Question about Frigidaire GLGF376 Gas Kitchen Range
GAS STOVE - MODEL GLGF377 - FRIGIDAIRE - OVEN SMALL EXPLOSION
HOW TO FIX THIS?
  • 318 Answers
Find the broken part and replace it. it really is that simple!!!!
now seriously, you need to explain what is wrong.
let us know what kind of problem you are having... ie. the oven glow bar glows but doesnt let gas in to heat.
if this is your problem then replace the glow-bar ignitor and that should fix it.
give us more info and we can help you out.
Posted on Jan 22, 2009
How do I turn my oven on? I have never had a gas stove, but I cant get the stove to start except if I turn right to grill in other words I can get it to ignite for 180 degrees etc only grill
normal operation is to push the oven knob in and turn
pushing in sets the igniter off and turning opens the gas flow to ignite
always light an oven with the oven door open
stop s an explosion if there is a problem
down load an operators manual bu going google and typing in --- user manual for ( make and model ) gas stove --- find a pdf version and download it
Aug 13, 2016 | Ovens
Frigidaire GLG=F366asd stove igniter problems and solutions . ... on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Where is the problem -- in the oven burner or a stovetop burner?
If something got spilled on a burner ring and clogged the small holes, especially near the igniter, the burner will be slow to light. A stiff wire (small enough to fit) can be used to clean out the holes.
Mar 18, 2012 | Kitchen Ranges
The clock(computer?)broke so I replaced that part it seems to work. I then tried the oven it will not light. The ignition glows red but does not light the gas. I can smell gas. I tried lighting the oven...
Just because an igniter glows, does not necessarily mean it is good. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
It sounds like you may have had a couple of problems. The gas smell concerns me though. If an igniter is weak, you shouldn't get any gas flow in the oven. This is a designed safety feature that prevents free flowing gas from filling up the oven cavity without ignition. I would recommend checking your igniter for the proper current and/or replace. The link I provided, lists the steps required. If you have any questions, please let me know. I hope this helps you.
Jun 25, 2009 | Frigidaire GLGF377 Gas Kitchen Range
FRIGIDAIRE GAS STOVE GLGF377ASE OVEN PROBLEM
i would replace the igniter and go ahead and replace the gas safty valve eather the ignitor is not allowing enought amps to open the gas valve enough to light or the valve is opening to slowly eather way i would go ahead and replace both this could be very dangerious is not repaired.
Jan 22, 2009 | Frigidaire GLGF376 Gas Kitchen Range
Covert a frigidaire stove to nat. gas
Lift the top of the stove up. Then there should be 4 nuts on the backs of the burner controls. Turn them left to open the valves for nat. gas. You want just a small amount of yellow on the flame. Then take the droor out of the oven and there should be another nut close to the gas valve for your oven flow. Do the same to the oven.
Nov 20, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Mice infestation problem
You will have to get rid of the mice first . Then take unit out and remove any nests that may be in there and clean it then fire it up it may smell but will kill off any smells .
Mar 17, 2017 | Frigidaire GLGF377 Gas Kitchen Range
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Frigidaire GLGF376 Gas Kitchen Range Logo
162 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
