My new samsung Toploader model WA80V3 does not retain water. water drains out continuosly as soon as it gets in
jumptrout51
  • 3361 Answers
SOURCE: How can we troubleshhot a Maytag toploader that
You probably have something stuck in the drain pump. You will have to remove the hoses from the pump to extract it.
I can not be more help without a model number. Maytag builds several styles of top load washers. They all access differently.
Posted on Aug 30, 2009
  • 1937 Answers
SOURCE: washing machine model 110:23032102 is retaining
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23032102&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
I'd check the hoses for blockage, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
Posted on Apr 28, 2010
beltronic205
  • 1460 Answers
SOURCE: I have purchased SAMSUNG -
sounds like the drain pipe is too low resulting in Syphoning of water lift pipe above 24 inch floor level, this should cure...
Posted on Feb 01, 2011
  • 6277 Answers
SOURCE: Samsung WA80V3 leaking water at
It could be that the cap is not screwing on completely because of limescale in the thread and/or the filter is not seated properly. I suggest undoing the cap and removing the filter (if that is practical/possible) and spraying all with anticalc fluid to clean. This 'cure' helped another FixYa customer with a similar problem!
With ours I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed.
I now run an anticalc clean regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 15, 2011
barkencoa
  • 3463 Answers
SOURCE: Samsung WA80v3 connected to cold
It will heat the water as normal, even though it is a cold fill only washer.
Just select prog as normal, washer will do rest.
Posted on May 18, 2011
What's your question?defy toploader drain motor keeps running as soon as power switched on!!
Hi some machines do this to empty any water that may have been sitting in the bottom of your washing machine and the water has went stagnant. It should stop when you start a new washing cycle if it does not you will have to have your machine looked as it would just be draining the water as it goes in.
Mar 18, 2016 | Washing Machines
Got a Samsung Diamond Drum WA80V3 after I put in on quick was and start it goes 22 minutes and when at 15 it goes toe rinse but then the machine just stop doing anything. Water still inside drum. Maks n...
The drain pump is either blocked or failed. Check the filter if it's clear then you are most likely up for a new drain pump. Here is a link to the part you need and a video on how to do it. Samsung DC31 00030E DRAIN PUMP B20 3 120V 60 NEW ORIGINAL
Mar 15, 2015 | Samsung Washing Machines
Why does my Samsung washing machine wa80v3 not wash, spin or drain. ?
There are a few things that could cause this, first of all check the lid switch. That is a safety thing that makes sure the lid is closed before it allows it to start washing or spinning. Some other culprits could be a clogged filter, or a broken belt ( if your model has a belt) does the machine sound like its trying to wash? or does it just turn off and do nothing like its dead? if it seems dead its more than likely the lid switch, they are about $40 and simple to replace.
Jul 15, 2014 | Washing Machines
Samsung Washing Machine WA80v3 not working properly
Did the water start without you setting the cycle?
Nov 28, 2012 | Washing Machines
Water is continuously draining from my samsung washing machine . due to this unable to keep washing the clothes .why the problem come & what is the remedial measure to rectify?
Possible that the drain value is half blocked and so is not able to block the water in the tub. Remove the connection to the valve and check if this drains , if so it is confirmed. Remove, clean the dirt and reset. If the leak stays then the valve is faulty.
Also it can be due to partial voltage to the drain valve to keep it open which means that the program controller is faulty. This is confirmed when the drain stops as the connection to valve is taken off.
Jan 13, 2011 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
