Question about Visioneer Office Equipment & Supplies
Documents when scanned have lines or is half scanned.
Need to know how to clean or do I need to buy another scanner.
My scanner is critical to my business.
  • 537 Answers
Look at the optical scanning strip (small strip) and clean it with some WIndex. This is an ADF scanner right? If not, still clean the glass.
Posted on Jan 22, 2009
Canon DR-2580C scanner only scanning half the page. What could be the problem?
Select Auto for page size. The scanning software displays scanned image in many options, including 'fit'. Choose 'fit' so that you see complete image.
S. Mohan
Dec 29, 2011 | Canon DR-2580C Path-Through Scanner
Why do I have a black line down the side of my scanned documents?
If you are using the ADF (Automatic Document Feeder) there is likely debris in that section of the scanning glass. The ADF parks the scanner in place and moves the paper over it, if something is on the scanner it will show up as a line. Check the thin section of glass at whichever end of the scanning deck for dust and clean it with a dry towel. If this is happening with documents on the scanner bed the debris is likely in the scanner and will likely need professional servicing.
Jun 09, 2010 | Office Equipment & Supplies
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
Line appears on all scanned documents. Scaning window & rollers have been cleaned.
Do the lines appear in the same location on all images? Please clean the glass with isopropyl alcohol.IF the lines are crisp and sharp at the edges on all levels of contrast, then it is module problem. If it varies depending upon the contrast chosen and is also with jaggered edges, it is dust stuck on the glass. Dont use solvents.
S. Mohan, Chennai, India
Jun 02, 2009 | Canon Office Equipment & Supplies
Line on far right of scanned documents
Most likely the scanner has dirt on the glass that is over the imaging array or the glass may be scrached. If the glass is scratch, the imaging CCD array need to be replaced. If you do not scan the rear of your documents, you can swap the upper with the lower in the case that one is scratched.
The imaging array are the green long bars, one at the bottom of the paper path halfway inside the scanner and the other is above it. Look closely for a small spot of black toner or dirt stuck
on the glass. Take a soft cloth, wet it with water or alcohol if needed and clean the glass.
Pass you finger over the glass, try to feel if all of the toner or rubber residue has been removed.
You might try looking at the specific area were your documents image is getting the line. It will
help you pinpoint where you should clean. CAREFULL not to push on the glass as this
might break it. Hope this helps.
Otaron
Sep 08, 2008 | Kodak Digital Science 2500D Path-Through...
Line on Scanned Documents
There is a spot on the thin strip of glass that sits next to the large scanner glass. Because you are moving the paper when using the feeder, a spot appears as a line. Shining a flashlight on the glass can help you locate it. You can scrape it off with a finger nail or clean it with a damp cloth.
May 09, 2008 | Office Equipment & Supplies
Scanner excludes front page
This is not the only solution, but this might help.
Put a blank page in as the first page and see if all of your documents scan completely.
You may need to clean the ADF. Try the following:
Cleaning the Automatic Document Feeder
You may need to clean the ADF feed mechanism if your
documents do not feed easily into the ADF, or several feed in at the
same time.
To clean the ADF:
1. Dampen a soft cloth with some isopropyl rubbing alcohol
(95%).
2. Press the ADF cover release on the top left of the scanner body
to open the Automatic Document Feeder cover.
3. Wipe the feed roller from side to side. Rotate the roller to clean
its entire surface.
4. Wipe the pad from top to bottom. Be careful not to snag the
cloth on the springs on either side of the pad.
5. Close the cover when you’re finished.
NOTE: Please be careful when cleaning the roller. The roller is
designed to rotate in one direction only. As you’re cleaning the
roller, make sure it rotates easily, and continue rotating it in that
direction while wiping it clean. Do NOT force the roller to rotate
in the opposite direction. Forcing the roller to rotate will damage
it, and may cause the scanner to feed pages incorrectly.
Please let me know if this has helped and thank you. Binary Bob
Dec 05, 2007 | Xerox DocuMate 252 Path-Through Scanner
Scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
Sep 29, 2006 | Canon DR-1210C Scanner
190 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Level 1 Expert
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
