Question about Vacuums
How to remove brush roller bottom plate
I have removed two long screws the other two are loosened but not completely removed I want to take the bottom plate off to get at the brush roller
  • Becky Grayem Jan 11, 2013
    electrolux discoveryIII
  • Vacuums Master
  • 18,409 Answers
Make and model ??????
Posted on Jan 11, 2013
    Electrolux Discovery III
  • 1462 Answers
SOURCE: cannot get new belt on
no need to remove motor shaft which is integral with motor. slip belt on motor shaft first, then on roller then pull roller back to correct position. needs a little force
Posted on Jun 06, 2007
  • 126 Answers
SOURCE: Bissell 7950 ProHeat Self Propelled Carpet cleaner Replacement Pump Belt part 215-0628
Normally, there is a post sticking out of the retainer to remove it. If the post is broken off, then you will have to lift the black arm and wiggle it at the same time and the retainer will pop up so you can remove it. On the belt side, the retainer is fairly large and you can usually get a hold of it with a pair of needle nose pliers. On the other side, the retainer is small and you can lift it out with the pliers by griping it gently using the hole that the screw goes through.
Posted on Jan 27, 2008
SOURCE: Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Posted on Aug 16, 2008
  • 134 Answers
SOURCE: Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Posted on Mar 12, 2009
  • 61 Answers
SOURCE: Dyson Animal DC14 brush will not rotate. Removed
If this model takes a clutch then it is stripped and needs to be replaced.
Posted on Apr 15, 2009
Machine just rotates same spot in a circle
I just repaired my 530 roomba last night. I used a sewing machine brush and cotton swabs. On the bottom of the roomba there is a face plate with four screws. Loosen each of these four screws and remove the face plate. DUST EVERY OPENING YOU CAN SEE, but do it gently. Use NO chemicals. Then there is the area that holds in the brush and roller cartridge. Again, loosen those four screws and remove the corner brush's screw and completely remove that little brush. Then you will carefully remove the "case" holding the brush and roller cartridge.DUST EVERY OPENING YOU CAN SEE. Wipe all the silver contact points..plates on the bottom of roomba and one inside the brush and roller cartridge. At this point, I dampened a paper towel ever so slightly with some window cleaner and wiped and dried those contact points. Then using the brush attachment on my vacuum I gently went over all areas of the body of the roomba to dislodge even more dust. Once that is done, reattach all the parts in the reverse order of how you removed them. I charged my roomba overnight and this morning she was charged and worked as if she were brand new! I hope this helps. If my solution works for you,please contact FIXYA and rate my advice.
Nov 18, 2010 | iRobot Roomba 530 Robotic Vacuum
Tip
How To Replace The Belt on The Riccar 8850 Upright Vacuum
Greetings from GoVacuum,
I will attempt to walk you through the belt change on your Riccar 8955 upright vacuum cleaner. I have taken pictures for you for each step to ensure that it's done properly. What you'll need to have handy for this repair;
- Phillips Head Screw Driver
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum cleaner is unplugged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush
Step 3: Remove the belt guard that sits to the left of the roller brush, and is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift straight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), but the other end of the belt through your new roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continuously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, position the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right. Here's a picture of the belt guard being put back into place;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Change the the rug / floor switch from bare floors to the carpet setting, and the turn the vacuum upside again so the brush and belt are exposed:
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
Step 12: There is a flap that can be opened after the metal bottom plate has been removed, that will give you more access to the motor shaft. Make sure that this flap is closed;
Step 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as low as if the bottom plate is correctly installed. Here's a picture of the lip with the bottom plate in the backgroud;
Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. The lip is a little tricky, but after doing it just once, you'll have no problems in the future changing your belt.
Here's a picture of the bottom plate installed INCORRECTLY with the bottom plate over top of the lip;
Here's a picture of the CORRECT way to install the bottom plate:
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the 4 Thumbs Up Icons in the top right hand corner of the solution. Feel free to request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions.
Thank you very much,
Chris J.
on Mar 21, 2010 | Riccar 8850 Vacuum
Tip
How To Replace The Belt On Riccar 8850 Upright Vacuums
Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Chris J.
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
How to replace the belt in the 8850 model
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the 4 Thumbs Up Icons in the top right hand corner of the solution. Feel free to send me an email, or request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions. Be sure to check out our website for any Riccar parts that you may need, including; Riccar Vacuum Bags, Filters, Belts, and Parts.
Chris Jones
GoVacuum.com
Mar 19, 2010 | Riccar 8955 Upright Vacuum
I bought a replacement brushroll because the one in the vaccum cleaner is worn out.How do I go about putting the brush in the vaccum cleaner. Do I pull it out or do I have to unscrew the entire bottom...
Make sure the vacuum is NOT plugged in. In order to replace the roller brush, you'll need to unscrew the 6 screws on the bottom plate of the vacuum cleaner. Oreck uses a Phillips Head screw, so you'll need to get a Phillips head screw driver to replace the brush.
