Question about Kenmore 75962 Gas Dryer
Kenmore model 76712 does not blow heat just cold air
The dryer blow cold air only
  • 3 more comments
  • jcombs1961 Jan 23, 2009
    The model number you have stated is incorrect the correct model # is: 110.76712690 the dry blows cold air. I have taken the back of the dryer off and i can see the heating element but i cannot get to it how do i open the back of the dryer more?
    I really appreciate your help in this matter, but my dryer is gas not electric will this make a difference in your answer?
    Sorry, i was not aware that the rating would go out for all to see. This is the first time i have used this system and i thought in order to move through the prompts this step was needed. Thanks for letting me know, i did not want to cause you any harm. By the way my dryer is a Kenmore not a Whirlpool dryer or could they be owned by the same company?
    Thank you, can you tell me how i can get to the back of my dryer better to see and touch the parts? I have the back off but it is very tight, does it open more? I will change the rating now, i am reading to see how this works.
    You are doing a GREAT!!!! job in helping me with my dryer problem. Thanks for your patience.....:)
  • 5,911 Answers
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Posted on Jan 22, 2009
  • 2 more comments
  • Jeff Rockwell
    Jeff Rockwell Jan 23, 2009
    I did not list a model number. The link I provided was a Tip posted for "All Electric Dryers". In particular, Whirlpool manufactured dryers such as yours. The advice I gave you would have worked for your dryer, as all Whirlpool manufactured electric dryers have the same heating circuit components. In the last sentence, I stated that if you had questions to please let me know. You could have provided some feedback, or asked questions rather than leaving an adverse rating. I usually stop giving advice at this point.
  • Jeff Rockwell
    You never specified a COMPLETE model number with your initial question and , YES, this does make a difference. There is no heating element in a gas dryer. You have a burner assembly, so I do not know what heating element you saw in the comments you provided.
    Most commonly, the problem with failed ignition in a gas dryer is caused by the IGNITER. This is a glow bar type igniter. You can generally see it glowing inside the dryer cabinet under the drum just before ignition. If the igniter is bad, the gas safety valve will never open and you will not get any flow of gas to the burner assembly. This is a designed safety feature that prevents free flowing gas from entering the dryer cabinet with no ignition. Such condition could cause an explosion.
    If the igniter glows, but you still do not have ignition, the igniter may be weak from age and still require replacement.
    If the burner assembly ignites for a short period of time, then goes out, this is genrall caused by weak gas valve solenoids. There are generally two of them on this model dryer. One is the main coil, while the other is the pilot position coil. If they are suspected as being bad, replace both of them at the same time to prevent premature failure of any replaced parts. They are normally sold as a set.
    All these symptoms would cause the dryer to tumble, but only blow cold air.
  • Jeff Rockwell
    Kenmore has never made their own appliances. They but the Kenmore name on other manufacturer's products (usually the more reliable models). The model number prefix of "110" identifies this dryer as a Whirlpool.
    Ratings do go out for all to see and is not required to ask questions or provide feedback. That's why we encourage communication with consumers to come to a viable solution BEFORE a solution is rated. These can also be changed at any time.
  • Jeff Rockwell
    To access the burner assembly, you have to go through the FRONT of the dryer. This is accomplished by following these steps:
    1. UNPLUG the dryer.
    2. Locate the two screws under the lint screen door on the dryer top panel. Carefully remove screws. NOTE: Do not drop them down the lint chute. Place a free hand over the opening, or cover with tape to prevent this from happening.
    3. With two screws removed, the top panel will slide towards you, then lift up.
    4. Remove the front panel by removing the door latch connectors and ground wires, first. Then locate the two screws that hold the front panel to the side casing. There is one on each side. Place you body against the panel with the door shut to support the panel while you loosen the screws. With the screws removed, the panel should lift up a bit then come off. NOTE: Tape the door shut while removing, so it does not fly open.
    The burner assembly should be easily accessible under the drum on the left hand side.
    The drum can easily be removed for better access by releasing the belt tension on the idler pulley and lifting the entire drum out of the dryer cabinet.
    If you go to searspartdirect.com, there are some excellent exploded view diagrams of your dryer that you can use for reference. The burner assembly components are listed under the "Cabinet" heading. The ingniter is listed as item number 64, while the valve solenoids are listed as items 71 and 72.
    I hope this helps you. Let me know if you have further questions.
Dryer stopped heating only blows cool air
you have to open the back off dryer,the r two thermostats. they are round held by 2 small screws. high heat- low heat. use volt meter to see which one is bad. if u put volt meter on wires,it will let you know which is bad. 30 to 35 a pc.
Mar 17, 2013 | Dryers
76712 Kenmore...is there a pilot light?
What is the full model number of the dryer? The Kenmore 11076712693 dryer has an glow bar igniter (electric igniter) and no pilot light. The parts diagram for the burner assembly for this dryer is available here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11076712693/0582/0151200/10052613/00001?blt=06&prst=&shdMod= .
Please add a comment with the full model number of your dryer if you would like more assistance.
Dec 02, 2012 | Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Kenmore dryer model 110 60622990, runs great but blows cold air
This video will show you how to troubleshoot your no heat problem.
Aug 09, 2011 | Kenmore 64602 Electric Dryer
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
My problem is the same as the one posted May 13th by someone else, but I don't see any suggested remedies. The Kenmore dryer model 76712 has power, the drum turns, COLD air blows out well, the venting is...
Good day,
You didn't give the complete model number and whether it's electric or gas.
If it's electric it could be the heating element burned out or a thermal fuse that fails frequently. It looks like this.9970e71.jpg
If it is gas, it could be that same thermal fuse and or the ignitor or the gas valve coils. These are the common failure components. There are more including limit and safety fuses to name a few.
You need an ohm meter to test these components except for the gas valve coils, which are none testable.
As to your question, the timer will not advance if the heating system has failed. That is by design. Once the no heat problem is solved the timer will work.
Jun 13, 2010 | Kenmore Dryers
OUR KENMORE DRYER BLOWS OUT COLD AIR
It's most likely a thermal fuse if it's a gas dryer. very easy to install. If your dryer is electric, it's either the thermal cut-off or the heating element itself. If you need help with anything, please feel free to e-mail me. good luck :)
Jul 06, 2009 | Kenmore Dryers
My kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Jun 26, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Kenmore 75962 Gas Dryer Logo
678 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
