Are all agitator dogs the same size? - Washing Machines
The agitator appears to not be working properly
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa!!
Nov 20, 2010 | Whirlpool Washing Machines
Tip
Replacing Agitator Dogs
The following advice is for replacing the Agitator Dogs on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10.
What are Agitator Dogs? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary. Just type in your COMPLETE washer model number and look under the Agitator Parts heading. I hope this information is found to be helpful.
on Dec 09, 2009 | Washing Machines
How do I remove agitator?
Thanks!!
Nov 09, 2010 | Kenmore 22422 Top Load Washer
Agitator is loose and not working correctly.
Nov 09, 2010 | Washing Machines
How do i remove the agitator dogs on 22952 kenmore elite washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 16, 2010 | Kenmore 22932 Top Load Washer
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
I have the dog agits to replace Whirlpool top load washer LLR6233AWO I have the dog agits to replace in my top agitator and cant figure out how to take the top off the bottom
On mine I pulled on the fabric softener plastic top.And under it was a cap. I pulled the cap off and looked inside to see a bolt (I think it was a 1/2" size. I needed a 1/2" socked and a 6" long extension and took the bolt completly loose. Righty tighty ,Lefty loosey. Then I just pulled up on big center plastic part and the dogs are under it. I hope this helps you.
Sep 04, 2009 | Whirlpool Washing Machines
I have an Inglis Sterling washer. The 'dogs' as they are called need to be replaced....I have disconnected the dual agitator from the washer. I am unsure how to disconnect the plastic housing that holds...
Aug 30, 2009 | Washing Machines
Clucth Dog replacements in Agitato
Feb 02, 2009 | Washing Machines
I have a kenmore washer and I am trying to replace the cam dogs. I have removed the dispenser cup and the cap that is beneath it. I can see the edges of the cam dogs, but cannot remove the plastic thing...
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
Dec 31, 2008 | Washing Machines
Washing Machines Logo
458 people viewed this question
Top Washing Machines Experts
