Trying to conect wifi on my vigo anroid tab and it asking for ssid and security method wat is that ssid
  • 7,627 Answers
Your Wireless device, you didn't supply that info, If Secured, has a SSID (name) and a Security Key (password) . Who setup your wireless device? They have the info. I need more info on what the wireless device is? Make, Model?
Posted on Jan 11, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: having trouble adding computer to wireless network
this is just easy.. what you should type is the encryption key only... if your security is wep, only the encryption key or key 1 is needed. if your security is wpa, only the passphrase is needed.. it is very CASE SENSITIVE.. but if you see that the name has changed to LINKYS_SES, then you have a problem there because your wireless settings has changed due to the button on your router which is the secure easy set-up on the upper left corner which is the cisco button.
Posted on Feb 21, 2008
Lost my ssid on router seems to have reset somehow
Enable your SSID broadcast on your router, if not shown, insert SSID and/or password(if needed) manually.
Apr 13, 2014 | TP-LINK Computers & Internet
No sound or audio on gt313ts gaxaly tab 2 7.0 wifi
del anroid and then try fixing it again.
Jul 10, 2013 | Computers & Internet
No wifi toshiba satellite a665d s5178 un able to install a wireless drive and fnf8 doesnt work
Is the wireless switch on that is located on the side or front of the laptop?
Did you ever see any wireless networks to connect to? If so, did yours try to connect? maybe you have the password/network key in wrong. It will never connect if the password is wrong.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
May 09, 2012 | Toshiba Satellite A665D-S5178 15.6-Inch...
Wifi discovery problem. I have installed a Motorola SBG900i. All my wifi devices have had trouble discovering the SSID. When I do a scan available networks it does not exist. I forced 2 laptops to...
Assuming you haven't changed your modem's settings...
  1. Access the modem by typing http://192.168.100.1 in your browser.
  2. Enter the default username admin and password motorola
  3. On the left frame, click Wireless
  4. Click on the Security tab
  5. Under the tab, click Advanced
  6. Untick Disable ESSID Broadcast
May 13, 2011 | Arris SURFboard SBG900 Wireless Router...
I have a samsung LCD TV Model LA40C650L1R newly purchased a week ago . it went with an offer of free wifi wireless LAN adapter.I cant seem to connect it in the internet. I did all the configurations the...
Please test the WiFi with a laptop or netbook, if Internet works with it, maybe you have bad settings into the wireless adapter, you could use the PC wireless connection parameters (SSID, IP address, subnet mask, gateway, DNS) as reference with the data obtained with the TV wireless adapter, the only difference must be the IP address, the rest must be the same since they're using the same network.
Mar 15, 2011 | Samsung Televison & Video
Trying to hook up wireiess keeps asking for ssid what is ssid. staying at a motel with wifi
The SSID is the name of the wireless connection. Just do a search and connect to the one that doesn't have security on it.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
Im trying to set up a wireless modem, but i dont no how to r wat the switch looks like to turn on the wireless
usually there is not a switch to turn wifi on a modem you need a wireless device to try to access its wireless network
you need to plug a wired computer into your modem and type in default ip address 192.168.x.x they are slightly different for each brand EI: linksys 192.168.1.1 Dlink 192.168.0.1 telus: 192.168.1.254
so go into your router settings and you should have a wifi tab somewere in there you can set your SSID (what your wifi will be called) for something you will remember and maybe disable security untill you get your wifi device connected then add what ever security you like
when you try to access your wifi network witha wifi device you wifi light will come on your modem
Feb 05, 2011 | Acer Computers & Internet
How do i make a password on my wifi conection..my router is linksys BEFW11S4 v.2
First, your router is old, go pickup a new one that supports the G standard, don't worry it will fall back to B standard or better yet get an N standard router. To setup wireless security directly connect a pc via cat5 data cable to one of the switch ports on the router (not the wan) and login to the web innerface, click the wireless tab, now look for the security or encrypted options. Most routers support WPA-2 encryption where you enter a phrase of 2 or 3 words if your router only supports web encryption go buy a new router. Save it, then go to your pc, disconnect, remove the wifi ssid from your managed wireless list refresh and search for the ssid of your wireless signal (name), now connect and the router should challenge you for your WPA pass phrase you setup in the router. Now your wifi ssid is secure and all connections will require the passphrase.
Aug 28, 2010 | Linksys BEFW11S4 802.11b Wireless...
How to install the router
onfigure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Aug 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Psp how to get on to the internet using wifi
manfiodhslfksdhklfdnsklcvnsdklvnklscvnklscnvklscnvlksdnvklsdnvskld
Mar 06, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
