Question about Jenn-Air JGS8750BDS Stainless Steel Gas Kitchen Range
Jgs8750bds control panel not working - Jenn-Air JGS8750BDS Stainless Steel Gas Kitchen Range
Bravo 2012 gas dryer control panel
I have the same dryer. My control panel went dead today too. Light in drum works just fine. Nothing working at all on the control panel.
Mar 07, 2014 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
The control panel isn't working properly. How do
Try getting in through the start menu, your documents, and your search bar. If all fails, then start your computers command prompt, (type in search button in start menu: "cmd") just type in: "start control" and press enter; the control panel will launch. Also, if you type "run" in your start menu search bar and type in control followed by pressing the enter key, the control panel should start up.
Jun 22, 2013 | Computers & Internet
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Dishwashers
Regency problems
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
Main Control Board
Jun 14, 2013 | Maytag Dishwashers
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Sep 28, 2012 | Leisure DWLT65 Dishwasher
Touch keypad on the JGS8750BDS is unresponisve, still getting power as the clock is still functioning. is there a breaker besides the ones on my house I can trip on and off to reset it
the touchpad could be bad or the clock assy. also could be bad,just because the clock still lites up doesn't mean the computer board isn't bad.is there any error codes that come up?also have you tried shutting it down for a while,sometimes the computer board has to be rebooted just like a regular computer,another thing you can try is unplug it,remove the front panel or touchpad,unplug the ribbin and then plug it back in,i've done this before and the touchpad functioned again.also check the tech sheet or book that came with it,on some there's a lock on the touchpad so kids can't start the oven,someone could have locked the touchpad but there isn't any other fuse to check for.on the sears site your touchpad is 252 dollars and the part number is W10206074 the electronic control is 185 and the part number is 8507P227-60 but you can call your parts store and make sure this is correct.did the power go out in your area or anything like that to cause this or did it just stop working altogether.it sounds like a bad touchpad but for that kind of money you might want to call someone in to check it
Dec 08, 2011 | Jenn-Air JGS8750BDS Stainless Steel Gas...
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will...
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Aug 26, 2008 | Kitchen Ranges
Ignition "clicks" forever
If only one out of the surface burners clicking, rotate the cap perhaps it doesnt sit properly,or check the electrode if broken replace it.
If it was all surface burners clicking. replace your spark module
Jul 22, 2008 | Jenn-Air JGS8750BDS Stainless Steel Gas...
Jenn-Air JGS8750BDS Stainless Steel Gas Kitchen Range Logo
48 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
