Question about Electronics - Others
32GB microSD card Damaged
Last Wednesday morning i woke up messing up with a damaged SD card on my LG optimus one P500 phone. i was so confused about it because it worked all fine when i locked it. it has been 3 days i'm working on recovering it but NO luck. i plugged it on Desktop with a card reader that i used previously with it but my computer still doesn't recognized it (...prompts me to reformat or "Please insert a Disk into Removable...) . I've been trying using every Tool to recover it but still NO LUCK! i used HP USB Disk Storage Format Tool and many others just to fix it but still doesn't work at all. i also tried cleaning it up using DiskPart on windows. NO USE! Windows disk management recognized it but with unallocated label on it. i'm still having a hope because it showed up on windows disk management with 29.72GB space which is it's actual storage use. What else would be possibly recover my 32GB Apcaer micro SDcard? *********************************************************************************** ANY HELP WOULD BE MUCH APPRECIATED AND APPLAUDED! *********************************************************************************** THANKS MUCH!
  • 27,725 Answers
Click start control panel Administrative tools Computer Management Disk Management right click on your drive select properties click tools you should see click check now click start two boxes Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not do anything while the chkdsk utility is in progress any input may damage this drive. You might get best results ticking in one box the returning after it has finished then ticking the other box it might take some time depending on the of your disk but be patient. Hope it helps.
Posted on Jan 11, 2013
Testimonial: "***** SOLVED ***** OK ......!!!! I'm back again.... BUT NOW with GOOD NEWS to ya'll! just this morning ***PST (UTC+8)*** i've got to have had my Common sense to work out for the sake of this NOT SO CHEAP 32GB SD card i've been trying to recover it's functionality for 5 days, NOW I've got it working fine and i mean CLEAN SD Card and fully functioning. this is what i did, and thank you for giving me a hint. i should've listened and think carefully when you wrote :"An SDHC reader is required to read the high capacity cards since the memory allocation formatting is different." with that in mind, i thought that moving or copying files to and from an SDHC memory stick using a NON-SDHC Card reader is OK. BUT FORMATTING an SDHC memory stick using a NON-SDHC Card reader is NOT OK (just according to my observation). what i really did was to insert the MicroSD card to its given ADAPTER and plug it directly to an SDcard reader slot of a LAPTOP (LENOVO 32bit Win7 home basic) and lauched windows diskpart. here's the step solved it in diskpart: list disk, select disk x (x-number of my sdcard) clean, create partition primary, active, list volume, select volume x (x-volume of my sdcard), format fs=fat32 quick. and everything went OK. AND NOW I'M OK TOO ;-). "
  • 26 more comments
  • Joward Castillo
    Joward Castillo Jan 12, 2013
    Thanks for your reply but i don't see "tools" anyway when i right-click my device. all i see are tabs General, Policies, Volumes, Driver, and Details. what will i do next?
  • Brian Sullivan
    Brian Sullivan Jan 12, 2013
    which operating system? what options are available if you select the policies tab you might check all other tabs to see what options are available
  • Brian Sullivan
    locate the card in "My Computer" or Windows Explorer" and right-click on it. right click on it there select tools
  • Joward Castillo
    64bit Windows 7 Professional. it seems that there's a problem in my SD card. i tried to insert another sd car which is 16GB and tried to do the following guide you provided and it worked. i see tabs General, tools, hardware and customize which i do not see when i plug my 32GB Sd Card. anyway, my 32GB SD card is Apacer and my 16GB is Transcend. Only Options i can see on the policies tab are "Quick Removal(default)" and "Better performance" . In the General Tab it says: This device is working properly. i wonder why....
  • Brian Sullivan
    just computers and there devices they like to have there own way did you try it in windows explorer ?
  • Joward Castillo
    I tried that already but windows could not perform the disk check because the disk is not formatted. when i format it, windows could not finish formatting it for unknown reason.
  • Brian Sullivan
    An SDHC reader is required to read the high capacity cards since the memory allocation formatting is different. If your data is on an SDHC card, it may be intact but you'll need the SDHC device to read it. Some devices, such as readers and cameras, may have software downloads available to upgrade the device to read the SDHC cards. Go to the device manufacturer's website to determine whether such an upgrade is available.
  • Brian Sullivan
    it might be write protected
  • Joward Castillo
    I am not certain that my card reader is an SDHC device but previously, it worked fine for me to copy files to and from my computer using my 32GB SD card on my reader so i don't think it's about my reader but i'll try that.
