Question about Toshiba Satellite A75-S209 Notebook
Laptop Boots then shuts off
Normal 0 My laptop (Toshiba A75-S209) froze and I had to manuallyshut it off to restart it. When it restarted it came up with the blackscreen/white letters that reads:
''We apologize for the inconvenience, but Windows did not startsuccessfully...etc...''
And it gave me options as to continue in ''Safe Mode'' and to continuenormally...I've tried each of the options and each one results in attempting toload Windows XP then a blue screen that flashes really quickly with white wordsbut my computer shuts off automatically, not giving me time to read any of it.It restarts on its own and does the same thing. I've tried not selectinganything and letting it ''start windows'' in its own ''in 30seconds''. And still it goes to the blue screen.
And then it says that it could be because ofhardware/software that's been unproperly downloaded or something and to makesure that it's downloaded correctly. But I can't get on the computer to dothat! (Keeps shutting off after that.).
I tried to reformat the HD but it shuts itself off over andover again. I am at a loss of what to do.
  • afamof5 Jan 22, 2009
    I am not able to do this because the laptop shuts off. I boot the laptop to the CDrom and the recovery starts but the laptop turns itself off.
  • 3 Answers
Well...i'm a technician...one of my customers had the exact same problem. After I disassableded the laptop i figured it out...it was a short circuit inside...this laptop had problems with the power supply too, and i had to connect a second power jack to it. Please Pmme if you are still interested in fixing this...
Posted on Sep 01, 2009
  • 52 Answers
It's definately no RAM, it can look like it's in properly when it's not, don't be afraid of giving it a good push! Also check the fan is still working as it will switch off if it's over heating
Posted on Oct 18, 2010
Put in a new stick of ram.it keeps restarting because there is no memory to use to boot up windows.
Posted on Feb 23, 2009
  • hilyar007 Aug 29, 2009
    im 80 percent sure its your ram. like the first guy said, there is no memory for the pc to boot from. and this has happened to me before. if you go to the f8 mode you can shut off the auto restart mode.
  • 81 Answers
Well what you can try to do is to perform a system restore on your computer by going into... the recovery console of your windows by using the winxp reinstal disc... the link to perform the following operation is mentioned below:-
http://support.microsoft.com/kb/314058
Posted on Jan 22, 2009
How do I restore my Toshiba Satellite A75 from the partition
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Aug 21, 2012 | Toshiba Satellite A75-S209 PC Notebook
How do I do a complete restore on a Toshiba Satellite A75-S209
your notebook.
Aug 21, 2012 | Toshiba Satellite A75-S209 Notebook
Wanted Toshiba Satellite A75-S209 17"
I had an old thinkpad that i needed a screen for...i believe I ordered it off ebay...and it was under 100 dollars...go to ebay and try it
Jun 11, 2011 | Toshiba Satellite A75-S209 Notebook
Is this laptop windows 7 compatible?
Hi, Your laptop:-"Toshiba Satellite A75-S209" is compatible with the Windows 7 operating system. Thank you for your time and best wishes for your effort.
Jan 06, 2011 | Toshiba Satellite A75-S209 Notebook
Toshiba Satellite A75-S209 (PSA70U-09700E) PC Notebook will not start.power lights come on for both the battery and DC. There is no fan or hard drive sound.power button does not light up. pushing the...
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
If the laptop won't start on AC power, what you could do is remove the system memory, clean the brass pins and the slots and then re-seat them/it.
Then try to turn the machine on.
Good luck.
Nov 13, 2009 | Toshiba Satellite A75-S209 Notebook
Toshiba boots up power light stays on and shuts down, bad m/b ?
I own a Laptop Toshiba Satellite A75-S2131.
This series have a problem with the cooling flow to the processor.
The processor overheats and the laptop shuts down.To solve this particular problem you must tear down the laptop and clean up the processor heatsink (you will find it totally plugged or partially dirty).
Find in the internet the step by step instructions (with photos) for dismantling this laptop. Do not forget to apply thermal paste between processor & heatsink.
I hope this solution helps.
Posted by MCampos
Mar 12, 2009 | Toshiba Satellite A75-S209 Notebook
Video on Toshiba Satellite A75-S209
check the display on external monitor through the vga port of the laptop,
Jul 17, 2008 | Toshiba Satellite A75-S209 Notebook
Open Questions:
Toshiba Satellite L15-S104, Model PSL10U-01X02F--A COMPLETE LEMON! 2-14-08 I purchased a Toshiba laptop in May 2005 at Best Buy in Montclair, California and all was good for a short time. Less than a year later I began to have so many problems. I took laptop to Best Buy Geek Squad and the hard drive had to be replaced! I had an extended warranty, so not any cost to me. I continued to have problems with the laptop and in took my laptop back to the Geek Squad in January 2008 and was told the laptop needed a motherboard at the cost of over $600! The warranty had ended. I have called Toshiba apx 4 times and finally given to a case manager and left on hold each time from 10 to 17 minutes! I have left messages and not anyone has returned my call. I have requested that my laptop be replaced. Christine Honea-Takata CHoneaTakata@msn.com Ever since I bought my laptop in December of 2004, I've had nothing but problems. My laptop overheats and shuts down repeatedly, the screen freezes, my sound only works 75% of the time, etc, etc. I have a stack of paperwork from the Geek Squad for numerous repairs - they've replaced everything at least once, some parts multiple times. They finally told me it was a lemon and that they were sending it in so that I could get a new lap top....6 weeks later I hadn't heard anything and called them - the usual waiting on the line, talking to 4 different people, them saying they'll call me back. A few days later I still hadn't heard back from them so I called again - same run around. They then told me that my lap top wasn't a lemon and that there was nothing they could do for me. I bought an extended warranty (3 years) and it's been in every few months - also meaning I'm without my blimmin' lap top for at least 2 weeks at a stretch. After my warranty ran out, I "gave up"...what more could I possibly do? The machine was a lemon from the start but Toshiba won't own up to anything. However, I know there was a class action law suit filed...haven't heard anything about it for the past year or so. I wouldn't touch a Toshiba with a ten foot pole. Terribly disappointed, angry and frustrated. I've lost huge amounts of data and had nothing but problems with customer service.
Apr 06, 2009 | Toshiba Satellite A75-S209 Notebook
Toshiba Satellite A75-S209 Notebook Logo
411 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
