Question about Danby DFF280WDB 9.9 cu. ft. Refrigerator/freezer
Fridge makes a car alarm sound
,when the bottom door is opened the sound stops. the Ifridge does not always make the sound just once in awhile
My Miele Fridge Freezer Keeps Beeping Although there is no issue, how do i remove the alarm?
I bet the light is also staying on inside even if the door is closed. There is a switch inside that turn the light on and off when the door is open. If the (Door Switch) is working then the light inside should shut off when the door is closed to save energy. It also tell the computer the door has been shut in case you forget then it will notify you. The switch may not be working. Look for a door with on ebay or sears. Need your model number and brand of the unit.
Sep 20, 2016 | Miele KFN8762SDED Bottom Freezer...
I have a GE Profile bottom freezer that door alarm will not stop. How do I fix it. I turned off the breaker for 30 minutes, and the alarm was silent when I powered back up, but the started to repeatedly...
Open freezer door. On top You will see 2 or 3 switches. Push all of them, if light in the freezer did not go off - you have bad door switch, if it did go off try same thing with fresh food door. Door switches do go bad once in a while on this fridges. Thanks
Mar 23, 2015 | GE Refrigerators
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Miele fridge keeps beeping
Door is open (shut it)
or
seal on door is broken ( replace it)
or
temperature dropped too low ( reduce it)
or
door was lett open too long (reset alarm)
- after ffix
press alarm buttons once to switch of beeps
Oct 20, 2013 | Miele KFN8862SD Bottom Freezer...
LG Side by Side refrigerator - ongoing intermittent beep - not door alarm
Have you cleared and cleaned the condenser and checked the water filter?
Apr 28, 2012 | LG Refrigerators
Alarm no longer sounds when fridge door is open
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
May 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Want to dismantle the alarm sound.
I did this before and couldn't remember how. This works on our fridge which has a water dispenser and a bunch of buttons on the left door: Try holding the express freez and lock button for a few seconds. The beeping of the buttons should stop too. I tried countless live chats with the LG people and none of them could help me. I tried a bunch of combinations and found this one to work.
May 01, 2009 | LG LFC25770TT Bottom Freezer French Door...
Fridge light not shutting down, alarm on, temperature heating up
you do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Oct 20, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Open Questions:
Danby Refrig DFFC1WDB, two years old, in my vacation home that I visit one weekend a month. Lights flashing, power cycled (after req'd 5 mins). Discovered coils were packed with ice. See below: 1.) Danby Refrigerator DFFC1WDB, about two years old, in my vacation home that I visit one weekend a month 2.) Never defrosted it manually before (i.e. turned off and left to defrost) 3.) For some time I noticed the light inside the fridge was flashing, but the refrigerator seemed to be cooling okay and the manual says nothing about what the flashing light means. I attributed it to a power failure and the flashing stops once the unit is unplugged and plugged back in (power cycled) after 5 minutes or so. 4.) This visit I noticed the flashing lights again and that the freezer was cold (it was heavily loaded) but fridge was barely cool. I power cycled the fridge (allowing 5 minutes) and the flashing stopped but I was concerned about the issue and threw out some food. 5.) I unplugged the unit again and removed everything from the freezer. I noticed a thick coating of ice on the freezer back wall. I used a hair dryer to melt this coating of ice and then realized that the coils behind this wall must be covered in ice. I removed the back wall exposing the coils and discovered that I was correct: The coils were completely covered/packed with ice, so I greatly sped up the melting process with the hair dryer. After all, I had food sitting in coolers with ice and wanted to return it to the freezer and fridge asap. 6.) Once all the ice was gone I left the freezer open for a while for the coils and assembly to cool (since I had used a hair dryer to melt away the ice pack) 7.) I set the freezer and fridge to their coldest settings and plugged it back in. The lights do not flash when I plugged it back in. The compressor (I assume) ran for a while (the fan in the freezer ran also), and during this time I heard the unit lightly buzzing (with life), and then it stopped. But it seemed to have quite a way to go when it stopped and the freezer and fridge were not nearly cold enough at that point. I surmised that it might be entering one of its periodic defrosting periods, but after quite a while of waiting it still hadn't started running again so I power cycled the unit again and again the compressor/fan ran for a while and then stopped. It just doesn't seem to be starting on its own unless I power cycle it (waiting the required 5 minutes before plugging it back in.) At this point I don't have confidence that it is cooling well enough to keep my food fresh (and frozen). 8.) What do you think could be wrong? It certainly seems reasonable that the part/system responsible for periodically defrosting the coils may have failed. But since the unit is completely defrosted now, why does the unit only run for a short time after unplugging/replugging and never run again?
Jun 10, 2018 | Danby Refrigerators
Danby DFF280WDB 9.9 cu. ft. Refrigerator/freezer Logo
128 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
