Question about HP Business InkJet 2800 Printer
Close covers, but it is closed - HP Business InkJet 2800 Printer
    New Friend:
  • 3 Answers
1 SWITCH PROBLEM 2 MAIN PWB TO SWITCH WAYAER DICONCT
Posted on Jan 11, 2013
Close Front Cover For Toshiba E-studio 350
There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Dec 02, 2015 | Toshiba e-Studio 350 Copier
My konica bizhub 163 gives massage 1st side cover open close 1st side cover,how do i clear the massage. pliz help me.
1st Side cover is front cover.The cover which you use to open to install or check toner bottle.When you close that cover and machine gives caution then it means cover is not properly closed
"OR"
The 1st side cover switch is not working properly.
There is a knob at the end of the front cover, make sure it it aligned with the switch.
Front cover Micro Switch can be dirty due to toner spilling/dropping inside the machine.Clean it and then recheck.
Jun 20, 2015 | Konica Minolta bizhub Office Equipment &...
My Toshiba e-studio 233 copier is giving the error message, "Close side cover." Opening any cover to close again changes the message to "Close x" where x is the part opened, until that...
there is a switch at the side that is being push by the cover when it closes check this switch to be sure it hits the button when close or you may replace the switch it has a problem.
Jun 27, 2011 | Office Equipment & Supplies
Its showing "close ink cover"
Hi there!
The message "Close Ink Cover" means that the cartridge door is not closed securely.
-please open the ink cartridge cover and make sure all cartridges are installed correctly and then close the cartridge cover. That should clear the message on the screen.
Hope this helps!
May 08, 2011 | Brother DCP 165C Compact Color Inkjet...
Close printer cover error when cover is closed
The cover sensor might have dislodged or not in its proper position. You could try to reset your printer to determine if there's a hardware fault. Remove the cartridges from your printer. Close the cover. Unplug and replug your printer into the power source. When the printer turns on completely, reinsert your cartridges. Check if error appears again. (Error: 'Cover open, please close the cover')
Feb 17, 2011 | Lexmark X2250 All-In-One InkJet Printer
Just bought MX870 and put power on and it says "The feeder cover is ope Close cover and press ok." I closed every cover and pressed ok but still shows that error.
The two covers on top are just not aligned properly. Open both top covers (one opens to the right one to the left). Close the cover that opens toward the right 1st (you should hear it click into place) then close the second cover. Press "ok" should be good to go.
Sep 01, 2010 | Office Equipment & Supplies
My Brother 560 says top cover open when the cover appears closed.
Make sure the covers are completely closed. Open each section an close it making sure it closes with a click. Also check for covers under other covers.
Hope this is of some help.
ED
May 09, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Hp 7410 officejet all in one
--close cover ---means the lower base of the printer is open the cover you open when to remove or insert the cartridges.that is not related to copy or scan cover which is above that.just close the lower covwer little bit tightly.apply gentle force or push to make it close properly.
do it carefully.
thanks.
Sep 15, 2008 | HP OfficeJet 7410 All-In-One InkJet...
STATES THAT TO CLOSE TOP COVER TO CONTINUE
1. The top cover hinges are not connected to the ink slider bar properly. - Open the top cover and snap the hinge arms back into place and close the top cover. Check for proper operation. 2. Customer has not loaded the ink sticks properly and the top cover will not close properly. - Verify the ink sticks are loaded properly and that the customer is using proper Phaser 860 ink sticks. Close the top cover and check for proper operation. PARTS:Parts are listed in the order of highest probability for repair. NUMBER QTY DESCRIPTION PROBABILITY% MODEL S/N FROM S/N TO S/N 200469000 1 COVER; TOP COVER
May 22, 2008 | Xerox Phaser 8200 Laser Printer
Close top cover
Start by trying this.
Open the cover and look around for openings in the where the cover closes. In those openings there are interlock switches. 1 of 2 things have happened.
1, The switch may have become dislodged.
2. Look on the cover you have opened for actuators, ( pieces of plastic sticking out) that would go into those holes to turn the switch on when closed. Those often break off.
One of those 2 items is your problem, The switch is just not being actuated properly.
Make sure nothing is binding the cover also.
Dec 31, 2007 | HP LaserJet 2420 Printer
HP Business InkJet 2800 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
