Question about Frigidaire FWSB5700DS Top Load Washer
Relay switch between the timimg circuit and the spin cycle
    New Friend:
    Problem Solver:
  • 5 Answers
Could be,the Timer ,going Bad.,replace The Timer .,found behind right backside of THE WASHER.
Posted on Feb 24, 2013
I have a 2009 gmc sierra, where is the wiper relay location.
The PCB wiper relays are soldered directly to circuit board inside the under hood fuse box.
The windshield wiper/washer switch signal circuits are inputs to the body control module (BCM) and the BCM controls wiper motor low speed operation, washer pump and high speed operation. The windshield wiper/washer switch is provided a low reference from the BCM and each of the switch signal circuits is supplied 12 volts through a resistor and monitored within the BCM. During LOW or INTERMITTENT operation the wiper switch low signal circuit is closed to the low reference circuit through a series of resistors within the switch assembly and the signal circuit voltage monitored by the BCM will depend on the switch contact location to the resistor assembly. During HIGH or WASH operation the high and wash switch signal circuits are closed directly to the low reference circuit within the switch assembly and nearly all the signal circuit voltage will be dropped across the BCM resistors. The BCM controls the wiper motor through the WIPER CONTROL PCB Relay and the WIPER SPEED PCB Relay. During any wiper motor function that uses low speed the BCM supplies the voltage to energize the WIPER CONTROL PCB Relay and battery voltage will be supplied from the WIPER CONTROL PCB Relay through the de-energized WIPER SPEED PCB Relay to the wiper motor low speed control circuit. During high speed wiper motor operation the WIPER CONTROL PCB Relay is energized as in low speed and the BCM provides a ground to energize the WIPER SPEED PCB Relay and the battery voltage is supplied to the wiper motor high speed control circuit. Wiper motor park operation is controlled by the BCM using an input from the park switch within the wiper motor assembly. The BCM supplies the park switch signal circuit 12 volts through a resistor then monitors the circuit. Whenever the wiper motor is out of the park position the park switch signal circuit is closed to ground and nearly all the signal circuit voltage will be dropped across the BCM resistor. When the wiper switch is turned to the OFF position while the wiper motor is somewhere in mid-cycle, the BCM will continue to operate the motor until the wipers reach the park position. If the ignition is turned OFF while the wipers are in mid-cycle, the wipers will stop immediately where they are and the BCM will park the wipers the next time the ignition is cycled ON.
DTC B3715 02: Front Wiper Relay Drive Circuit Short to Ground
DTC B3875 00: Wiper High Speed Relay Circuit
DTC B3922 00: Front Wiper Function Select Circuit
Have it checked for DTC'S - diagnostic trouble codes .
The body control module (BCM) controls the wiper motor based on input from the windshield wiper washer switch. The BCM monitors the wiper washer switch through three separate signal circuits and a ground circuit. The windshield wiper switch high signal circuit is used to determine high speed wiper operation, the windshield wiper switch low signal is used to determine low speed, intermittent, and mist operation through the use of a resistor ladder, and windshield washer switch signal circuit is used to determine washer operation.
The BCM controls the windshield wiper motor through two output controls, controlling two relays which determine the desired wiper speed, high or low.
Your best bet , take your vehicle to a qualified repair shop or dealer . Hooking up a factory scan tool to see what the wiper switch inputs to the BCM are correct and outputs to relays are good .
Feb 11, 2017 | GMC Cars & Trucks
Heil model NUGI125DH03 heater fan doesnt shut off when after burners are extinguished and plenum is cooled. Is it Limit switch or control relay
Confirm that the FAN (auto/on) switch at the thermostat is in the auto position.
I have cycled between the auto-on positions on the thermostat and confirmed that the control relay is sticky. After a few cycles the control relay sticking had corrected itself. I attribute it to residue on the contacts collecting and after a few cycles cleans off.
The limit switch has also failed but can be easily checked by checking the control voltage, Remember that the limit control has two circuits one is 115 volts the other is 24 volt control circuit.
The other circuit for cooling can also activate the fan control relay depending on the control logic set up. So the thermostat has the ability to activate the fan either by the (auto/on) or cool cycle if an A/C unit is attached to the furnace.
I would not assume that it can only be the limit or control relay. Less likely a shorted wire or defective thermostat could cause the same result.
Nov 30, 2015 | Heating & Cooling
Washer does not go through the spin cycle
while the machine is empty and in the spin cycle open the lid and hold down the lid switch spin the basket with your hand if it spins slowly you probably have a worn out clutch.
Jul 15, 2012 | Washing Machines
Kenmore Series 90 intermittent spin. Washer will go through normal wash cycle, but will often not spin during rinse or spin cycles. Upon observation, machine was seen to appear to "lock up"...
I used-to-be a big fan of Craftsman & Kenmore
but after intensive abuse I got better)...
Great trouble description...
(& trouble shooting))
Sears
has a fairly decent on-line "CHAT"
(and have been trending toward competitive)
To encourage PARTS PURCHASES...
Once they conform my "CONTROL BOARD"
hypothesis...
Check prices at :
appliancepartspros
Search Over 2 1 Million Appliance Parts
repairclinic or
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
partssellect... all have do-it-yourself VIDEOS.
PartSelect Appliance Parts and Repair Help
And last (in my opinion certainly least)... SEARS
Water Filters Lawn Garden Appliance Parts
Mar 06, 2017 | Kenmore Washing Machines
The washer will not drain water during the rinse and spin cycle
The pump is not switched on during the cycle and this circuit must be traced from the timer output. However if the drain works well in the last cycle then the pump is alright. Hence the pump circuit switch during the rinse and spin has to be traced and confirmed. Good day
Aug 12, 2010 | GE Washing Machines
Will not spin on dry cycle at any selection setting.
Not exactly sure what dry cycle means here but If it washes (agitates) but does not spin at all then you have a problem with your the lid switch or a busted motor. The wash circuit differs from spin circuit. If its one of the older type whirlpool then the switch can easily had and replaced.. Where the switch is - is usually obvious - a hole just above the switch through which the actuator on the lid operate the switch - look under there - easily replaced
Aug 22, 2008 | Whirlpool Washing Machines
Washer
relay switch between timing circuit and spin cycle is faulty
Apr 03, 2008 | GE WDSR2080D Top Load Washer
Maytag toploader model pav2300WW
Do you hear the motor activate during the expected spin cycle? If yes, then there might be a gearbox or clutch assembly issue. If not, it might be as simple as the safety switch not being engaged as the rest of the cycles might operate properly even if the safety switch is not engaged.
If the washer totally shuts down when the spin cycle begins, look at the safety switch circuit.
Mar 09, 2008 | Maytag LAT3600A Top Load Washer
Frigidaire FWSB5700DS Top Load Washer Logo
88 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
