Question about HP Compaq Presario V6000T Notebook
Blank screen i have a presario v6000, when i turn on my laptop nothing happens except blank screen, i don't hear anything and the only light that's on is the on and off switches. pls answer.
    Problem Solver:
  • 6 Answers
Hey Boots_Calara,
In most of hp/compaq dv6000 series that i have worked on have bad ram , easiest way is taking out the ram and replace it. Or if you have a friend that has a hp or compaq laptop switch the ram and try boot it with there ram. Try it before you replace the bad ram.
Posted on Jan 22, 2009
Screen on presario 2500 is black blank and won't change
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :-
May 19, 2012 | HP Compaq Business Notebook NX9010
I have a Compaq Presario V6000. I bought a
It sounds like you have a bad MIC. The MIC is located behind the bezel at the top.
Jan 26, 2010 | HP Compaq Presario V6000T 15.4" Notebook...
Compaq presario v6000 laptop when switched on blue lcd lights on only,can hear fan on but windows does'nt install and nothing on lcd screen what so ever. Every few minutes i hear a click noise and lcd...
It is the motherboard. The V6000, V2000 as well as the siblings in the HP line DV2000, DV6000, and DV9000 all have the same issue. In my opinion is from the oxidation of the motherboard contacts before the nVidia BallGridArray chips are hot air soldered to the board.
As the laptop heats and cools, these .014mm balls expand and contract. Where there is a poor solder pad, the solderball unsticks from the contact surface.
I have repaired 22+ in the month of October alone.
Oct 30, 2009 | HP Compaq Presario V6000T Notebook
Compaq Presario V6000, does not reboot, blank screen, and no power light ON, even after connecting to Power Plug. My Laptop is not getting ON.
Try on to remove the Battery. Wait 10 seconds to replug back again the battery.
Usually this happen when Motherboard Laptop are hang due to increase of wattage from the battery. I hope it is.
Sep 09, 2009 | IBM ThinkPad T40 2373 Notebook
When I turn my V6000 on, I have power lights and the fan starts for 5 secs then shuts off. Nothing appears on the screen!
Sorry to hear about your V6000 problems.
If this problem has just started and all was OK before this happened.!
1. Remove all media from drives.
2. Remove battery and A/C power input.
3. Flip unit over and remove the memory.
4. Disconnect the CMOS battery.
5. Remove the Hard Drive.
6. Flip unit over and Press the Start Button for 30 seconds.
7. Flip unit over again and re-install the Hard Drive, Memory and last, the CMOS battery.
Note ...
8. Reconnect the unit to the A/C input supply voltage.
Leave the battery out for NOW !.
Flip unit and try to start with the Touch Pad Led's. This should bring up Quick Play.
If your unit starts and you here several beeps,
Don’t worry, !! You should be able to access the BIOS screen. You can reset your date and time.
If you are still not able to start unit, drop me a email and I will try some other ideas.
Hope this works for you. !!
Try it, It may work !!
John Ray
Readers please rate your information, even if you disagree, it shows the technician, you care enough to respond.
Jul 09, 2009 | HP Compaq Presario V6000T 15.4" Notebook...
Not starting up
sounds like a dead processor
Jun 14, 2009 | Compaq Presario Notebook
Dvd not playing
thge lense is defetctive or dirty please try cleaning it usig one of the recommended cleaner disks that comes with liquide
Mar 31, 2009 | HP Compaq Presario V6000T Notebook PC
How can i reboot ma laptop itz compaq presario v6000 i want to clean all ma stuff hey  i followed what u said to do but when i pressed (f11) it brung me to a baby blue blank screen before i have...
You should start tapping the F11 key right after you turn the laptop on. It should go into the recovery mode, and you can select either a windows recovery (saving your data) or a full destructive recovery. If you feel you have picked up a virus, the destructive recovery is best, as this will put the laptop back to like new, out of the box condition.
Please rate this
Mar 15, 2009 | HP Compaq Presario V6000T Notebook
Pavilion dv6000t screen won't come on.
I had this exact problem with a customers computer andi found out that HP put faulty motherboards in the DV6000, DV9000, Compaq V6000 Series Computers. Thankfully HP fixing all computers for free and extending the warranty even if the warranty has expired they will ship you a box and you ship it off and they fix it at no cost. the turn around period is about 7 days.
Here is a link to an article that talks about it
Hope this helps!
Dec 14, 2008 | HP Pavilion dv6000t 15.4" Notebook Laptop...
Presario V6000 laptop
sounds like a motherboard issue ,
can you take the drive to another computer and check the contents are still accessible.
If contents are accesible then the motherboard is poked.
replace device and start again.
There is no cheap fix for this one unfortunately.
Keep me posted with your outcome thanks
Jul 20, 2008 | HP Compaq Presario V6000T Notebook
HP Compaq Presario V6000T Notebook Logo
259 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
