Question about Lantronix 1 PORT USB REMOTE KVM KVM/IP SPIDER (SLS200USB0-01) KVM Switch
Duplicate keystroke in spider 1 port usb kvm switch
Bridgeview 2-port USB/DVI KVM Switch not seeing the Kybd
With under $30 price, the DVI KVM switch with all-in-1 cable attached is a steal if it works. However, this kind of KVM switch is based on low-end USB hub structure or emulated USB structure.
For Windows 7 or newer OS, it will cause more compatibility issues. It is not driver issue. A hardware-base KVM switch 99% of them doesn't need driver.
My suggestion to you - looking more solid KVM switch technology - DDM based KVM switch. They are more expensive but in a long run, it is a better deal.
Jan 11, 2014 | Bridgeview br-u1021da 2-port usb-dvi kvm...
Toggle keys don't work as advertised
Hi David,
I located and downloaded a copy of the manual and found the details for [Scroll Lock] [Scroll Lock] [Enter] on page 8 that simply says:
"This will switch everything (KVM and sound) to the next port."
There is no mention of this keystroke switching to the next port "only if there is a computer connected" as you indicated in your question. It would seem to me that if the KVM switches to the next port when it receives the [Scroll Lock] [Scroll Lock] [Enter] keystroke - it is working as described in the manual that I downloaded from the IOGear site.
The only remaining commands accepted by the KVM are :
[Scroll Lock] [Scroll Lock] [a] [Enter] which is a 5 second Auto Scan mode
and:
[Scroll Lock] [Scroll Lock] [a] [n] [Enter] which is nearly identical as the a5 second Auto Scan mode - except the the numerical value you type in place of [n] is the number of seconds spent on the next port.
Double check your manual and if you're still having trouble - contact IOGear directly below:
Toll Free 866-9-IOGEAR (USA)
Phone: 949-453-8782
19641 Da Vinci, Foothill Ranch, CA92610
www.iogear.com
support@iogear.com
Dec 16, 2013 | IOGear GCS634U KVM Switch
How do i switch from pc to pc using the key board keys??
Hit scroll lock twice and priess the left or right arrow.
Jul 17, 2010 | Inland 08216 2-port KVM Switch
What are the keystrokes for a dell 582rr kvm?
Have you tried pressing Ctrl twice and then the port you want to control? I can't find the exact answer for you but here are few more;
1. Scroll lock twice and the port number you want to assign.
2. Numlock twice and the port number.
Same sequence as done with Ctrl key. (press Ctrl key twice and the desired port number).
Hope one of these will definitely work for you.
Good luck.
Thanks for using FixYa.
Jun 19, 2010 | Dell (582RR) 16-port KVM Switch
How can you switch over to different computers with the Scorpius -p7 trackball keyboard?
If your keyboard and this KVM Switch are both PS2 (from the picture I see the KVM Switch is PS2 and from the Internet searching for Scorpius -p7 trackball keyboard I see it can be either USB or PS2) the connections are straight forward.
Usually a 2 port KVM switch uses keystrokes to make the switch, they are usually "Scroll Lock" or rarely "Num Lock" -- press the key 2 times with about a second or less between presses. You may hear a BEEP from the switch indicating "it's hearing your request."
Good Luck
Jeff
Mar 02, 2010 | Belkin F1DK102P 2-port KVM Switch
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
Sometimes one of my computers *always same one) doesn't recognize the mouse and keyboard.
This is a common problem with KVM switches. To isolate the problem, here's what you need to do:
1. First, connect the keyboard and mouse directly to the problem computer to ensure that the keyboard and mouse works correctly while being directly connected.
2. Swap the connection of two computers. If you're having a problem on the computer that is connected to port 1 of the KVM, connect that computer to port 2 of the switch or just swap the connection. If the problem recur on port 1, then there's a problem with the keyboard and mouse cable on port 1.
3. But if you're not able to duplicate the problem on port 1 or 2, disconnect the KVM switch from the computers, leave it disconnected for 5 minutes.
4. After 5 minutes, reconnect the KVM to the computers and reboot the computers.
5. If same problem occur, then contact the manufacturer of the KVM and have them RMA the device.
Thank you!
Feb 09, 2010 | Edimax EK-PS2C (EKPS2C) 2-port KVM Switch
KVM troubles
Belkin.com....Switching software update.
Dec 04, 2007 | IOGear GCS632U 2-port KVM Switch
KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Sep 30, 2007 | IOGear USB gcs1734 4-port KVM Switch
8 port kvm console switch
KVM switches are hardware based and there is no use software.
Aug 22, 2006 | HP Console Switch (J1474A) 8-port KVM...
Lantronix 1 PORT USB REMOTE KVM KVM/IP SPIDER (SLS200USB0-01) KVM Switch Logo
41 people viewed this question
Top Lantronix Computers & Internet Experts
David Gust
Are you a Lantronix Computer and Internet Expert? Answer questions, earn points and help others
