Question about Panasonic Heating & Cooling
F 90 error code panasonic air conditioner
I have this error code - how do I fix the air conditioner - Any ideas PS have cleaned the air filters and the timer light on the front panel keeps blinking
  • Patrick Jan 11, 2013
    I can switch the unit off at the circuit breaker on my home panel then on again - the unit will now work for 2minutes or so then switch off and timer light blinks. the unit is a model CU-E12GKR
3 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
Posted on Jun 13, 2010
Comfort Control Center 2. Why is E-1 error displayed?
[PDF]Customer assistance for air filters cleaning (E1 code)
www.sharpusa.com/.../air_man_AFS100FX_S120FX_S125F...
Sharp SolarCustomer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners. The display will indicate an E1 code and not allow the unit to operate until the ...
Sep 08, 2015 | Dometic Rooftop RV Air Conditioner
Showing an error code E4. What does this mean as the filters have been cleaned recently? Thank you
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Diffeent ac's have diffrent error codes. I need this information to better assist you. Fix my ac
May 04, 2015 | Heating & Cooling
Panasonic fault codes
I found this error. The simple possible resolution is to reset the circuit breakers feeding this unit and/or replace possible blown fuses. Other possible problems may be too involved therefore a professional should be hired. Just a warning, this problem could get expensive.
Dec 11, 2013 | Heating & Cooling
Error code e3
This often happens when the evaporator freezes up. The freezing temp is not normal and the frost sensor causes an error code. You should open the unit and clean the evap and condensor thoroughly. Let it thaw out if its frozen with ice. Drain the unit. Clean the evap thoroughly. Reasemble and run in fan mode to let the unit dry out. This should fix it 90% of the time. Rarely there will be an actual problem with the sensor in the rear of the unit, you can check the wires leading to the sensor when you have it open for cleaning - sometimes they will be broken when you remove and replace the filter.
Jul 30, 2012 | Windchaser PAC9 Air Conditioner
What to do to fix the E1 error on a haier her08xc7
Push buttons about five times each beforjust to make sure they are not stuck....then......Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. See the Care and Cleaning section in your use and care manual. After cleaning, replace the filter and plug the air conditioner back in.
Other forums say the E1 code is because the AC thinks a button is stuck or because it's dirty, but almost all of them say to use the remote and it'll work ok.
Jul 23, 2012 | Haier HWR08XC7 Air Conditioner
E1 error code
E1-Automatic filter clean reminder.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 07, 2011 | Haier HWR06XC7 Air Conditioner
I have an E1 error code
Hi
E1 means Automatic filter clean reminder. Turn the air conditioner OFF and unplug it. Kindly make sure that the air conditioner is unplugged for the automatic filter clean timer to reset, then clean the filter. After cleaning, replace the filter and plug the air conditioner back in.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | GE Heating & Cooling
Heating & Cooling Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
