Question about Torgoen T8 Pilot Watch T08103
What is the battery number for the Torgoen T8 (it takes 3 separate batteries
2 Suggested Answers
headstrong56
  • 493 Answers
SOURCE: i got a torgoen swiss T8 where do i get batters and what kind do i need
a jewelry store that deal with watches can tell you and actually replace it for you
Posted on Jul 15, 2012
Torgoen - T27105 n'est marche pas,je vient juste de l'acheter mais il marche pas
Lis les instructions de mise en marche de la montre. Lis aussi la section en cas de probl`eme. Si elle refuse de se mettre en marche, retourne au magasin et demande un remboursement. La prochaine fois que tu veux acheter une montre demande au marchand de v'erifier le bon 'etat de marche.
Jan 28, 2014 | Torgoen T27105 T27 Pilot Watch
I got a torgoen swiss T8 where do i get batters and what kind do i need
Jul 14, 2012 | Torgoen T8 Pilot Watch T08103
BATTERY REPLACEMENT FOR RELIC WET WATCH ZR11657????
If you can, pop the back of the watch off, the battery will have 3 digits, and some letters, for example 375R, 325LRW, etc. the 3 digit number is the type of battery you need. If you cannot read the number, then typically, if you take out the battery, and you measure the width, and height of the battery, then find another battery with the same measurements, it will work, trust me.
i hope i helped!
Jul 17, 2011 | Relic Wet ZR11657 Watch for Men
Watch stops intermittantly. Where can I send or take it for repair. I live in Boston.
This one has good reviews:
The watch hospital inc. 40 Bromfield Street, Boston, MA 02108(617) 542-8332
Thanks and good luck!
May 25, 2011 | Torgoen Zulu Time T50108s02 Watch for Men
I have an old fossil bq-8793, years ago I was going to replace the battery myself. I lost the battery back then, there seems to be no indication on the watch itself as to what size it takes inside or out....
Back Plate:
About 1 1/4'' inches wide. Inside inscription/stamp reads:
FOSSIL INC. HONG KONG 1
Battery:
Energizer 373
Movement plate:
There are 3 inscriptions/stamps
1) S (May be a # 5)
2) 1A
3) TMI TIME MODULE INC. JAPAN VX3J
(The above number stamp may also read UX3J)
Mar 29, 2011 | Watches
What type of battery goes into Casio G shock MTG900, Module 2638
CTL is the designation for a rechargeable secondary battery. The CR is a primary disposable battery and is a 3 volt cell. The CTL1616 while the same size as the CR1616 function completely differently and are not interchangeable. The CTL1616 is 2.3 volts and is recharged by solar or light or kinetic movement. The CR1616 is 3 volts is not rechargeable and will not function properly in a time piece designed for a 2.3 volt circuit. There is only one manufacturer of the CTL1616, Panasonic and they sell through Casio parts distribution.
Jan 22, 2009 | Luminox 3102 (Size: ) Watch for Men
I have just replaced the CR 2016 battery in my Timex Ironman it says after battery insertion short AC pad and battery ( ) to reset. How do I do this ?
To all who need to change their Timex Ironman Triathlon watches:
It is a little confusing, but this is a watch you can change the battery by yourself!
First you will need:
-A big clear area (i.e. a table or counter) with lots of light to see what exactly you are doing.
-Small screw driver (like the tiny ones for a glasses care kit)
-Paper clip
Directions:
1. Remove all screws from the the back of the watch (there should be 4). Make sure that you take note of which screws are coming from which spot on your watch and keep them separated as such.
2. Next, you should see a white circular sticker with directions on how to change your battery. They aren't clear as "how to" but they are the basics.
2a. Take off the white sticker once you have memorized the places it is pointing to; set it up as such in front of you so you can refer back to it from time to time.
2b. You should see two silver pieces. One should be a circle (which is the battery), which is held in by another silver piece. This unlatches. In order to do so, you need to simply pop it open on one of the sides (as it tells you in the directions). You may use the same screwdriver or even a paper clip works wonders!
3. Replace your battery (should be CR2016) with the + on top, facing towards you. make sure it is flat, not just shoved back where the old battery was. This make take some extra time and patience to make sure it is done right.
4. Snap the silver part back into place (should look like it is holding the battery in place i.e. a gate).
5. THEN: this is the most important and confusing part in my opinion. On the white sticker the directions read: "after battery insertion, short pads to reset". this should look something like an oval with a line cutting it in half (vertically). It is not on the battery but next to it. You will need the paper clip here to hold down the right most side (at somewhat of an angle). this should do it! you'll know if your digital faces flashes numbers at you and may even light up. Make sure you hold down long enough.
6. Once you have the numbers flashing, you are good to go. Put the back of your watch back on, taking note of which screw goes where. Then, set your watch accordingly and you have just changed your watch! Ta-da!
Follow these steps and you should be good. Good luck to all!
Apr 22, 2008 | Watches
Torgoen T8 Pilot Watch T08103 Logo
75 people viewed this question
Top Torgoen Watches Experts
Jimmy Accardi
Are you a Torgoen Watch Expert? Answer questions, earn points and help others
