Hi John Robert Trinidad:
I make this video for help ...wish you solve your problem
here's my dxdiag... and thank you for helping me...
my Proccesor is Core 2 Duo E4600 2.40 GHZ
i see you have a good processor if your memory 2G-or 4G kingston you will see good speed and your pc will be wonderfull don't forget your vga card socket is pci Express
my Ram is 8gb..
SOURCE: AGP 4x-8x compatability on msik7t turbo
It seems you can't, no. Your board supports AGP 1x, 2x and 4x; http://global.msi.com.tw/index.php?func=proddesc&prod_no=327&maincat_no=1&cat2_no=&cat3_no=
SOURCE: Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
SOURCE: graphics card compatibility
That mobo is here"
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138090
It says it has a PCIe x16 slot, so really good graphics cards running on PCIe x16 will work on it.
This is a list of the PCI express x16 cards you can buy:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048%201069609641&name=PCI%20Express%20x16
Generally the more they cost the better the performance but that is another story =)
If you wanna to hit me up with your full PC specs of CPU, RAM, Windows version, etc, i could recommend cards for certain games.
It also has PCI so older and less powerful PCI cards can likely be used.
SOURCE: how to connect graphics card in d945gcpe
Hi, Open the case of your system.if your graphics card is in agp type, locate it as shown at left (color brown). If it is a pci, installed into the pci slot as shown.
AGP Slot PCI Slot
Use the antistatic wrist strap to avoid electrostatic discharge (ESD). Or you can ground yourself into the case.
Hope it works,
geloaa
