were incompat. Drivers (wifi, sound, graphics.) all were fixed with googling those drivers with windows 7 because this hardware is not compatible with 7 but seeing as it is a restart thing,
Check the drivers u have installed try to see if any need updating or are no compat.
Nov 19, 2012 | Dell Latitude D610 Notebook
My lap win 7 shutting down after auto restarting
First thing you need to do is check if there is a diagnostic utility built into the BIOS. If you can find it, then run it and see if it gives you any errors with hardware. Not sure what function key is needed to enter the bios on an Acer, but it is usually F2, ESC, or DEL at the "Acer" splash screen when the laptop is turned on. You can look thru the BIOS to see if the hard drive shows up at all. If it does, then do the following:
Does it always shut down at the same point of booting? if it shuts down at the same point over and over again, then there is probably something wrong with Windows. Insert your installation CD and boot to it. After you select your language, you'll see an option to "repair" windows. It will then look for the Windows installation on your hard drive. After clicking next, it will attempt to repair whatever is wrong with it. Try to boot again. Keep in mind if there is more than one thing wrong with Windows, you may need to boot to the CD again to repair another problem, as it tends to repair problems one at a time.
Oct 29, 2012 | Acer Aspire 5735 Notebook
My dell vostro 1015 gets completely shut down without giving any prior warning..i have to restart it again and it shows that windows didnot shut down properly.it happens 3 to 4 times a day.plz help..
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Dec 02, 2011 | Dell Vostro 1015 Laptop
I left my Dell Inspiron on shut down overnight whilst it installed some windows updates. The next day it flashed up saying that the laptop hadnt shut down properly and needed rebooting and repairing. THis...
Boot up with the vista disk that came with your laptop and do system recovery again. Ignore the file corruption message because your going to be reversing your OS back in time to when your files weren't corrupted. Back it up to a time you know it works, the dates will be listed. Afterwards things should be fine, but know that vista does this alot for alot of people. NOTE: when you go back in time you will not have any files you had inbetween the date you back it up to and today. OTHER THOUGHTS: those mac commercials from way back when weren't just Evil Apple iPropaganda. Consider updating to Windows 7, I've never had a problem with it- where as your boot loop error happened to me on a weekly basis.
Mar 02, 2011 | Dell Inspiron 1525 Laptop Flamingo Pink
I m unable to install xp on dell vostro 1015 with 2 gb ram and intel core 2 duo cpu (t6570) ( the laptop came with preinstalled windows 7 and i have also successfully installed red hat linux 5 server...
If you try to run XP setup without changing the BIOS SATA setting to ATA mode, setup will BSOD with an 0X0000007B error. Make sure the SATA setting in the BIOS is ATA...
you will get this error when you will be booting your system from CD and windows installation will be in first step.
to resolve it, go to BIOS setting-->change BIOS SATA setting to ATA mode--->apply changes-->insert windows CD and restart the system-->press f12--->nd boot from CD....hope u will be able to resolve it.
Oct 12, 2010 | Dell Vostro 1015 Laptop
Laptop randomly shuts down and shows a blue screen saying
Make sure you don't have any unecessary programs loading up into windows when your laptop boots up. The next time the system randomly reboots check to see if the laptop feels a bit warmer then normal. Could be that your air vents are being blocked by dust. That would cause the air not to flow properly. Take a can of air and blow the vents clear so the air can flow properly and that would take care of the problem.
Jul 05, 2010 | Gateway CX2618 Notebook
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
Jun 21, 2010 | Dell Inspiron 1501 Notebook
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