  • Joward Castillo
    write protection i think can be bypassed using diskpart on windows that i tried yesterday. and i didn't do anything to write protect it. anyway, do you know of anyway to remove write protection so that i can format it?
  • Brian Sullivan
    click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
  • Joward Castillo
    Then Apply? Done...so do i have to format it now?
  • Brian Sullivan
    no only if you dont want to recover anything on it all will be lost if you format it
  • Brian Sullivan
    run the chkdsk utility on it right click select properties tools you know the drill
  • Joward Castillo
    So i just have to open it and use it? when i opened it, it says "Please insert a disk into Removable Disk (I): anyway it's mounted as Drive I in my computer.
  • Joward Castillo
    "The disk check could not be performed because windows can't access the disk." why is that?
  • Brian Sullivan
    windows 7 can be a real pain with large usb drives you might have to alternate running the chkdsk on it restoring it to its default status Right click on your drive select properties then on customize restore Default in W 7 .Sometimes leaving the drive in the computer and restarting it gets its working again and sometimes it does not it might be tedious but just try alternating a few of these things
  • Joward Castillo
    Ok! i'll try every best of me to fix it my own with your guides cuz i think i'm too much of annoying to you. thanks anyway for dropping me HELP. Good day and hope to meeting you in many other Problems i'll be encountering,,, :-)
  • Brian Sullivan
    no problems hope it all works out and do keep me posted on the outcome i have completly steered away fro using large usb drives on windows 7 it seemed every time i would insert one i had to do exactly what i have explained to you to get them working again
  • Joward Castillo
    Joward Castillo Jan 14, 2013
    Everything didn\'t even work either. i\'m gettin\' annoyed having NO HOPE of making my SD card usable again..... i already bought another 32GB and now SanDisk but i\'m still trying to repair my Apacer 32GB Sd Card with window\'s disk management, diskpart,and everything else.
  • Brian Sullivan
    Brian Sullivan Jan 14, 2013
    you might run into problems using your new large usb drive with windows 7
  • Joward Castillo
    I really HOPE NOT SIR! anyway, just to make you aware, it's not win7 who prompted me that my SD card was damaged. it's Android ICS. but Google's Android doesn't seem to be having problems with SDHC Devices. so BLAME is to Apacers' .... if in no escape i'll be having problems with my new 32GB SanDisk Sd card, you guys are always willing to help. :-)
  • Brian Sullivan
    anyway good luck with this
  • Joward Castillo
    Yea and THANK YOU SO MUCH FOR SHARING YOUR PRECIOUS TIME helping me.
  • Joward Castillo
    Joward Castillo Jan 15, 2013
  • Brian Sullivan
    Brian Sullivan Jan 15, 2013
    well done and thanks for replying with the good news glad to see your good with it
  • Joward Castillo
    NOT if i'm not having nightmares wanting my SD card back. haha!
  • Brian Sullivan
    at the end of the day they are still only computers and there devices temperamental things
  • 31 Answers
To recover photos from SDHC card or the other memory cards, the Recover Files software works great as it does not have any kind of drawbacks. You should try the same to get back your lost images right now. For all the details follow the below mentioned link,
http://www.recoverfiles.org/photo-recovery/recover-pictures-from-sdhc-card
Posted on Feb 02, 2013
SOURCE: Insignia mp3 player reads "Unable to format external memory!!"
I too had this same problem.
i downloaded and installed the firmware update...and now my 2gb microSD is readable.
link for download:
http://www.insignia-products.com/t-New%20Video%20Player%20Firmware.aspx
follow directions and you'll be good to go.
Posted on Nov 02, 2008
  • 71 Answers
SOURCE: I have a SanDisk 4GB MicroSD (TransFlash) Memory
Sounds like a defective card. Some phones only take up to 2 gigs, and will not format anything larger. Try the card on another phone or computer.
Posted on Jul 25, 2009
niquose
  • 198 Answers
SOURCE: I just got a new 8GB SanDisk Mobile Ultra
Make sure that the card is properly inserted (all the way in) in the reader. It is possible that the SD card adaptor does not support 8GB microSDHC or the Mobilemate is defective. But it is highly likely to be the card that is defective.
You may want to try inserting the card to a phone that supports microSDHC to see if it will be detected. Otherwise, that proves that your card is defective.
