Question about JVC AV-48P575 48" Rear Projection HDTV-Ready Television
Need a av-48p575 that has good power supply board and conv output
The rest can be damaged or broke just need help finging junk tvs to get parts from any help would be great thanks for all the help
    President:
  • JVC Master
  • 1,779 Answers
Try Shop Jimmy.Com
Posted on Feb 14, 2009
Repair or Junk my Samsung UN55C6500VF TV?
Hi William,
Not necessary to junk your TV. Damages due to lightning are extensive at times but from what you have mentioned it appears that may be it is only the power supply board which has gone bad and rest of the TV is ok. Replacing power board may restore your TV.
Good Luck.
Aug 24, 2015 | Samsung Televison & Video
JVC Model No. AV-48P575. Picture goes all distorted after it's been on awhile, then a bit later it goes back then distorted again. Can someone please help
Ur tv are developing a problems call convergence,it dying.The convergence board the 2 STK convergence ICS,and some or all it resistors are dying.These parts are must be changed to solved the convergence problems.The shop will cost u $300-350 for the parts and labors.
May 21, 2010 | JVC AV-48P575 48" Rear Projection...
Clicking on the power supply board(no picture or sound)
If you hear a buzzing, humming or rapid clicking noises this could be a problem with your ballast.Might be a good idea though to pull out your lamp just ensure its not damaged.You can find these at discount-merchant.com
Apr 01, 2010 | JVC AV-48P575 48" Rear Projection...
I am lookin for parts for jvc av-48p575 power supply panel and
hello have you tryed ebay also here is website you could try mulja repair portal-index you can buy spare
parts try and find out the part number of the panel you need . you could give this company a call it's called wiltsgrove in birmingham 01217722733 good luck
shaun
Jan 24, 2009 | JVC AV-48P575 48" Rear Projection...
Jvc tv model av-56wp74
1024x768 Normal 0 Won’t start
The power supply has an automatic shutdown circuit that senses a shorted component and excessive current flow.
If you can access the convergence board and remove the plugs one at a time (red, blue or green) for the convergence output, the TV may start up and show a picture with the unplugged color misaligned.
This confirms a short in the convergence output. The convergence IC failure can show up as coloured outlines or power supply shutdown.
If this does not help, then there is some other short circuit in power or deflection circuits. You need a technician to troubleshoot HV or power problems.
Replacing the output amplifiers (located within the Convergence IC's) allows the pictures to line up correctly, and no more color outlines or power shutdown.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable shop/manufacturer's support to repair because of their design that causes other power supply or vertical deflection problems. The poorly designed products require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip may fail again.
This is not a simple repair like changing batteries or a fuse. Reading through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with other "new and improved" IC's, like STK 392-150. These are devices with different characteristics and require different value resistors in the circuit. Replacing with the STK 392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience working on your JVC. My website is below with some costs and explanation.
calgaryconvergencerepair.weebly.com/convergence-explanation.html
Good Luck,
Easyab
May 08, 2008 | JVC AV-56WP74 56" Rear Projection...
Power problem
Dear tonyb73,
Try to check the relay in your power supply, it might have a loose solder or loose connection at the back of PC board. The sound that you hear when you plug is the relay itself. if your set newer , check for loose connections on pins and other connecting parts of relay. That is located in the power supply section. If nothing happened after resoldering, then replace the relay, probably the contact points is corroded or damaged.Hope this will help...pls. send feedback so we can work together.. Thank you....
Good Luck..
rgrds,
Eriez
Apr 27, 2008 | JVC AV-48P575 48" Rear Projection...
Need help to locate two parts.
the parts are the convergence power supply and convegence amplifier board. two circit boards that are over the main cuircit board. I dont find there too difficult to replace. i believe union electronics carries those. always be carefull in a television. there are voltages that will hurt you.
Nov 11, 2007 | RCA D52W19 52" Rear Projection Television
JVC AV-48P575 48" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
