Question about Minolta XG-A 35mm SLR Camera
Line in Picture
I have a vertical line just to the left of center of all my pictures. Is this a bad seal letting in light? Can I fix this by tightening up the door or does the seal have to be replaced?
  • 944 Answers
Here is the free link for the user manual if you need it; http://ca.konicaminolta.com/support/manuals/film-cameras/film_mf_slr/xg_a/xg_a_manual.pdf These guys have a copy of the parts list for sale ($5); http://www.natcam.net/manuals.html Try this guy for a service manual; http://www.vikenk.com/minolta_manual.htm I think you are right about the seal issue - check there is no play in the door - most likely causes of it being loose would be a loose latch or worn hinge guides / bent hinge pins. Replace or tighten is hard to say from the info i could find, my guess is it will be much easier to tighten it than to find the spares, although many xg-as are advertised on e-bay "for spares". One way to test for sure is to put in new film, then tape the door shut as solidly as you can, and tape around the edges with black PVC electrical tape - see if this helps, if not, there may be a problem in the optics, possibly not worth fixing. There could feasibly be a problem with the shutter sticking slightly, or one of the plates of the aperture could be bent away from its neighbour. Have a look, be gentle. Only other thing I can think of is the film itself - was it good, new film you had the problem with? old film could feasibly show those symptoms, although unlikely, Hope this helps, please ask again if you need more info :)
Posted on Jul 04, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Jul 04, 2007
    PS if you think the seal is ok, but you still get the line, try taking it to a camera store for a service - unless you have the tools yourself it is usually cheaper, in particular get them to lubricate all the appropriate moving parts.
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
Aug 18, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Lines across the top of screen
If this is a picture tube set (not a thin screen), then you have a bad electrolytic capacitor in the vertical circuit. Just about all picture tube sets that I've worked on that get lines at the top was caused by a bad or leaky cap and is a common problem w/ most sets. There's a very slim chance it could be the vertical ic but normally when it goes bad you will have nothing but a thin white line running across the center of the screen from left to right. If it's just a capacitor, the part would only cost a couple of dollars at most, however there's no way I can tell you exactly which one to change w/ out looking in the set. A repair shop would probably get between $30-$50 to fix it. If you can give me the model number of the tv, I can see if I can you some more info.
Jul 28, 2010 | Sylvania Televison & Video
Picture go into a thin line.
You have a thin horizontal line in the center of the TV. You, in this case have vertical IC that has bad grounds. Resolder the vertical IC pins and check the capacitors in the immediate area and replace these caps as necessary. If you still have a horizontal line, you will have to replace the vertical IC. Find a TV tech or someone with electronic experience to do this for you. Should be reasonable to fix. Thanks for asking and Good Luck!
May 30, 2010 | Sanyo AVM-3659S 36" TV
No picture just on line in the middle left to right
I know the line is horizontal but the problem is in the "Vertical" circuit of the set that deflects the picture from the middle of the screen to the top and bottom.
Only a few easy possible reasons for this.
1) set has developed bad solder connections in the vertical output circuit--it happens as a normal thing and most sets like this the picture will have opened and closed before going to just a line.
2) a part in the vertical output circuit is bad---most common is a IC chip for output. Not real hard to get at or replace and is inexpensive.
If it is as stated here a 27 inch set it may not be economical to fix and cheaper to just consider replacing it.
Let me know if you have questions.
SD TECH
May 02, 2010 | Sansui 27 inch TV
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
I only have a Horizonal bow tie looking line for a pictuce
Do you have a thin line in the middle of the screen running left to right and no picture above or below?
If so read below
This is an easy repair if you've ever soldered or it would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.let me know if this helped. -VOTE
Sep 22, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Vertical lines in the picture on light background only
It sounds like you have Image burn in on your crt's. This happens when you watch programs in 4X3 mode. (The sides are blacked or grayed out and the picture is centered in the screen). The only way to fix this is to replace the crt's. I wish I had better news. Let me know if I can be of further assistance
Jan 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Blurred picture
Sounds like a resistor in the convergence circuits or covergence amp ICs them selves. Usually the ICs will distort the picture. My guess would be the flame proof resistors near the ICs 1 or 2 may be oen. Let me know if you need anything further.
Jan 26, 2008 | Toshiba 61HX70 61" Rear Projection...
Minolta XG-A 35mm SLR Camera Logo
139 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
