Question about Gigabyte M7800e Wireless Mouse
I have changed batteries with new brand but still red light on mouse.
My Logitech MX 1100 just stopped working out of the blue. The red battery light on top is blinking, so even though I've only been using this for a couple weeks (and the batteries were fairly fresh) I...
I had the same problem, brand new battery, the indicator light still blinking red. I finally got mad enough to shake the mouse kinda hard, and it worked. I then removed and replaced the old batteries in, it started blinking red again, but it worked after I gave it a couple of hard side by side shake. I do notice that there's something moving inside the mouse. It could be a connector that got loose. Hope this fixes your problem
Sep 25, 2010 | Logitech MX1100 LASER Mouse
My usb wireless mouse receiver displays a red light on the far right on what appears to be a picture of a battery. The green light lights up the number 9 on the left. WHAT DOES THE RED LIGHT MEAN? I don't...
I just had the same problem. If you look at the picture carefully, it's the mouse & the red light means you need to change the battery in your mouse. The picture just to the left of mouse picture is the keyboard so if that turns red, then you need to change the batteries in your keyboard.
Jun 11, 2010 | Dell Wireless Keyboard Optical Mouse w0147
How do i charge it?
You do have re-chargeable batteries in it? You could try a new set of batteries and there's usually a "Connect button you can press to reconnect it after installing new batteries.
Jan 02, 2010 | Dynex Wireless Optical Mouse
Laser mouse no power
Make sure that the switch on the mouse is ON. Try another battery. If you get the same problem, you need to contact the manufacturer or the reseller for RMA.
Jul 09, 2009 | ACCO Brands Kensington PilotBoard 64390...
Receiver light is steady green. mouse won't light up. cursor won't move.
Why don't you try at the moment of placing a new battery to see if the small button that protrudes, where the receiver is located at the bottom of the mouse is pressed down. Without the receiver in place that **** on must be out for as long as the receiver is in the USB port.
Good luck!!!
Chawah.
May 19, 2009 | Microsoft Wireless Notebook Optical Mouse...
My GE mouse doesn't work anymore
First thing to do is check the device manager. If it shows up there, make sure that there are no icons saying there is a problem.
Jul 29, 2017 | GE JASHO97985 Mouse
Logitech cordless mouse red light won't go off - New Batteries
Check the bottom of the mouse for a connect button. Push the connect button and it should work.
Mar 21, 2009 | Logitech LX5 Cordless Optical Mouse
Flashing red light
Most wireless mice will hibernate after a short period of inactivity. If something bumps the desk or moves the mouse it will start scanning again. If you don't like the light, you could try a laser mouse (no red LED flashing).
Feb 08, 2009 | HP Wireless Optical Mouse
Open Questions:
Gigabyte M7800e Wireless Mouse Logo
42 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