Posted on Aug 03, 2009
SOURCE: unallocated usb part - Win 7
i just fixed my usb 8 GB. It was all space unallocated.
and i just formated it with paragon partition manager. Now ir works fine
Posted on Dec 07, 2009
SOURCE: PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
I had the same issue with my 4GB Sony Memory Card when I put it in my memory card slot on my computer. I have a Toshiba laptop, so what I did that fixed the problem is I went to Toshibas Support Webpage in the downloads section and under the CATEGORY: Driver Card Reader and re-downloaded: Ricoh Card Reader for Windows 7 (32/64)(v3.54.02; 09-04-2009; 4.94M) and once I did that it read my memory card and didn't give me any more issues and it opened all my pictures. Of course if you don't have a Toshiba then you would go to your manufacturers web site and see if they have the same thing, because that is what fixed my issue and it didn't take long at all.
Posted on Sep 05, 2010
How do I change the SD card
Removing the microSD Card
To safely remove the microSD card from your device, you first need to unmount it.
WARNING: On the Android OS 2.3, you can download applications from Android Market and store them
on a microSD card as well as on the device. Due to this feature, skipping the unmount procedure can cause an error because information between the microSD card and the device is not accorded properly. In the worst case, the microSD card can be corrupted or damaged.
1. Press > > Settings>Storage>Unmount SD card.
Confirm your selection by tapping
OK.Now you can safely remove the microSD card.
2.Remove the back cover using the fingertip cutout at the bottom of the cover.
3. Gently press the microSD card in to release it and carefully pull it out of the slot.
Inserting the microSD Card
1. Remove the back cover using the fingertip cutout at the bottom of the cover.
2. Position the microSD card with the label side facing up and slide it into place until it is fully inserted
and locked in place.
Note
Be sure to
use only recommended microSD cards (up to 32GB). Using non-recommended microSD cards could cause data
loss and damage your device
Oct 19, 2014 | LG Optimus Slider
What operating system is an lg optimus
. It runs Android 4.0 / Ice Cream Sandwich, which makes up for the slower processor and is micro sd card expandable to 32gb (comes with a 4gb card). It's a 3G phone - not the fastest, but definitely works well.
Jan 19, 2014 | LG KU990 Viewty
Operating instructions for LG-P500 phone
LG Optimus One P500 User Manual/Guide - New LG Cell Phones bullseye.bmp
lge-phones.org/lg-optimus-one-p500-user-manualguide.html
LG P500 MANUAL; manual LG P500; lg-p500 manual; lg optimus one user guide; ... Upcoming LG Cell Phones; USB Drivers; User Manual; Verizon Wireless LG Cell Phone;
Mar 15, 2013 | LG Cell Phones
Need flashplayer for LG Optimus P500 T
LG Optimus P500 will not support flash. if you want to install/run Flash then you need to upgrade your hardware in P500. Contact LG mobile support service center to upgrade.
Thanks,
Mr.Maduraikaran.
Nov 07, 2011 | LG P500 Cell Phone
I need a manual for lgv700
Here you go:LG Optimus ONE P500 User Manual Download
You will need adobe reader to open the manual PDF.
Regards, Chris
Aug 20, 2011 | LG P500 Cell Phone
Hi, I am using LG P500 with 2GB Memory Card. its working awesome. Now thinking of moving to 8GB or 16GB Micro Sd card. However, I have heard from some forum that LG P500 is causing problem with 8GB. Can...
you r right optimus one hangs on 8 gb card many times card automatically get removed and some time phone restarts however 2gb card is working fine
Feb 05, 2011 | Cameras
LG P500 how do i connect to internet?
I'm able to connect internet on my pc by using my lg optimus p500 as a modem, but I'm getting only 115 kbps speed while i have 3G card which give me speed of 3.6Mbps on my mobile.
May be this 115 kbps speed is my pc to phone connecting speed. So i can't use my 3G speed
How can I connect my lg p500 modem with 7.2 or 3.6 Mbps to my pc
Jan 29, 2011 | LG Cell Phones
I have LG Optimus One P500 . I am able to connect my phone to PC and transfer files in storage mode. But when i run PC suite it is not able to detect my phone. Pls Help
Uncheck the Mass storage only under SD card and phone storage settings, then try again will do. Hope this will help you.
Dec 11, 2010 | LG Cell Phones
Electronics - Others Logo
2,034 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
