My fridgedaire crown series wont spin - Washing Machines
  • Washing Mach... Master
  • 17,129 Answers
If the washing machine works on all cycles but does not go to the SPIN cycle the fault seems more related to a failure to switch the motor in the SPIN cycle. You can confirm this with a voltage test while in this mode, If present then check the capacitors and drive.
If not the program controller is the suspect.
Posted on Jan 11, 2013
My fridgedaire washer wont spin onspin cycle?
There is not enough info and need model number
Jun 14, 2014 | Washing Machines
My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Feb 29, 2012 | Frigidaire Washing Machines
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
Drum came loose on Fridgedaire front loader on final spin cycle.
What was the point of posting this on the site?
The drum has broken loose from the support plate at the rear
You need a new drum and a support plate plus probably an outer shell.
A complaint to the manufacturer may get you a deal on a replacement
Jun 04, 2009 | Frigidaire ATF6000ES Front Load Washer
What can i do
ok you could have a series of problems, first check if fuel is getting to the engine, check fuel pump, see if when you open the ignition you hear a sssss sound meaning that fuel pump is working hope i was helpful thank you
May 27, 2009 | 2003 Ford Crown Victoria
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
