Question about Watches
G-shock g-741d speaker and back light problems
I had to replace my g-shock watch batteries. I put in 2 new batteries, reset the watch with the AC and (-) terminals and now the speaker and back light wont work. I have tried resetting it a few times but nothing works. The back light button works as I can use it to set time. The speaker's spring is there and makes contact with the speaker on the case back. Can anyone help fix these issues?
SOURCE: columbia watch - set time
Hope this helps!
I found it finally!!!
Good luck, I hope this helps you!!!
Columbia by Fossil Customer Service Contact
Contact this seller Phone: 800-449-3056
Posted on Jan 11, 2008
SOURCE: Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
Posted on Jan 16, 2008
upajos
  • 24 Answers
SOURCE: battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Posted on Oct 29, 2008
upajos
  • 24 Answers
SOURCE: please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
escapement
  • 2334 Answers
SOURCE: I have replaced my battery in my Oakley sports
Use this link:
http://oakley.com/customer_service/support/watches
If you can not find your particular watch here, email them using same site and ask for instructions to be sent to you.
Rate me, please.
Posted on Aug 14, 2009
Testimonial: "Appreciate your feedback. Problem solved and watch back in action. Tks. "
Changing batteries on a Casio G-Shock Cockpit watch
yes. wrong battery possibly...
395/399 = SR927SW/SR927W
The 395 is a lower power output but same voltage (1.5v). The power spike of shorting might have caused a spike in the watch electronics.. make sure they are right polarity too. These batteries are not high current items, but maintain their voltage over the 5+ year lifespan. The S and SW are basically interchangable except for the higher amerage output.
Jan 03, 2015 | Casio G-Shock G511-1AV Wrist Watch
Those batteries are compatible. The reset isn't working right. You may need to send the watch in, or take it to a repair shop that is familiar with that watch. You can probably find one in any large mall...
Jan 03, 2015 | Casio Watches
How do I replace the battery, in a Casio G-Shock G-2300 9V watch?
Your watch is a solar powered watch and normally you don't need battery change .Nevertheless,if (as it is an old Casio model),you are convinced that battery is the cause of your problems,then replace.
1) You have to be absolutely sure that you are able to carry out the procedure.
2) IMPORTANT!! Pse note that the specific battery IS NOT an ordinary battery as it is rechargeable.DO NOT TRY TO REPLACE WITH AN ORDINARY ONE.RISK OF EXPLOSION on your wrist.+total damage of the watch.New battery has to be exactly the same with the old one (ID.code).Can be ordered on E-Bay,I suppose.
3)TOOLS:Watchmakers screw drivers + philips small size screw driver (for backcover screws) + watchmaker tweezers + 2 finger rubber gloves.
Turn the watch upside down and carefully remove the four screws (try not to loose them).Remove the strap if needed.Gently remove the back cover.Pay attention as there must be 1 or 2 tiny springs embeded on the mechanism.Keep them in place and try not to loose them.You have to remove the plastic cover (pay extreme caution to the spring/s) in order to have access to the battery.Unlatch and remove (if needed) the battery holder ( if can be removed-remember the position to put it back correctly).Take out the battery and check for possible leaks.Check the battery compartment cleaness.DO NOT TOUCH WITH BARE FINGERTIPS THE CONTACTS OF THE BATTERY COMPARTMENT.DO NOT TOUCH THE NEW BATTERY ON BOTH SIDES WITH BARE FINGERTIPS.Use the finger gloves.Put the new battery in place (do not force) and secure back the battery lamina holder.There is a AC(All clear-reset) contact on the mechanism.Using the tweezers touch one end on this contact and the other to the metallic body of the mechanism.Lift the watch very carefully(as it is,upside down-without disturbing spring/s) and check if display is activated.By paying much caution put back the plastic cover correctly in position PAYING CAUTION TO THE SPRING/S. Clean up the back cover,gasket,and gasket furrow from dirt as good as possible.Check the gasket condition.Replace if needed.Apply a little amount of special gasket silicon compound all around the gasket,both sides.Put the gasket in place.Put back gently the back cover and screws in position.MAKE SURE TO POSITION THE BACK COVER CORRECTLY(in place and not upside down).Press it gently when in correct position before you screw.CHECK ALL AROUND FOR CORRECT CONTACT. DO NOT SCREW TOO TIGHT,DO NOT FORCE.Screw with fingertips until you meet resistance.
I hope this will help.
BRegards
Jul 04, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
I have a gw-500a and the battery got replaced with a brand new one, but my watch still says charge and it won't let me change the mode or anything. The time is on the screen though. Please help
You have to reset this watch after battery replacement. Using tweezers or something similar you have to touch the AC & - contact on back of watch, for 2 seconds. Hope this helps.
Dec 23, 2010 | Casio G-Shock GW500A-1V Wrist Watch
How do i replacs the batterie in a g-shock illuminator
<P>Thanks for contacting FixYa.</P><P>Found a great tutorial for you.</P><P>Ive been changing batteries for 25 years and I wouldnt touch this one, so best of luck to you!!</P><P><A href="http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html">http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html</A></P><P>If you do this one, then you should get in the biz for sure!!</P><P>Jewel</P>
Aug 26, 2010 | Casio GShock Illuminator watch
POD watch battery replacement. No problem removing back of the watch - (waterproof / 4 small screws), however the battery is held in place under a ''cage'' type of cover and not the usual single spring...
Unscrew the screws holding that contact. Memorize where each screw was - they can be different in length. Fit new battery, put contact back in place and screw all screws back exactly where they were. After that you may need to shortcut battery's+ and AC point (marked on movement) for resetting your watch. Use tweezers to do that. Rate me, plz.
Feb 02, 2010 | Watches
Replaced battery in Casio G Shock 2317 and now hands do not move at all.
Take the battery out again, wait for a few minutes, then replace it and shortcut AC and battery. After that you have to reset your watch completely. To find AC you will need an eyeglass.
Mar 02, 2009 | Casio G-Shock G2600 watch
Buttons stopped working
Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
Good luck.
Arthur
Dec 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Battery replacement for a G-shock.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
