Question about Dayton (3VE49) Oil Filled Liquid Fuel Radiator Heater
Need manual for dayton 3ve49 heater - Dayton (3VE49) Oil Filled Liquid Fuel Radiator Heater
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Need a manual for a Dayton Model 2YU40 electric heater
Contact Grainger
http://www.grainger.com/product/DAYTON-Convection-Ceiling-Heater-2YU40
Grainger owns Dayton manufacturing
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 05, 2014 | Water Heaters
I need a manual or wiring diagram for Dayton Unit Heater 2YU70
Dayton heaters are a product of Grainger Industrial Supply.They have locations throughout the country, which can help you with the manual. For a location near you go to the following link.
http://www.grainger.com/Grainger/wwg/branchSearchRender.shtml
Apr 21, 2011 | Dayton (4LX41) Heater
I am having a problem with my 170K BTU unit. The bearing went out and I replaced it. At the same time the unit is spraying fuel but won't light/ignite. We are in the middle of an artic front and I need...
Remove the top and turn the heater on. Look for the igniter and make sure it is working. I don't know which type you have, but it could be the spark plug type or may be a HSI (hot surface igniter which will just glow until the heater starts). If the igniter isn't working, you may need to clean the sparkplug and set the gap. You can also check the transformer for the igniter. If it is the HSI type make sure it isn't broken off. Also check the flame sensor.
Jan 11, 2011 | Dayton (3VE49) Oil Filled Liquid Fuel...
I HAVE A DAYTON 3VE49 TURN IT ON FAN RUNS GETS SPARK BUT IT SEEMS TO NOT BE GETTING FUEL I HAVE TO BLOW AIR THRU THE FAN PUMP HOSE TO FORCE THE FUEL TO THE SPARK I CHECKED THE LINES CLEAR THE PROP INSIDE...
Check the fuel lines and the nozzle. Make sure there are no leaks from the air/fuel lines at the nozzle fittings or air pump. The air pressure from the pump is no where near what you forced to the nozzle with an air compressor. You can push fuel past a plugged nozzle to get it to fire with your compressor, but the air pump can not even if it's new. Check the lines for leaks with soapy water. take off the nozzle and clean it to be sure it isn't plugged. Dont loose the spring inside to nozzle. Check the pressure at the pump testing port. You can buy a gage as descibed below at an ATV dealer. use a valve stem with 1/4 threaded end and a shrader valve at the other to adapt this for testing. Extra low pressure pencil-type gauge registers 1-20 psi in 1/2 lb. units. Do not use a standard tire gage, They are not accurate at low pressures.
Good Luck
Dec 23, 2010 | Dayton E48 Oil Filled Utility Heater
Runs for short period and shuts off
bruce how658,
You have a classic reddy heater problem. Actually reddy heat and dayton are the same. They have a fuel pump which is dependent upon the pressure of the air filter to maintain exactly 4.5 psi or your unit will do what you describe. This is an easy fix and I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, where to get the parts and how to do the repair.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 07, 2010 | Dayton (3VE49) Oil Filled Liquid Fuel...
I need a service manual for a Dayton 3e219e heater.
I have a manual for a Dayton 3E219E. If you want a copy email me at Edwards0202@aol.com and put "HEATER MANUAL" in the subject line. I can scan it in and email it back to you. This manual is for 2E510F, 2E511F, 3E218E and 3E219E. I also found a great web site for parts for all these models as well: http://www.bealsmotor.com/
Jan 08, 2010 | Dayton E50 Heater
I need a service manual for a Dayton oil fired 350,000 BTU heater.
I have a manual for a Dayton 3E218E. If you want a copy email me at Edwards0202@aol.com and put "HEATER MANUAL" in the subject line. I can scan it in and email it back to you. This manual is for 2E510F, 2E511F, 3E218E and 3E219E. I also found a great web site for parts for all these models as well:
Nov 30, 2009 | Dayton E50 Heater
I need an installition manual for a Dayton
u have to googel installtion manual and download
Nov 24, 2009 | Dayton Gas Furnace Heater
Dayton unit heater
Dayton heaters are a product sold by Grainger. Contact them for a manual.
Aug 26, 2008 | Dayton Heating & Cooling
Dayton (3VE49) Oil Filled Liquid Fuel Radiator Heater Logo
64 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