After removing the screws from the bottom plate, simply pull up on the plate by putting your fingers into the open area where the existing brush is located. After the bottom plate has been removed you will have access to the roller brush and belt.
You can now just grab the roller brush and pull straight up on it. It's beneficial to change the belt of the vacuum when you're replacing the roller brush anyways. There is a spare belt on the actual bottom plate of all Oreck XL vacuums.
You'll notice that the new roller brush has two black square plastic caps on both sides of the roller brush. You can look on the outside of this black cap, and you'll see the words OLD and NEW. Rotate the NEW side so it's facing upwards, and the OLD side is the side that's down inside the vacuum cleaner, make sure that both sides have the NEW side facing upwards. You'll need to wrap the belt around the silver pin in the back of the vacuum on one side, and through the roller brush's metal pulley on the other side. The just stretch the belt with the brush inside of it, and place the black plastic parts back into the vacuum cleaner.
Congratulations, you've now just replaced the roller brush in your Oreck!
Please feel free to email me if you have any questions on how to complete this repair, or just request a clarification through this Fixya page. My email address is chris.jones@govacuum.com.
If this repair solution was helpful, please be sure to rate this repair as helpful by clicking the 4 Thumbs Up icons in the top right hand corner of this repair solution.
Be sure to check out http://www.govacuum.com for all Oreck vacuum cleaner parts and supplies!
Chris Jones
GoVacuum.com
Mar 16, 2010 | Oreck XL2000 Bagged Upright Vacuum
How to replace belt on Riccar
Step 1: Make sure the vacuum cleaner is unpluged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unsrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift staight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, posistion the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Chris Jones
Feb 22, 2010 | Riccar 8955 Upright Vacuum
Changing Belt on Riccar 8650
Chris J.
Feb 17, 2009 | Riccar 8650/8625 s Vacuum
Riccar 8700 Brush Roll
Greetings,
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the Thumbs Up Icons in the lower right hand corner of the solution. Feel free to request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions.
Chris Jones
Oct 11, 2008 | Riccar 8955 Upright Vacuum
How to clean the power brush on the miele vacuum. Is the brush removable? If so how do you remove it?
Greetings from GoVacuum.com,
Miele canisters have 2 different types of power brushes. The first, and most popular is the Miele SEB 217, and 213 Power heads. To remove the brush, follow these instructions.
On the bottom of the power head there are 2 yellow (older models it is black) plastic screws. You can remove these screws with a phillips head, or flat head screw driver. Simply unscrew these two screws. You do NOT have to remove these screws, just unscrew them to where they are loose enough to remove the bottom plate.
Once you have unscrewed the plastic screws, simply pull the bottom plate up and off of the power brush. You will notice the belt on the left hand side of the brush. Simply pull the brush up, and un hook the belt from the brush;
Now that you have unhooked the brush from the belt, you may thoroughly clean the brush, and un wrap any hair or thread that is wrapped around the brush. You will notice on the roller brush itself there are two indentions on both sides of the brush that run the entire length of the brush. You can take a knife or scissors and run them down the brush on both indentions, which will help you remove the stubborn debris wrapped around them.
Also you'll notice on both sides of the brush that there is a yellow bearing cap on both sides of the brush. You may pull these bearing caps off, and remove any debris that is around these caps. You may also lubricate these bearings with grease or WD-40, to ensure the brushes spin fluently.
After you have cleaned the brushes and bearings, insert the brush roller back through the belt, and into the power brush. You'll notice that the bearing cap will have two sides. One side of the bearing cap has 1 groove in it, the other side has 2 grooves.
When you reinsert the brush back into the power brush, you may lower the roller brushes if the machine has been used a lot. If the roller brush is older, you will want to re insert the brush with the side that has 2 grooves facing upwards, and the side with 1 groove in it, facing down. In the first picture above, you will see that the side with 1 groove is facing upwards and is visible to the camera. The side with 2 grooves is facing down. This is because this brush is new. If your brush is older, you will want to reverse that, and have the side with 2 grooves facing upwards. When the brush is back into the power head, simply put the bottom plate back on, (IMPORTANT! Make sure that in the front of the machine the bottom plate is completely hooked onto the front of the power brush, there should NOT be any space in the front) Once you have screwed the plastic screws back into the power brush, in the front of the power head, push the bottom plate upwards to make sure there it is fastened tightly in the front.
I hope this helps you. If you have the larger, less popular SEB236 power brush, just send me an email, I'd be happy to walk you through cleaning the brush on this one also. If you have any questions about this repair, please feel free to email with any questions, I really enjoy sharing my knowledge, and passion fixing vacuum cleaners.
Chris Jones
GoVacuum.com
Sep 29, 2008 | Miele Vacuums
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
