Question about Linksys E2500 Advanced Dual-Band N Router
I have my computers and printer plugged into my ES2500 Router what do I have to do to get the printer to work
    Sergeant:
  • 486 Answers
You need to configure it using a wizard cd and driver then install it.
Posted on Nov 05, 2013
How do I restore a lost connection from epson workforce 635 printer to mac ?
Try this. Unplug the printer and the computer. If it's a laptop you also remove the battery. Plug the printer into the AC socket and if nessary install the computer battery and plug the computer back in to the AC outlet and see if it recognizes the printer. This is essentially a reboot. If your using the printer through a network connection (router) make sure the router is working properly.
Aug 30, 2014 | Epson Office Equipment & Supplies
HP Officejet Pro L7650
The problem could be your web browser and its settings. You can try using another computer, or another browser. If you are using Internet Explorer, dry downloadingFirefox and accessing the router again. Hope this helps.Can you tell me which Internet Service Provider having you use. If your physical connectivity is pour or every minute or while reconnect your physical connectivity then your router also reconnect your ISP so router ask you password conformation for that.
If you using DSL connection then you do first that check your telephone wire physical connectivity and also if you have multimeter than check telephone wire voltage if is not stable than your telephone connectivitiy is pour so called telephone mechenic for that.
if everything is ok than ask your router company.
Dec 05, 2011 | Linksys Wireless-G Broadband Router
I have 1 ethernet connector but i need 2 spots 1 for the printer the other for the router please advise
So you want to comminictae the printer to your pc right? If you have a router, the printer should be plug in to the router directly as well as your pc to the router.
Oct 03, 2010 | Computers & Internet
Router quite working. Wireless does not work nor
Follow this procedure :
  1. Turn off all components on your network - computer, router, modem, printers and any wifi laptops
  2. With the ethernet cable connected only between the modem and the router TURN THE POWER TO THE ROUTER ON and let it boot up.
  3. Turn on the modem and let it boot up to all lights on.
  4. Connect / boot up any and all other components on your network.
Keep this order handy in case of a power outage. Best of successes!
Dec 04, 2009 | Linksys WRT160N Wireless Router
Wireless printer will not perform without usb cable
It sounds like your printer is not in sync with your wireless router.
Try restarting your computer, then make sure you have Internet access. (Click on Explorer or Firefox, and if you get access, then you know your router is working)
If your router isn't working, unplug the router for 10 or 15 seconds, then plug it back in. Then restart your computer again. That should work.
Once you are sure your router is working, you'll need to make sure your printer is in sync with your router. Best bet is to follow the instructions that came with your printer. You might have to put in the CD that came with the printer and reload the Photosmart programs. At one point during that process, it will ask you what type of router you have, and it will make a connection to the router, allowing you to print stuff without using a USB cable.
(I had to go through this process three times, for three different laptops in my house, and - knock on wood - we've been having great success with wireless printing with our Photosmart printer.)
Jan 18, 2009 | HP Photosmart C3180 All-In-One InkJet...
What router do I use for the hp officejet 6110 All-in-one
You should put both computers under the same "groupwork" name .
to change this settings right click on MY COMPUTER the go to properties
then the go under the COMPUTER NAME tab. CHANGE the settings Look at PICTURE #1
When you choose the "workgroup" name make sure that you pick a unique name.youll probably want to use your name.look at picture #2.after changes are done your asked to restart once you have done this FIRST part let me know i can help you with the setup of the Nwetwork Printer.b07620b.jpgbdecea2.jpg
Nov 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP C6100 Wireless printer has stopped working
The HP C6100 series has had some ip setting issues. One day my printer didn't print. I checked the ip settings on the printer and got some 648.154.1.654 address. I had no clue where this ip number came from, because my router's ip is 192.168.0.1. I went into the settings of my printer and set my ip settings manual. Then I went into the router settings and reserved the ip setting I previously setting on the printer to the printers MAC address. I also set static ip address for each computer on my network. This network response issue started about one year after I purchased the printer. I still lose connection every once in a while, but rebooting the router reconnects the printer and everything sitting in the que to print starts to print. To stablize the issue: upgrade router firmware, set static ip address on your network devices, reserve those ip address in your router, , if all else fails reboot router.
Jan 23, 2008 | HP Photosmart C6100 All-In-One Printer
Network Connection (LAN) for HP 650C
Plug it directly into the router and set the printer up on your Win2k/Xp as a network printer via the new printer wizard. The router will allow it to pull an IP number and you will find it on the network that way. It does not have USB because it was meant as an office printer and the option was network adaptor when purchased. If you look at the card in it, you can see it can be swapped out for another adaptor.
Apr 26, 2007 | HP DesignJet 750c plus InkJet Printer
Linksys E2500 Advanced Dual-Band N Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
